SOURCE: FRIGIDAIRE UPRIGHT FREEZER ONLY 2 BOTTOM SHELFS FREEZING
someone suggested to me the other day to put weter foods closer to the top the ones with dripin water and more solids down at bottom they said this changes the climate inside to be more economical
im just passing this info cause ive never had or been in contact with a upright freezer
SOURCE: Replacement glass shelf required
Not too sure what your glass shelf looks like, but if you can't find replacements it might be easier to just get a sheet of plexiglass and glass cutting tool from a home depo (or the like) and cut it to the correct measurements. That's what I did for mine.
SOURCE: Wire shelf in freezer of Frigidaire refrgerator - how do I move?
since on differnet models it goes right or left,
but you should be able to push the shelf one way, enough so that the other side pops out of the wall
then slide in the long side first, you will see what i mean when you have the shelf out
push the long side in with a lil pressure and raise the shelf the leve you want it installed on
SOURCE: frigidaire upright freezer ffu21k2cw1 has frost on
I have bad news for you. EAch of your shelves is part of the evaporator coil. This is the coil where the liquid refrigerant expands into a vapor. If only one shelf has frost, and the other shelves no longer do, then you have a low side sealed system leak of your refrigerant. You could have it repaired, but that is a major service call, and to have it repaired properly to EPA regulations, it is quite expensive.
sorry
SOURCE: MFD2560HEW Bottom freezer french doors. Top shelf
At this point I am not sure if your Auto Damper that regulates the cold air is stuck closed or if the thermistor that controls the damper is responsible. You could also be having a defrost problem restricting the air flow to the fresh food section. Look into rear of freezer to see if there is a layer of frost building on rear panel. If yes then we will need to focus in a different direction. First by manually unplugging fridge and then using a hair dryer to help speed things up. The manual also has diagnostics test that you can do to locate a problem area like thermistors or many other errors will show once placed into diagnostics. Sea Breeze
