Question about Cell Phones
How to access my phones settings from my nook because it was stolen
Why does keyboard keeps hitting same key without touching
Heres a few ways to get around issues with keyboading.
What keyboard app are you using? You can download alternative keyboard apps as one way to get around bugs in the stock Nook Keyboard app. I love Swiftkey as it's now free. Google itself has has its own keyboard app. Both run circles around stock aspecially Swiftkey.
Are you using any of the accessibility features? Go Settings - Accessibility. Make sure the choices are all set to off.
Press the Switch Keyboard button. Press Set up input methods.
Be sure it shows your correct language, turn Auto capitalization to off. Turn auto correction to off.
Triple check your screen is really really clean and smooth to the touch.
Jul 09, 2014 | Nook HD+
I went to the seceret setting screen on my nook hd and turned on demo mode and now i cant turn it off
access Settings > Device Information and tap above the volume bar while holding Volume + button, a menu pops up...unchecked "Enable Demo Mode". Turn off the Nook, turn it back on, demo mode should be off now.
-DO NOT- try and verify if demo mode is off before rebooting the device.
If all else fails, bring it in to your local B&N and seek the Nook specialist out. They should be able to turn it off for you.
Good Luck! :-)
Mar 24, 2014 | Barnes & Noble Nook
How do i change the password on my nook
Recover a Nook Password
Nook users can enable a pass code to prevent unwanted access to the device.
If you forget your device pass code, you won't be able to recover it.
You can reset your pass code and create a new one by using your Barnes & Noble account credentials.
Attempt to input your pass code three times.
Once you have failed to unlock the Nook three times, you will be prompted to "Start Over" or "Disable pass code using account credentials."
Tap "Disable pass code using account credentials" in the menu.
Enter your Barnes & Noble email address and password.
Tap "Submit" to disable the pass-code protection.
Enable New Pass Code
Tap the Home button and select "Settings" from the icon menu. Tap "Device."
Tap "Enable Pass Code" from the menu that appears.
Enter a unique alphanumeric pass code, then confirm it in the text-entry fields.
http://www.barnesandnoble.com/nook/support/
Jul 31, 2013 | Computers & Internet
I can't get my nook to work it keeps wanting a password and i don't have one
If you haven't already set up a Nook account,you should. It's easy to do, but you have to have acredit or debt card to do so.
Feb 25, 2012 | Barnes & Noble Nook
My samsung Galaxy phone stolen how i can look it online or stop it service
Hi, your phone IMEI is a number which is unique to every GSM mobile phone. It is usually found printed on or underneath the phone's battery and warranty card. IMEI of any set can also be found by dialing the sequence *#06# into the phone. The IMEI number is used by the GSM network to identify valid devices and therefore can be used to stop a stolen phone from accessing the network.
For example, if a mobile phone is stolen, the owner can call Authorities (service provider) and instruct them to "block" the phone using its IMEI number. This renders the phone useless, regardless of whether the phone's SIM is changed.
Jul 01, 2011 | Samsung Cell Phones
Nook hooked up for billing nut nook states it does not have a billing address
make sure that the billing address is the same as the credit card's billing address, I believe that it does not except any address outside the USA territories or canada. I would log into the B&N website and go under account settings to payment settings and edit the info, if anything add the same card again, i had that issue and it worked after i did that. Hope that helps!
Feb 22, 2011 | Barnes & Noble Nook
What does the error code c7713 on my Nook refer to? How can i fix this?
When I called Barnes and Noble, they said it meants it was registered under another user. Is cases like mine (that you thief on Craigslist), it can also mean that the Nook was stolen and cannot be restored. Call cutomer service though, because as long as it is not blacklisted, they may be able to work with you.
Feb 15, 2011 | Barnes & Noble Nook
Unable to get NOOK to work with Linksys WRT54GS
To log into your WRT54G, open a Web browser on a computer that's connected to your router and go to http://192.168.1.1/ - the default username is admin and the default password is blank (leave the field empty).
In the Setup tab, Basic Setup subtab:
DHCP Server should be set to Enable.
If you had to change this setting, be sure to click the Save Settings button.
In the Wireless tab, Basic Wireless Settings subtab:
The first data item is Wireless Network Mode. For reasonable performance, this should be set to either Mixed or G-Only. You should be able to connect your NOOK even if it's set to B-Only, but that would be a very unusual setting and would give slower networking.
Wireless Network Name (SSID) is the name of your Wi-Fi network. If it still says 'linksys', change it to something different-but be aware that you'll need to reconnect all of your current Wi-Fi devices using the new SSID. That's a pain in the behind, but using the default SSID will cause you lots of connection grief if someone else installs a Wi-Fi router with the default SSID, because your devices won't be able to tell them apart. Write down your SSID, being careful to distinguish capital letters from small letters, so you'll know what it is.
Wireless SSID Broadcast should be set to Enable. Otherwise, your NOOK won't see your network. You could type in your SSID, but that's a pain in the behind that you don't need. There's no reason not to enable SSID broadcast.
If you had to make any changes to these settings, be sure to click the Save Settings button.
In the Wireless tab, Wireless Security subtab:
Security Mode: write down which of the choices is selected:
  • Disable
  • WPA Pre-Shared Key
  • WPA RADIUS
  • RADIUS
  • WEP
I say to write this down just in case you run into more trouble and need to ask someone for help.
If 'Disable' is selected: you have no security on your Wi-Fi. Anyone can use your Internet connection, and anyone can listen in if they're in range. If you send unencrypted passwords, email, etc., they could see what you send. Most public Wi-Fi systems (McDonald's, Starbucks, B&N, etc.) have no security.
If either 'RADIUS' choice is selected: these settings are used for large organizations with stringent security requirements and a dedicated authentication server. Your NOOK cannot connect if either of these settings is used. You almost certainly don't want to be using either of these for a home system.
If the 'WPA Pre-Shared Key' choice is selected: WPA offers good security for Wi-Fi and is the best of these choices for home use.
  • WPA Algorithms should be set to TKIP. This is the normal setting for WPA. I don't know if your NOOK will connect if you set it to AES, which is normally used with WPA2 rather than WPA.
  • WPA Shared Key is the access key for your network. Write it down, being careful to distinguish capital letters and small letters. You'll definitely need this key in order to connect your NOOK or any other Wi-Fi device to your router. Don't change this unless you're prepared to go back and reconnect your other Wi-Fi devices. Unfortunately, there are some punctuation marks that you can't enter on the NOOK keyboard, and if your WPA passphrase contains one of those you may need to change the passphrase in order to connect your NOOK.
If 'WEP' is selected: the WEP security system is a weak system, easily cracked by knowledgeable hackers. However, many older wireless devices and some of the cheapest new wireless devices can't handle anything better than WEP. This isn't a good situation, but you work with what you've got.
  • Default Transmit Key should be set to 1.
  • Passphrase is not important. It is not your network's access key. Ignore it.
  • Key 1 is the access key for your network. Write it down. It will be either 10 or 26 characters, containing only the numbers 0-9 and the letters A-F. You will definitely need this key in order to connect your NOOK or any other Wi-Fi device to your router. There's no reason to change this, and if you do change it you'll have to go back and reconnect your other Wi-Fi devices.
If you had to make any changes to these settings, be sure to click the Save Settings button. Any changes in this section will also require that your existing Wi-Fi devices be reconnected.
In the Wireless tab, Wireless MAC Filter subtab:
  • Wireless MAC Filter should be set to Disable. If it's enabled and set to Permit only mode, only the devices listed on the MAC Filter List can use your Wi-Fi. If your NOOK isn't in the list, you can't connect your NOOK. Bad ju-ju, huh?
If you had to change this setting, be sure to click the Save Settings button. Changing this should not require your current Wi-Fi devices to reconnect.
It's possible to add your NOOK to the MAC Filtering list and then turn MAC Filtering back on. But that's beyond the scope of this posting. I will, however, mention that your NOOK's MAC address is listed in its Settings screen-on page 2 if it's a NOOK 3G.
In the Wireless tab, Advanced Wireless Settings subtab:
  • Authentication Type should be set to Auto. Do not set it to 'Shared Key'; this won't work with NOOK. Auto should work with any WEP-capable devices. If it's set to 'Shared Key', change it to 'Auto'-this shouldn't affect any of your current Wi-Fi devices.
You should now be able to connect your NOOK using the SSID and the access key that you wrote down.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 29, 2010 | Linksys Wireless-G WRT54G Router
My mobile 2600 classic is stolen so how can i get my mobile
I think it is very hard nowadays to recover stolen or lost phones, but one thing you can do is block your phone so that the person who stole it cannot use the phone. All you have to do is call the phone provider. They will get some basic info and the IMEI number of your lost mobile set. They will register IMEI (International Mobile Equipment Identity) of your cell phone and will request all the mobile operators to block this IMEI on their networks.
stop a stolen phone from accessing the network. For example, if a mobile phone is
stolen, the owner can call his/her network provider and instruct them to "block" the
Nov 24, 2010 | Nokia 2600 Classic Cell Phone
NOOK is not capable of responding to the Linksys router
The tech was correct about that matter. However you can configure the MAC to always allow the device.
  1. Find your MAC for NOOK. I think you have already did.
  2. Go to Setting and then to the Second Page to find it.
  • Configuring MAC
  • Wireless MAC Filter. To filter wireless users by MAC Address, either permitting or blocking access, click Enable.
  • If you do not wish to filter users by MAC Address, select Disable.
  • Prevent. Clicking this button will block wireless access by MAC Address.
  • Permit Only. Clicking this button will allow wireless access by MAC Address.
  • Edit MAC Address Filter List. Clicking this button will open the MAC Address Filter List. On this screen, you can list users, by MAC Address, to whom you wish to provide or block access. For easy reference, click the Wireless
  • Client MAC List button to display a list of network users by MAC Address.
  • Change these settings as described here and click the Save Settings button to apply your changes or Cancel Changes to cancel your changes.
Please rate the answer as well. Feel free to contact if you have any other problems or if this solution didn't solve the issue.
Thanks for contacting Fixya!
Jul 08, 2010 | Linksys Wireless-G WRT54G Router
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
