Question about Minn Kota Boating
My Minn Kota deck hand 25 has no power on the lift.It seems to be working very hard and will pop the breaker but will release the anchor OK.
3 Suggested Answers
SOURCE: have a 3 hp. minn kota, prop wont turn, hard to
I have the same trolling motor and the same problem.
It seems the factory grease gets hard inside the motor where the shaft spins and acts like glue. I removed the long screws, carefully pulled the case apart, cleaned out the old grease (which was more like hard plastic) and packed the bearing area with lithium grease. I also lubricated the "O" rings and they were not damaged or brittle so I re-used them and put the unit back together being careful to tighten the screws properly. I have had no problems since. Also be sure to check the connections to the battery, for some reason that motor is very sensitive and wants a really good connection to the battery posts and sometimes all you need to do is re-tighten the connection if the motor does not run at all.
By the way, I contacted Minn Kota regarding the 3Hp and was told "hp" stands for high performance and the motor is not 3 Horsepower.
Posted on Apr 02, 2010
  • 3289 Answers
SOURCE: My minn Kota deackhand 35 won't lift a 28lb anchor
How heavy is the line that is attached to the anchor - you need to add that weight to the amount being lifted as well. Some general things to consider: Are you providing the correct voltage and current? Is the wire supplying the motor large enough - or is it getting hot? Check & clean as needed ALL connections at terminals, relays, etc for corrosion and tightness. Make sure the unit has been serviced and lubricated as required.
Posted on Sep 29, 2015
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Sep 29, 2015 | Minn Kota Boating
    Anchor will not go down but will go up
    I have two deckhand anchor units. I ve tested both on battery, and both went up. I replaced switches, and I get nothing, but I heard a light click coming from unit. Is the motor bad?
    Nov 09, 2010 | Minn Kota Deckhand Electric Anchor Lifts...
    Anchor pulls up won't release to go down on either of the two switches
    Im getting power to motor, but can't get it go down. When I hit switch I can hear a clicking sound from the unit
    Nov 05, 2010 | Minn Kota Deckhand Electric Anchor Lifts...
    I have a Minn Kota Deck Hand Ser. No. MK01798492 I can not find a modle # on it. It came on the boat i bought used. it did work now it will not let the ancor down. I took the cover off, found a spring off...
    39 2372700 COIL SPRING ??
    DeckHand 40, 12 Volt, 25 to 40 Pound Capacity, 2377106 - 2004,2005,2006,2007,2008,2009,2010,2011,2012,2013,2014,2015,2016,2017
    DeckHand 40 - parts diagram
    Aug 07, 2017 | Minn Kota Boating
    Have a 3 hp. minn kota, prop wont turn, hard to
    Jan 19, 2010 | Minn Kota Boating
    Boating Logo
    27 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
