Question about Kitchen Appliances - Others
Need water container for my hometouch steamer, lost during move. How much?
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Hoover steamvan cleaner F5807
If this has a duct part #38661003 (#3) that is supposed to be installed in front of the tank isn't there, then you will have no suction to pick up the dirty water.
If this doesn't use a duct, then either the foam filter (#2) is up all of the way, need to leave 1/4 in. gap from the top, or the rear of the tank lid is not locked down.
Posted on Jan 22, 2008
SOURCE: water left in steamer - need to clean clear tank
I'm willing to try this to clean the mold out of the steamer container and possibly the rest of the attachments:
1. Empty the water reservoir completely. 2. Place 20 mL of CLR or bleach into the reservoir. 3. Fill the reservoir with hot water. 4. Shake the reservoir to mix and let stand for about 1 hour. 5. Empty the reservoir completely. 6. Rinse the reservoir 3 or 4 times with cold water. 7. Fill the reservoir with distilled water. 8. Run the steamer into the ventilated air a couple of times to ensure that there is no CLR or bleach residue on the evaporation elements. Thus, there will be no bleach on your cloths.
I have the same problem and will try this out tomorrow. I will tell you how it turns out.
Posted on Aug 07, 2009
digritz
  • 530 Answers
SOURCE: Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=32173
Posted on Sep 05, 2009
My shark steamer is foaming and no steam is coming out
You cant put soap in the steamers, only water. Clean out water container and start new. Also, clean hole where steam comes out with something thin. Make sure it is heating up enough to produce steam, otherwise heat assembly is broken.
Mar 08, 2017 | Shark Vacuums
Hi There,i need to know,my russel hopps steamer is making a beep sound the whole time. what am i doing wrong? the sound is very annoying
Hi, ok I also had that problem whereby the steamer keeps on beeping. It's a warning alarm. we need to fill the steamer with water directly into the reservoir and NOT into the side. the side is only for top up during the steaming process.
Hope this helps.
Sep 27, 2011 | Russell Hobbs RHST3 Rice Cooker
DRIPS DURING STEAM PROCESS
Be sure no hairline cracks or pinhole in the steamer water container.
Put enough water level on it and not overfill it.
Repair hairline cracks or pinhole by applying epoxy or super glue in the surface.
Good luck.
Jun 28, 2011 | Rowenta Irons
HINARI STEAM SUPREME STEAMER MODEL ST326C i HAVE LOST THE THING THAT FITS IN THE BOTTOM OF THE STEAMER WHICH MAKES IT STEAM IN 45 SECONDS. WHERE CAN I GET A NEW ONE
Can anyone tell me how to get a replacement for the removable bottom of one of my steamer tiers? I lost it when I moved house.
Sincerely Jo Vernon mary.vernon1@ntlworld.com
Jan 28, 2010 | Kitchen Appliances - Others
Starbucks sirena won't heat up; blue light flashing-brand new
johnshami had this solution on another post, and it worked for us:
  1. make sure the water in the tank is stone cold -- which is a no brainer since it will not heat h2o unless it's primed.
  2. take off steamer wand cover, turn the steamer knob clockwise till pump starts.
  3. then s*ck (as you would on a straw, with your lips sealed around the end of the steamer wand) the tip of the end of the metal tip hard until pump stops
  4. may need to do it a couple of times. yes this seems crazy, but it works! you are flushing out the vapor lock in the pump.
Sep 27, 2009 | Saeco Starbucks Sirena Espresso Machine
Water left in steamer - need to clean clear tank
Mar 14, 2009 | Rowenta Compact Steamer - White
Rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Jul 22, 2008 | Rowenta Commercial Garment Steamer - White
Hintari steamer instructios
you need a steamer basket or "fold out fan looking tray" it needs to sit Off the bottom of the cooker, try 1 cup water 1st , it will depend on what your steaming, so check food after 4- min
Feb 28, 2008 | Kitchen Appliances - Others
Lost my instructions.. How do I steam actual veggies?
  • The water level as long do not overflow is ok. Ensure water do touches the centre of the element.It's important to ensure there is sufficent water in the base of the steamer by visually viewing the transparent water level gauage.You can top up water on the either side handle.Turn the timer on if you think that the food will cook at 20 min or so.A receipes will help and tell you to set the exact min for cooking.
Regards
Alan
Feb 01, 2008 | Tefal 61621 Steam Cuisine 2-Cup Rice...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
