Question about Garden
I have my fathers model DD79 Reliant Sandfer . I believe the motor has quit . I am looking for a manual to see how I can disengage the spindle and pulley to remove the motor.
  • 10865 Answers
SOURCE: What size a step pulley required for the motor ?
rpm_chart.jpg?t=1236890602
here is the chart you need to answer your question. please mark this as a fixya! thanks
Posted on Mar 12, 2009
  • 384 Answers
SOURCE: I have a 20 year old table saw of unknown
Simple, there are two options:
1) buy a new pulley from any hardware or home improvement store.
2) If threads are stripped from pulley, either retap with next larger size tap, or redrill new hole and tap with same size as the current size. Note the best way to keep pulley on is to have a set screw over the key and another at 90 degrees from keyway. Note 2 - Are you sure current pulley does have two set screws?
Posted on Jun 26, 2009
SOURCE: Ingersoll Rand SSR-EP75 owners manual, I need to
The pulley is held on by a compression type of coupling. Loosen all the screws in the coupling. Remove two screws and they should thread into two or more threaded holes in the coupling. These are holes that should be 180 degrees apart....they will be the only holes threaded. If all the other bolts in the circumference are loose you should be able to thread these two bolts into the coupling and the bolts actually "jack" the coupling apart. The coupling and fan should easily come off the front of the motor. The motor should be held on by 4 screws to the motor tower in front of your air/oil cooler.
Posted on Sep 04, 2009
Testimonial: "Although the information is way late, it is accurate information"
  • 65 Answers
SOURCE: disc will not spin...removed motor spindle
to give more details please.
Posted on Feb 16, 2010
SOURCE: reliant owners manual
mikebo732. I own a jointer same number and all as yours. I also need a manual. Can you call me or email. 573/422/3333 mweidi01@hotmail.com Mark Weidinger
Posted on Mar 31, 2010
Hi, I am looking for a manual for a Bush SRP 52 record player as the turntable won't turn when I switch it on. I want to find out what the problem is.
It's not a belt drive turntable. It's an Idler drive. A mains powered motor spins a brass spindle, this presses on a rubber wheel which pushes against the platter on the inside. If you can hear the motor running when put in play mode the chances are that the rubber tyre is no longer touching the rim of the platter. It might be possible to get a tyre for it. There are some shops that specialise in these old type turntables. If you don't hear the motor running then either the power supply to the motor has failed or that a micro switch is either not getting pressed upon or is broken. Taking the base off the deck will show the underside revealing the workings. The platter is held on by a horse shoe clip, located on the centre spindle. It might be hidden under a silver plastic thing. You have to get that off to get to the clip.
Mar 01, 2015 | Drive Audio Players & Recorders
Blade does not stop spinning when lever disengaged.
Under seat of tractor theres a plate that says model # it looks like 917. 000000 i need that # please and i can help you with the problem it sounds like the belt isnt disengaging which will cause blades to continue to go.
Jun 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My mower will die everytime i engage the blades to mow
Check to see if one of your deck spindles isn't seized. Disengage the blades and turn each blade to see if its free. Sounds like either a spindle is seized or your electric clutch on the motor has a problem.
Jul 20, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
Need manual for reliant electric nailer model DK-11
I have a manual that I can PDF and post somewhere. I would like to know where to get parts. I need the internal hammer. The old one is bent and there is not way to straighten it out. I have several Air hailers but I like my old reliant. It's quick and easy to use away from the shop.
Jan 13, 2012 | Air Tools & Compressors
I plugged in my machine after it had been sitting idle for about a year. I have power and can hear the motor turning, but the needle doesn't move. It acts like a 'clutch' has been disengaged....
does sound like machine is in bobbin winding mode. The clutch may be disengaged by an inner wheel on the flywheel, flicking the bobbin spindle over or a button.
Best thing is to check the manual for your machine as they all vary. Go to http://www.singerco.com/accessories/instruction-manuals/search
then type in the model number with a w in front and click search.
The White and Singer manuals are listed here and many are free downloads as pdfs.
I hope this helps you out.
May 30, 2011 | White Sewing 2037 Mechanical Sewing...
I have a wide belt sander that was made by Sunhill Machinery. I bought it used and it has has a digital controller. The manual does not give any instructions on how to use the controller and I have also...
I have a Reliant 6" belt/disk sander
Reliant dd79 3/4 hp, which is suppose to rise to a vertical position.
I need a manual for this.
e-mail delhotel@comcast.net
Jan 07, 2011 | Sunhill Machinery Sunhill Spiral...
I have a 2002 hyundai sonata that makes a clicking noise when you turn the wheel, I was told the front axles might need changing and if so what procedures need to be taken to do this repair?
Determine which axle is bad. Usually pretty obvious, the one that the rubber boot is ripped open. Remove wheel, outer tie rod end from spindle, lower ball joint from spindle, pry down with long heavy bar on lower control arm to disengage ball joint stud, Large nut from end of axle. Pull spindle away from car to get axle out of spindle. Carefully pry between axle and transmission to disengage axle.
Sep 27, 2009 | Hyundai Sonata Cars & Trucks
My 80 year old father has the CDR 4060 but can't find the manual for it. I need to know how to rewind it to look @ a break in @ his house. Can you tell me how to rewind and play
I believe that the commands are the exact same as using the model 4010.... here is the users manual for teh dvr-4010. See if that helps, if it does, please rate this answer.... :)
Thank you for using fix ya! :)
http://www.retrevo.com/d/ds/progress?doc=4e791b95ba11afe50e14194403e8eeb9
Sep 24, 2009 | Clover Corporation CDR-4060 Video Recorder
Reliant owners manual
I have one and can scan it and send it to you if you still need it.
Jun 17, 2009 | Masonry Tools
Error code 59.c0 in HPLaserjet 5550
This means a printer motor error has occured. From the service manual: C developing disengaging motor rotation error.
To fix:
Developing disengaging motor
error
1 Reconnect the connectors J16 for the developing disengaging motor and J1100 for the DC controller PCB.
2 Replace the developing disengaging drive assembly.
3 Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
So, at the very least you'll need the developing disengaging drive assembly and, if that doesn't fix it, then you'll need the DC controller board. My bet is the DC controller has failed.
Sorry for the bad news, but please rate this solution as fixya even if it wasn't what you wanted to hear. Thanks.
Jan 10, 2009 | Office Equipment & Supplies
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
