Question about JVC Audio Players & Recorders
How do i pair the subwoofer and the sound bar( bkuetooth) on the JVC TH-BY970
SOURCE: JVC TH M505 Subwoofer not working
i need to find the wire that connects from the subwoofer it has like little spikes inside the medal part and the spikes broke off
Posted on Apr 10, 2008
SOURCE: jvc th-c6 subwoofer won't turn on
Check the little prongs inside of the cord, they are very fragile and if they get pushed in wrong, bent and broken off - you would never see one on the floor. These should all be straight and be able to make contact. Hope this helps!
Posted on Mar 16, 2009
etirbynnor
  • 655 Answers
SOURCE: Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
Posted on Jun 06, 2009
  • 65 Answers
SOURCE: i have a JVC, Home Theater system. It is a TH-C30.
I think there may be a possible chord disconnected or the fuse may be bad!
Posted on Apr 26, 2010
  • 8 Answers
SOURCE: I have a jvc th-m606 receiver and I don't have a subwoofer for it, is there a different way for me to get audio output or a different subwoofer I can use?
You would have to make a cable that goes from the 8 pin mini din of the jvc unit to each individual speaker. A wiring diagram can be found online each pin on your 8 pin goes to a speaker , and one is for power. Find a wiring diagram and find a cheap electric store that can make the cable for you. I had the same problem...
Posted on Aug 12, 2012
Why? Jvc sound bar turning in by itself, no one turned it on, three mornings in a row , turned on radio automatically???
It sounds that you have accidently set up an alarm setting that is set to wake you up in the morning!
Look in the manual and see what it says about timer settings.
Aug 21, 2016 | JVC TH-BA1 Soundbar System with Wireless...
The sound bar suddenly stopped pairing with the subwoofer. The only sound is coming from the bar
I suggest turning off and unplugging everything from the power, then disconnect everything from each other. See if you can get it to pair again. Otherwise, please give more details on which model sound bar and subwoofer.
Thank you.
Feb 28, 2016 | Audio Players & Recorders
Subwoofer not working.
Most likely, the "remote" wire to the subwoofer amplifier has come off or is not making good connection.
May 15, 2015 | JVC TH-BA1 Soundbar System with Wireless...
How to pair my soundbar and wireless lg soundbar
Press and hold the reset button on the back of the subwoofer until the light on the front starts blinking. Then with the soundbar turned on, press the stop button on the soundbar and the mute button on the remote at the same time. The display should say "REMATE". The sub light should stop blinking then and should be linked.
Feb 03, 2013 | LG Lsb316 Sound Bar With Wireless...
Pairing my lsb316 sound bar and subwoofer
There is a button on the back of the sub that you need to press to complete the pairing..the led will be green when paired successfully or red if it is in standby mode
My 210 visio sound bar keeps losing volume then come back on then goes back off
You will need to take the following steps to ensure that the Vizio wireless subwoofer is working properly:1) You will want to make sure that the subwoofer is in the line of sight of the Vizio sound bar.
2) Ensure the Vizio wireless subwoofer is not beyond 60 ft. away from the sound bar.3) Unplug both the Vizio sound bar and the Vizio wireless subwoofer for 30 seconds and then plug back in.4) Try re-pairing the devices. Pairing works best when you have the devices facing each other about a foot apart during initial pairing, once they are paired you can move them to your desired location.
Sep 12, 2011 | Televison & Video
Jan 12, 2008 | JVC TH-M505 System
Subwoofer shuts down
Check the connection in the back of the sub,where your wire plugs in from the DVD unit, the connector is loose in the unit itself. Had mine replaced and is doing the same thing again
Nov 24, 2007 | JVC TH-M505 System
23 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
