Question about The Office Equipment & Supplies
The thermostat has power and is not working with e 1 code how do we fix?
Ricoh Copier Model MPC5000...SC code 582
The IH coil has a thermostat mounted in the center. If the thermostat open you will get SC 582 on power up. Even with a new IH coil, pressing the black center of the thermostat will cause it to open. Check CN 982 pin 1 to 2 for continuity to the thermostat. If pin 1 to 2 is open, the thermostat is open. Try jumping pin 1 to pin 2. If this allows the machine to power up, the thermostat is open. Order another IH coil, check the thermostat with your meter before installing, and be careful not to press the center of the thermostat while installing it. Due to the cost of the IH coil, you might try to find proper value Thermostat or thermofuse to fit it.
Nov 17, 2017 | Ricoh Office Equipment & Supplies
How do i fix the error code 6000 in kyocera 3060?
C6000 : Fuser heater break.
Fuser thermistor 1 detected less than
40°C/104°F for 10 s during warm-up and ready in.
Defective fuser heater M or S.
-Replace the fuser heater M or S.
Installation defectiveness on fuser thermistor 1.
-Check the mounting state of the fuser thermistor 1. If any problem is found, repair it.
Defective fuser thermostat.
-Replace the fuser thermostat.
Defective PWB.
-Replace the power source PWB or engine PWB and check for correct operation.
After parts replacement (fusing unit), you need to clear the fuser error code by going in the tech mode (10871087) and then U163.
Dec 19, 2015 | Kyocera Office Equipment & Supplies
Fifth wheel air conditioner has error code E1 on thermostat, how do i fix?
Somewhere in your manual you should have a table telling your what the codes mean. I have no idea. Once you find out I can most likely direct you in how to fix it.
Sep 02, 2014 | Dometic Rooftop RV Air Conditioner
Replacing double pole 220 v with honewell ct410a two wire120/140v wiring diagram not clear
1 power wire (120v) will go to the thermostat and 1 power wire (120v) will go directly to the unit. The other wire on the unit will go to the other side of the thermostat. The safety precaution behind using a single pole to replace a double pole contactor is that you will always have 1 leg of power going to the unit. Many systems are designed like this from the factory, but it is always better to have a 2 pole to cut all power off to the unit unless it's in operation. The unit will still not work as long as it does not have both legs of power.
L1 to Thermostat T1 to Unit
L2 and T2 wired together.
This is only for 240v systems. 120v Will have 1 common and 1 power, therefore you will need to know which wire is which. Power to thermostat, common wired direct.
Nov 26, 2013 | Honeywell Programmable Thermostat Heater
F-35-4 this code is displayed the machine is not working
If this unit is Konica your problem is under fusing problem. Clean first fusing unit and check the temperature sensor and thermostat could be dirty. reset under 25 mode "hold 2&5 while turn power on, select SW adjust 3-2-0 up to 3-7 set all to 0 then back, try off and on power. if don't work check 3 component 1. lamp. 2. temp sensor 3. thermostat if broken or busted replace it. but still use reset procedure.
Feb 18, 2012 | Office Equipment & Supplies
My check engine light is on, and today my temperature gauge stopped working and we have replaced the engine coolant sensor and the connector and temperature gauge still not working. PLEASE HELP
Could be the thermostat. I know nothing about cars but I noticed my 2000 Grand Prix temp gauge was not going to the normal level. My wife drives this car so I didn't notice it for a month or so. Eventually the Engine light came on. Took it to Autozone and the code came back as P0180... (1) low coolant (2) bad thermostat (3) enginge fuel temp sensor. They used a code reader that was about the size of an Ipod nano.
Coolant was okay, so took it to my mechanic. His netbook sized computer showed it was the Thermostat. He reset the codes and the temp guage went back to normal. Was short on $40 for the fix at the time, so I parked the car and promised to bring it back in 3 days. Went out and checked the car a day later at 25 degrees outside without starting the car... gauge still sitting at the normal level. No question it's the thermostat. That car will not be driven again until T.stat is fixed in 2 days.
Oct 18, 2010 | 2004 Pontiac Grand Prix
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
if that doesnt help you.....
the problem IS NOT necessarily a blocked drain hose or the drain pump it could be the thermostat micro switch!!! the thermostat is located at the rear of the right bottom side of the dishwasher(held by oval nylon plastic housing). Turn the machine off. remove the right side panel.(remove top {2screws in lid at back}, remove right panel screws {2 behind door, 3 bottom back panel, 2 behind panel below door {pull panel out from top [no screws pushes in & out of place]}. Locate oval nylon/plastic shape located as above - micro-switch is in the middle (3 wire connectors in 1 block) thermostat is 2 connectors ( 1 each side of micro-switch). use screwdriver to push thermostat back into the nylon housing on both sides (it has worked its way out a bit over time and stops the micro-switch working). Reassemble and dishwasher starts to work again!!!!
Aug 28, 2010 | Dishwashers
Nee help programmable thermostat wont turn on heat. works air just fine. I have four wire system Original white went to "O" green to "G" to "Rc" and Yello to "Y" I have tried multiple combinations....
The usual color code for thermostats are as follows:
Red (R) = Power
White (W) = Heat
Yellow (Y) = A/C
Green (G) = Fan/Blower Motor
That is for a standard 1 heat 1 cool thermostat. The other colors that you have described are usually for a heatpump system in which you have more than four wires. Depending on the furnace model, you can sometimes see the wires that go to a circuit board that are also mark with the same color codes. If so, then you just have to make sure that the w on the board is the same color has the w on the thermostat and etc. Hope this helps.
Oct 25, 2009 | Hunter Fan Company 5/1/1 Programmable...
Error Message on copier.
Probably a thermistor problem, dirty or out of position or failed. Could be thermostat too.You will want to check that fuser out first before you reset any codes. Checking for paper, sensors, etc...
If all is clear in the fuser then:
With the power off, hold the 2 and 5 button on the panel and turn the power on. In the display you will see, there are 1-12 choices, choose 1, Software SW. You will see a display of numbers (01-0:1 03). Change the first number to 03, change the second number to 01, change the third number to 00. Press RETURN on the display. Power the unit off, then on. Codes should be reset.
If after resetting the code and powering up machine -- if code comes back then replace the above mentioned.
Jan 23, 2009 | Office Equipment & Supplies
Ricoh aficio 1022 all-in-one error code sc542
Fusing temperature warm-up error
The fusing temperature does not reach
the standby temperature within 20
seconds after the main switch is turned
• Fusing thermistor defective or out of
• Fusing lamp open
• Fusing thermostat open
• Power supply board defective
• Poor connection of the fusing unit
It could need a new thermistor
Sep 01, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
