Question about Jamo Audio Players & Recorders
Im going to buy a hi Fi ive got 2 jamo 365 and have blue tooth tv sound bar with woofer what is the best but cheapest steroe i can get and were from. thanks
    Top Expert:
  • Jamo Master
  • 23,639 Answers
Look on fleabay.
eBayeBay
or Gumtree http://www.gumtree.com/
Posted on May 20, 2017
USING SOUND BAR FOR BLOWN SPEAKER ON TV
If you use Blue Tooth, wires are not needed.
Press the manual Mode button to find blue tooth mode. Green light will display. Blue Tooth is a general signal sent out. There is no specific setting for TV.
If your TV is sending out a Blue Tooth signal, it should find the speaker automatically. http://www.ematic.us/sites/default/files/ESB212_Manual_01_0.pdf
Check your TV's Blue Tooth settings and have it scan. Default password/code for the sound bar is 0000.
Also check your remote batteries. Sometimes they are installed backwards by the factory so they won't go dead.
Mar 22, 2016 | Ematic ESB212 Wireless SoundBar with...
What must I do to connect a sound bar to my tv ?
Before you buy a sound bar look on the back of your TV to see if there is a digital port and /or a fiber optic port. The fiber port may have a cover on it so the red laser won't cause eye damage. If your TV is so equipped, then get a sound bar with a fiber optic connection. Not many older TV's , flat screen or nor have blue tooth capability. Unless you know for sure your TV does, don't expect the sound bar to have it too.
Nov 09, 2015 | Insignia Televison & Video
Can I connect to Vizio TV with blue tooth
If your ear buds have been connected to any device before your TV then it won't work. If you want to connect it to your TV you turn on your headphones, hold the call button for 3 seconds, and you will see ur light flash and connect it to your TV. If this didn't help then go to the manual and check how to connect your headphones to your TV.
May 24, 2014 | AUVIO Bluetooth Headphones
Activate bluetooth on stealth g2
Hi Ali.. as far as i know and im pretty sure of this.. trio stealth aka Mach etc.. only has wi fi..no blue tooth. Here is a link with more info
for u.
http://youtu.be/mK-AGDPtoNU
Good luck
Chad man
Oct 26, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Need to replace 5.5" woofer in Jamo S426 floorstanding speaker
contact maplin electronics they are really good at replacement units.
Jun 30, 2012 | Jamo S426HCS3 5pcs Home Theater Speaker...
Have new lap top [toshiba satellite] have connected tomtomgo 520 twice and on both occasions my wi fi connection has been disabled
Built-in FM Transmitter to transmit sound over own car stereo and lets not forget Best hands-free calling> Best guess is that your computer is finding and trying to connect to the blue tooth connection since Toshiba has blue tooth capabilities, also you could be losing the wifi signal just because the FM transmitter is overpowering the the wifi signal. If i had to guess though i would go for the blue tooth connection as being the problem. Hope this helps
Apr 26, 2010 | Tomtom GO 520 GPS Receiver
I own jamo speakers CL 30. One of the woofers is broken. Can i find anywhere one woofer to replace it?
Best to have it reconed ! The speakers need to be matched pair.
If you are using these for music instrument(s) make sure they are intended for that use. Home stereo speakers won;t take the power that music instrument speakers are designed for by a factor of say four.
If these are mis-applied, don't waste money repairing, but buy instrument grade cabinets.
Dec 26, 2009 | Music
Hi, Ive tried to set up my samsung blue ray
It seems as though the HT works fine, so to get the TV itself to play through the HT setup, take the audio out from the TV and hook it up to a separate channel on the HT receiver. Turn on TV and receiver and put the receiver on the respective channel of the receiver. I hope this helps.
Oct 26, 2009 | Samsung Audio Players & Recorders
Help how to best connect sky hd and PS3 to a Jamo
you will have to use a component cable or optical lead from your ps3 to the jamo and sky hd to be connected via scart.
for best image,buy an HDMI CONNECTORS switch that will allow you to run many HDMI TO IT and from the switch you only need one to the tv so the jamo still output to the tv.
remember that you will have to get an automatic one so that it can select when you are using each element.
Mar 04, 2009 | Jamo DMR 60 DVD Player/Receiver
19 people viewed this question
Top Jamo Audio Players & Recorders Experts
Electro Med Services...
Tom Chichester
Steve
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
