Question about Reebok Exercise & Fitness
Reebok GT40S treadmill will turn on but then just gives a continuous beeping sound and the display flashes. Can't appear to do anything with it but turn it off again to stop the noise.
  • 351 Answers
SOURCE: Top drawer not working
sometimes if the heater is faulty only one drawer will work and the other drawer will flash f1
Posted on Mar 03, 2008
  • 901 Answers
SOURCE: My ADP 8342 continually sounds 10 beeps, stops the...
Refer the user guide for the error message meaning. Contact service provider.
Before that make sure that the water supply to the inlet is having free flow.
Posted on May 24, 2010
  • 327 Answers
SOURCE: My oven has code Fo displayed. It began with a
Hello, I had the same FO error. It turned out that the ribbon cable from the front panel was not making good contact where it mated with the circuit board. Remove ribbon cable and clean contacts on ribbon cable. Replace cable and problem should resolve.
Thanks
Posted on Jul 14, 2010
AJIN G
  • 6694 Answers
SOURCE: I've purchased a reebok gt40s treadmill it keeps on beeping when the safety key is taken of, very annoying I need to switch it of from the mains every time I use it. Is this normal?
Its normal. Indicating safety key is displaced.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Jan 10, 2017
AJIN G
  • 6694 Answers
SOURCE: Treadmill Reebok ZR9 When machine is switched on display flashes and makes a beeping noise
If you wish to get some details about treadmill repair and service ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Feb 06, 2017
Feb 06, 2017 | Reebok Exercise & Fitness
Horizon Treadmill Ct5.1 turns on, displays nothing and beeps nonstop
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
Nov 26, 2016 | Horizon Exercise & Fitness
When turn it on just beeping noise
reset the treadmill. follow this steps and fix it. God bless you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 23, 2013 | Reebok Exercise & Fitness
Reebok RB1 display fades
Run the software calibration for easy troubleshooting, and fix it.
However adjust the REED switch, clean it, and tight all plug or connector very well.
Please read you instr. manual or download from
www.iconservice.com
God bless you
Nov 24, 2012 | Exercise & Fitness
My Reebok S 9.80 will turn on but when I push any button on the console it just beeps and does not respond. What does that mean?
yes - had to recalibrate it. Plug it in, remove the key, hold down speed + and the stop button on the console, while holding them down replace the key. release the buttons, then press stop once. then press and hold speed + until speed reaches max. unit should run and speed up to max. console should display max speed (s9.80 should read 11.8 to 12.5). It took me a couple of tries to get running but now it is OK. If after several tries the unit does not run then the console will probably need to be replaced ($410) - so get a new treadmill ! If unit does run then it may still beep. Problem is with the IFit card. You can get rid of the beeping by opening the console (unplug the treadmill first) and removing the cable that connects the IFit card to the mother board. Of course the IFit will not work but it will not be beeping at you. good luck
Nov 21, 2010 | Reebok T 980 Treadmill
E1 Error Message on Reebok Cross Trainer
i too have this problem am under the impression there is a problem with the resistance but am waiting on areply from reebok technical support
Mar 27, 2009 | Reebok Exercise & Fitness
I have a Reebok Fusion Treadmill, an Oil Can Icon has appeared
I have the same problem. I phoned Reebok Tech Support 01908 512244. It is a timed icon to advise the deck should be lubricated. If you have done so / do this regularly you can ignore it. To remove the icon follow the instructions they emailed me. Hope this works Cheers John Please follow procedure below:
1. Keep power on and remove the safety key
2. Press and hold incline down and speed down, at the same time insert the safety key
3. You can release the “Down” buttons. (you will now hear a beep)
4. Press Speed up
6. Press stop. You will now hear a beep and the icon will disappear
Dec 02, 2008 | Exercise & Fitness
Exercise & Fitness Logo
42 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
