Question about Staples Tools & Hardware - Others
Multiple staples with 1 quick pull. 3-4 extras. is there a way to adjust or ? ? ?
4 Suggested Answers
  • 8 Answers
SOURCE: how do you adjust the staple size to load 1/2
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
Posted on Dec 05, 2009
  • 14 Answers
SOURCE: The staples are not going deep enough into our
The working pressure of this tool is 85 - 90 PSI max. Do not over power it or you risk O-ring breakage. These guns are adjustable for floor thickness. The adjustment is simply by adding and removing shims on the floor contact part of the tool. For 3/4" the pad should be 5/16" thick without shims
Posted on Jan 11, 2010
SOURCE: Hello. I have a model #1000 Swingline Power Gun.
Went to the local hardware and read the labels. The store brand fit and works as good as the original staples. The 1000 has outlasted several of the new fashion staplers. And the local hardware store is an Ace Hardware.
Posted on May 19, 2011
What.size staples needed for arrow fastener ct50
Product description
Product description
2750-1378 Features: -Revolutionary design with ergonomic handling.-Easy release drop in loading channel for staples.-Battery contains an easy to read LED charge meter.-Built-in safety switch prevents accidental firing.-Adjustable staple drive with depth of drive dial.-Light weight design for prolonged stapling tasks.-Can use T50 type 1/4'' staples (2750-0719), T50 type 5/4'' Monel staples, T50 type 5/16'' staples, T50 type 5/16'' Monel staples, T50 type 3/8'' staples, T50 type 3/8'' Monel staples, T50 type 1/2'' staples, T50 1/2'' Monel staples, T50 type 9/16''.-staples, and T50 type 17/32'' Ceiltile staples. Includes: -Kit includes case, charger, and tool. Specifications: -10.8 volts.
staples needed for arrow fastener ct50 Google Search
Jan 11, 2018 | Arrow Tools & Hardware - Others
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
My gun fires four or five staples all a once--is there an adjustment. with shooting so many staples at once then they do not go in all the way
  • This may or may not help, but I have one that was doing the same (as many as five at one trigger pull). I gave it the little WD40 and it still did the same. Then, I thought maybe it was the effect of not being used for a while. I proceeded to pull the trigger several hundred times (you can do this without staples loaded) and now, mine works fine. Seems to have helped.
Sep 16, 2014 | Electric Stanley Tre500 Staple Gun /...
Try turning off the Staple detection option in the settings.
Feb 11, 2014 | Canon DR-7580
How to load brads into stanley tre 550 electric staple/brad nail gun
1. Unplug tool, (fig. 1)...(place on/off switch in "off" position, (fig. 2).)
2. Place on/off switch in "off' position.
3. Select proper staple length.
4. Use only staples identified by stock numbers on next page. Substitute staples may cause jamming.
5. Hold tool upside down. (Squeeze latch and pull, (fig.3).)
6. Drop staples in channel, legs facing upward. Push latch back in to lock in place, (fig. 4).
2. Use only brads identified by stock numbers on next page. Substitute brads will cause jamming.
3. Look for the image of a brad nail on the front side of the tool (fig. 5). Load brads into this side only.
4. Hold tool upside down (Squeeze latch and pull, (fig. 3).)
5. Drop brads into the channel, tilt the tool so the brads lay against the channel wall, (fig. 5).
Push the latch back in watching that the brad strip does not fall over.
6. Use High/Low power when driving brads.
1. Make sure the on/off switch is in the "off" position, plug stapling tacker in.
2. Turn tool on by switching to position 1 which is the "on" position and hold firmly against work surface to
engage safety mechanism.
3. Apply adequate pressure on the top of the knob (fig. 6.) while the trigger is pulled.
You can find the figures mentioned above at the following link:
Jun 20, 2011 | Stanley Tools TRE550 Electric Staple/Brad...
How can i print multiple copies of the same document with 3 pages and have the printer staple the copies in the correct groups?
In the print driver you should have the option to collate, you need to make sure that that option is on, and when you go to send the print job, you need to make sure that you adjust the finishing options in the driver to tell it to staple.
May 11, 2011 | HP LaserJet 4250 Printer
Hello. I have a model #1000 Swingline Power Gun. It says,the extra heavy duty staple gun on the handle. I would like to purchase a box of 1/4" and 3/8" staples. The gun is so old I don't know the new...
Jan 20, 2010 | Staples Swingline® 36115 Staple Guns Tools...
My arrow fastener model t-50m is jammed how do I remove the few
I have a similar issue with my T50m stapler. To remove the staples unscrew the locking nut near where you load the staples and remove the tapppered bolt. The track will lift out and the staples can be easily removed. Why this is happening is unknown to me also. I purchased a new gun.
Feb 14, 2009 | Arrow Fastener 509 9/16" T50 Staples
Staple problem
pull about 1 inch of staples out of the cartridge, tear off the 1 inch so new staples are flush with plastic cartridge. Reinstall and make 10 stapled sets. By the time it tries to staple set number 3 or 4 you should start to see the staples working. It could take as many as 8 or 9 sets for the staples to advance far enough. Once it staples you are all set/
Mar 19, 2008 | Sharp AR-407 Copier
Tools & Hardware - Others Logo
54 people viewed this question
Top Staples Tools & Hardware - Others Experts
Jo Ann
Level 1 Expert
Joe Ball
Joe Ball
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
