R79 and r80 color value
Iam looking for the value of these resistor
2 Suggested Answers
  • 69 Answers
SOURCE: Due to lightning, Four on board resistors brunet
they are determined by the color bands on the resistor
Posted on May 09, 2010
The value of resistor in the light box color coded
Without a circuit diagram or another actual unit to look at it is very difficult to identify burnt out resistors. Even harder is finding out why it burnt out because most of the time a resistor only burns out if overloaded due to other circuit component faults.
Nov 21, 2015 | Dryers
WHAT IS THE VALUE OF RESISTOR R10 IN THE CIRCUIT BOARD?
Look at the color bands, they will determine the value. Last band color is the precision value of the resistor. You can find the color band values on many websites. The size of it tells you the wattage raring.
Mar 02, 2015 | Compaq CV 7500 17" CRT Monitor
R47 resistor is blown on Neff S5453X0GB/07 control board. I can't make out the value as it is badly damaged - anyone know the correct value so that I can replace it (TY7 is blown as well!).
HI.We cannot really but identify the correct resistor value unless we can identify or determine the color coding on the resistor.Each color has a corresponding value and tolerance as well.If you can't indentify the color coding then you can refer to its diagram usually printed out on the side of the control board or near thecontrol board.We cannot but cannot give a guess value unless color coding is given.Thank you for choosing FIXYA.
Aug 27, 2011 | Dishwashers
I have two crack green resistors colors are red, brown silver gold. what value is this. Its on the power board of a 24 dell monitor
The value = 0.21 ohms 5% tolerance
Use this WEB site to work out the value of the resistor.
http://www.smpspowersupply.com/resistor/resistorcolorcode.html
This WEB site gives you the color code values for resistors.
http://www.google.com.au/images?hl=en&q=resistor+colour+code&um=1&ie=UTF-8&source=univ&sa=X&ei=YHRsTfSsK5C2vQPA353UBA&ved=0CCsQsAQ&biw=1024&bih=416
Mar 01, 2011 | Computers & Internet
Black Screen One resistor is found Blown inside BWB but value unknown ! Please help !
Depending on the resistor, the values for a resistor is color coded, meaning that there are a couple of lines of colors and each color line represents a value. Do a google on Resistor coloring chart and you might find your answer. If the resistor is a surface mount one and very tiny, you might be out of luck as these are too small for the manufacturer to print the part number on. Only the manufacturer has that part number and can be very hard for you to contact them about.
Nov 10, 2010 | Acer AL1715 17" LCD Monitor
May 02, 2010 | Computers & Internet
Amp repair advice
check on the board to see if there is a resistor that looks similar, 90% of amps amps are matched in there design, meaning the left side is usally a carbon copy of the right, so if you look at one side and there is a resistor that looks like it's in the same spot on the other side, good chance thats the same one, read the colors off the one thats not burnt up. resistors come in different wattages,1/8,1/4 1/2 up to 10 watts, each wattage is a different size, most of the ones you see in the amp are 1/4 watt but some are 1/2 and 1/8. some on the output are 2 to 5 watt, but those are generally 10-18 mm in length, they are big ones you cant miss those. so once you get the color code, read the colors, ex red,gree,brown,last line is either silver or gold, that will tell you the resitor value. then google resistor color codes and then you can match the color sequence with the value codes, and that will tell you the value you need in ohms but then you have to get the size 1/4 watt resistors are generally about 6 mm in legnth, im measuring the actual part of the resistor not including the metal leads, just the body, so if its larger its probally a 1/2 watt if smaller its an 1/8 watt, 1/8 watt are about 4 mm. now go buy the resistor, but you might find it that tough, if its a common value radio shack might have it, but resistors are so cheap, pennies for a handful, good luck on your search.
Jun 30, 2009 | Sony Car Audio & Video
Blowin resistor on my Acoustic Research S112PS
When I put an ohm-meter across it, I get 505-ohms. The color code looks like maybe green, dark brown, brown? Mine is discolored too. Green, brown, brown would be 510ohms. . .so that must be it. The tolerance band is gold, so that's +/-5% so that would explain the 5 ohm variance.
Feb 12, 2009 | Acoustic Research S112PS Subwoofer
Rear projection tv mitsubishi vs-5005r
ok ill give you the proper value but you also need to change IC71012 volt regulator r79 and 792are 12 ohm 3 watt resistors
do not go down in wattage or change value in resistors as sum peole like thinking thay can do this it makes for bad thing to happen.
lol
hope this helps
regards
daniel.
Jan 05, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
