How do I go back to regular cable tv - Televison & Video
My ps3 does not work after i used the hdmi cable on my friends new t.v. when i came back to my house i put in back on my older tv to use the regular cable and the screen is just black. what could be wrong...
This is because the PS3 is trying to outpur in Digital... you have to reset the video output to work on your analog tv again... try this.
turn the unit off... if it is on hold the power button on the unit.
while the unit is off hold the power button untill it beeps, then go into the setup and reset the proper settings for your tv.
Jan 28, 2010 | Sony Playstation 3 (PS3) Console
I need to know what channel to operate my wii on. I have a toshiba tv that is about 8 years old.
Try changing the TV inputs to VIDEO or AUX, using the remote or a button on your TV. If there is not a way to connect the Wii to the TV using the 3-cable system (Yellow, Red and White), then you might have to use a VCR or DVD player to plug the 3 cables into and then transmit the audio and video from the Wii using the regular cable line of VCR or DVD Player on TV channels 3 or 4. If your Wii has a regular TV Cable jack on the back, connect that to the jack on the back of you TV and select channel 3 or 4.
Jan 05, 2010 | Nintendo Wii Console
Im plugging in all my xbox 360 cables but the game wont show up
If you have the cable that is both component and a regular a/v cable, make sure that the switch is on regular tv and not hd, then ste the hd settings to what your tv can handle and then turn it back if you need to.
Oct 24, 2009 | Microsoft Xbox 360 Console
Do not know how to get regular T.V. hooked up to this system
try using the red White cables from back of tv to back of dvd player/receiver. Do the same with DTV/dvr or cable box. not sure if cable box has red and white cable outlets, however the DTV-DVR does, The quick patch is from TV to back of dvd (input audio)side,....that should work
Sep 26, 2009 | Coby DVD-937 5.1 Channel DVD...
Trying to switch my symphonic tv back to cable mode
under menu their should be a CA/TV option.
May 12, 2009 | Symphonic WF104
Switching singnal
If you are using an antenna or regular cable without a cable box, put the tv on an analog channel. Go into the menu. Select the middle icon at the top of the screen. Go down to the TV/CABLE line. Select either TV (for antenna) or CABLE (for regular cable) on the right. Go down to AUTO CH MEMORY and press the volume+ (right arrow) button. Wait for the channel search screen to clear. Check all of your channels using the channel up button until you come back to the channel you started on.
Feb 28, 2009 | Sansui 27" TV
Tv/remote input problems
Try plugging your cable box in using a/v cables (red,white,yellow) and see if you have a picture on a different input from the box. If so, go into your general settings in the box and change the output channel to 4 instead of 3. Then try your TV on 4 and see if your picture comes in. I have seen TV tuners go out on just one channel before.
Feb 24, 2008 | JVC AV-27230 27" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
