Question about Toro Garden
Toro lx420 blows fuse after 10 20 min cutting grass
  • 60 Answers
SOURCE: My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Posted on Jun 24, 2009
  • 16 Answers
SOURCE: I have a 3 year old Toro 22
change the blade
Posted on Aug 20, 2009
SOURCE: Water and wet grass get into the battery
"Is this a design flaw by Toro?" (sic) Well, it indeed maybe, it definitely, isn't helping the situation. Here's what to do, get some Mesh, and fasten it across the opening, this will stop most things from gaining egress, and protect what is behind, If that's not sufficient, then perhaps a Plastic,sheet (perhaps if required some holes in it). fastened, across the aperture, will work. In any case I have no doubt, you have the idea of what to do to remedy this situation.
Posted on Apr 17, 2010
Testimonial: "Thanks for the reply. I have already sent a few scathing letters to Toro regarding this. I have only had the mower for less than a year."
rycgl
  • 1545 Answers
SOURCE: I hit a metal pipe while cutting grass. Lawnmower
If you are lucky, you have only sheared the flywheel key and messed up the blade. The flywheel key is under the top cover and under the flywheel along an indent in the side of the crankshaft. Those parts would have to be removed to check it....most likely it's sheared (broken) which is what it is supposed to do (most are made of aluminum) when the blade hits an immovable object. It CAN be fixed and there are videos and forum HOW TO's on this subject. A new key is very inexpensive and replacing one is a good learning experience.
Posted on Jul 15, 2010
Testimonial: "rycgl, I thank you for giving me very accurate advice. I took the flywheel off and sure enough the flywheel key had been sheared off. "
barterjoe
  • 344 Answers
SOURCE: We have Toro Lwa 100 Lawn Mower Model #26623.
This 1991-92 model is equipped with a blade brake clutch. When the blade slows down this means the belt is slipping. This slipping can be caused from a few different things.
Try adjusting the blade cable on the upper handle. this unit has an adjustable section. make sure the cable is not so tight that you snap it.
2 --A sticky pivot point under the belt cover
The belt cover in the back builds up with dirt and debris. Make sude it is clean under the cover and all of the pivots move freely. ( do this with the engine off)
3 --A sticky belt tensioner under the deck cover
The underside of this machine has a metal cover to protect the belts. Remove it and check that the blade belt idler arm is not frozen in place. this will cause the belt not to enguage all the way.
4 --A worn belt or belt pulley
The large flywheel and pulley can wear. Check this if the belt looks good.
This is all there is to the machine BBC system.
I hope this helps.
Get parts and more diagrams at a Master Toro Dealer like www.arcolawn.com
Posted on Mar 02, 2011
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Wiring diagram toro lx420
www.toro.com/en-us/customer-support/pages/default.aspx
May 31, 2014 | toro"" 2-cycle engine oil"
Grass cutting blowing out from in front of mower deck.
Dull or bent blades can cause this. Make sure that the grass is not built up under the mowing deck. You can purchase new blades at a Toro dealer like www.arcolawn.com.
tell them Joe from Fixya sent you!
Feb 12, 2011 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Why does the mower blow out chuncks of grass, i am not cutting to low? ive only usewd it 22 times
1. Sharpen the blades
2. Cut when the grass is dry
3. Ensure the belt to the blades is not slipping.
4. Clean the underside of the deck after each use, use a scraper if you must but keep the buildup to a minimum
5. Run the throttle wide open during cutting
Jun 16, 2010 | Toro 42'' Zero Turn Lawn Mower Trailer...
Water and wet grass get into the battery compartment of my Toro Key Start self propelled lawn mower and blow fuses. All Toro repairman did was replace corroded battery, replaced fuse and wiring harness,...
Apr 17, 2010 | Toro Lawn Mower With Toro Power Tools
Jun 23, 2009 | Toro Lawn Mower With Toro Power Tools
Mower bogs down in medium high gras
what is happening is there is tomuch grass in deck & not discharging as fast as it cuts it if deck is ajustable put it on high setting then try if it works then got back over it with a lower setting this is most likely the case to much grass in deck while mowing blade gets cought up alot with alot of grass in deck
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
76 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
