Question about RCA Televison & Video
RCA Model# M61WH185 ... Dusted inside of the TV and now there is no sound or picture. TV will not cut on with remote.. have to plug it in to outlet to come on. Does this sound like the flyback?
  • 10 Answers
SOURCE: No picture or sound - TV makes chirping noise
Rich that chirpin noise is somthing over loding it try checking your horzotal output for short and diodes around the transformer...
Posted on May 21, 2007
Slinteriors
  • 8617 Answers
SOURCE: tv problem dead set
Your flyback has shorted out and thats whats burning the resistors cahances are the HOT is shorted as well. You can get some information at the following link for RCA problems. Just leave them an email with your model and what the problem is
http://servicemanuals.vstore.ca/
Posted on May 20, 2008
SOURCE: Model F27650 RCA Entertainment Series
I have a RCA Entertainment Series 32' Model Number F32650Y01E024C226E just stopped working. no picture, just a chirping loud noise that came from the back of the tv.
Any suggestions?
Posted on Jun 23, 2008
  • 979 Answers
SOURCE: Need to know how to install a flyback in 2004 52 in RCA tv.
First and foremost, disconnect the power cord from the mains.
Next, after having removed the back cover from the set, discharge the tubes' residual high-voltage to ground using a suitable tool.
Access to the transformer is pretty much staightforward here.
A few hardware removals and you can then get to the board and transformer..
Mark, then remove all leads that go to the unit.
INstallation is the reverse of removal.
Be sure to replace the driver device, just to be certain...accordianman
Posted on Dec 12, 2008
muttandjeff
  • 359 Answers
SOURCE: TV power light comes on but no picture/no sound
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Posted on Feb 06, 2009
My tv is not working right with picture.
Press the TV button on the remote, make sure the TV is plugged in, check the electrical outlet to make sure it is live if the TV does not turn on. If these actions do not solve the problem, press the Power button on the front of the TV. If the TV turns on, replace the batteries in the remote control and reset it by pressing the number 1 button for 60 seconds. If necessary, reprogram the remote.
Unplug the TV for two minutes, then plug it back in if the buttons on the remote don't work. Make sure the remote is in TV mode.
Change the settings on the sleep timer if the TV turns off unexpectedly. Unplug the TV and wait five minutes before plugging it back in if necessary.
Check your antenna connections and cables if the sound is okay but the picture is poor. If all the connections are good, adjust the sharpness function.
Jul 21, 2011 | RCA 20F512T 20" TV
When we plug in hubby's remote headphones (he has a hearing impediment), it cuts off the sound and I can't hear it.
That is normal operating mode when using the headphone jack. The only way for you to do this without cutting the sound from the speaker so you can hear the sound (if your remote headphone has the Line level input), is to use the audio line out (WHITE and RED RCA jacks) to feed the remote headphone unit.
What the make and model of the remote Headphone system that you have?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Jun 05, 2011 | LG 32 32LK450 32 in. LCD TV
My RCA tv has been working fine for years. A few days ago it began to have intermittent popping sounds. Picture is clear and sound is good. I recently dusted the back of my set and I'm sure some dust must...
hi there,
if u know how to work with your set u can:
1. open the back cover case of your tv and try to find a foreign objects inside and clean it up with your vacuum cleaner.
2. popping sounds sometimes due to lossen parts, bad socket contacts, too much dust and dirts ,corrosions .and when cleaning you unplug first your TV set to avoid electric shock. i hope this will help a little. Thank You.
Feb 08, 2011 | RCA TruFlat 27F520T 27" TV
Does the RCA TV Model G27400WK, Serial No.234550152 have a reset button and where would it be located?
try these steps
On occasion, an RCA television may need to have certain options reset in order to restore default settings. Software resets, such as resetting the Picture Control, the Parental Control lock and the Wake-Up Timer, can easily be restored to the default settings by accessing the settings menu via the remote control. A Hard Reset is recommended if there are hardware problems with the TV, such as a loss of picture or if the TV isn't turning on properly.
if that doesn't work try these steps
  • Unplug the TV's power cord from the electrical outlet.
  • Wait 5 minutes.
  • Plug the TV's electrical cord back into the electrical outlet. If this does not resolve the problem contact RCA Customer Support or a local technician store
  • Jan 04, 2011 | Televison & Video
    M61WH185 rca scenium front panel flashes 5 times and no picture
    this is the tv's way of saying that my lamp is getting weak or is about to go.
    Sep 06, 2010 | RCA Scenium M61WH185 61" HDTV
    Feb 05, 2009 | RCA Televison & Video
    Sound but no picture
    Sounds as if the lamp has gone out...accordianman
    Feb 27, 2008 | RCA Scenium M61WH185 61" HDTV
    Any suggestions?
    Jan 06, 2008 | RCA 32F531T 32" TV
    Snap crackle pop
    Check the Flyback, had same problem, replaced it and the unit worked good.
    Oct 15, 2006 | RCA P46921 46" Rear Projection Television
    Televison & Video Logo
    18 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
