Question about Whirlpool Washing Machines
GETTING FAULT CODES WITH NO DISPLAY ON WHIRLPOOL CABIOR WASHER
the dr
  • 447 Answers
SOURCE: Whirlpool washer Cabrio WTW6600SB1
Its the Rotor Position Sensor very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
  • 6 Answers
SOURCE: Washer displaying a fault code.
check your manual. it will tell you what it means and what to do
Posted on Apr 01, 2010
sclarke7
  • 222 Answers
SOURCE: On whirlpool duet ,am getting fault code f21 in wash cycle.
Foreign objects in the prepump
remove access panel in front remove round plastic plug clear objects have towels ready
Posted on Apr 20, 2010
taran_2005
  • 10515 Answers
SOURCE: fault code f-33 on a whirlpool duet.
The F33 code is a pump failure code. The control unit is not measuring the proper amp draw on the pump during pump out. Remove lower panel and unplug then replug in the pump 2 or 3 times to remove any corrosion. While your down there, take the front of the pump off to check for any blockages.BE SURE TO UNPLUG YOUR WASHER WHILE SERVICING!
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: I get an F1 fault code during the fill cycle. Can anyone help us?
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Whirlpool duette washer stops during cycle beeps and displays error code F
The f should be followed by a digit or two that indicate a particular fault code. A mid cycle stop with a fault code might be because of a long drain time due to a
Faulty drain pump or clogged drain filter but without the entire fault code it’s difficult to give an exact answer.
Feb 11, 2018 | Whirlpool Washing Machines
My whirlpool awo/d 5556 washer displays error code f:26 can you help please?
F26 Drain pump triac failure This error code is displayed when the main electronic controller fails to detect the triac that controls the outlet drain pump during the wash cycle.
  • Check pressure switch contacts and connectors
  • Failure of the pressure switch or level sensor can also give rise to this fault code
  • Run test program
  • If failure persists after test and verification of pressure switch, replace main controller
The above information was take from UKWhitegoods web site
http://www.ukwhitegoods.co.uk/help/fault-codes/220-laundry-fault-codes?type=rss&limitstart=0
Feb 09, 2017 | Whirlpool Washing Machines
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    How do I clear the fault codes ?
    How To Fix Maytag Washer Error Code F9 E1 ...
    www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
    Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
    KitchenAid f09 error code Dishwashers Questions ... - Fixya
    Nov 29, 2015 | Dishwashers
    F- code does not show code in book what and how to remedy the problem?
    Hello there again here is some more info for you
    Whirlpool Washer Troubleshooting: Error/Fault Codes Whirlpool Washer Troubleshooting has been made easier since newer Whirlpool washers generally display a consistent range of error codes (or fault codes) when problems develop so that owners and service personnel can quickly troubleshoot the problem and fix it easily. The Fault codes address a wide range errors that occur with Whirlpool washers, everything from water and power problems to basic maintenance routines. We have put together a comprehensive list of Whirlpool Error Codes for some specific and general Whirlpool Washer models to help you with your Whirlpool Washer Troubleshooting task.on next post
    Oct 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Cabrio is showing a error code of F1 what does that mean?
    Typically, we're going to be looking at a pressure sensor failure here, although there are a few possible culprits. There's some pretty detailed troubleshooting here:
    http://www.managemylife.com/mmh/questions/195601-why-does-my-whirlpool-washer-model-wtw6500sw1-display-the-fault-code-f1
    Jul 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Apr 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
    I am getting a code F35 mid cycle,have to unplug washer to reset...any help?
    F35ANALOG PRESSURE SENSOR FAILURE
    If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
    1. Check if pressure hose is fi xed correctly.
    2. Check if the airtrap is not blocked.
    3. Check if the hose is not blocked
    Whirlpool Duet Washer Fault Codes
    Dec 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    I get F35 error code on my duet washer
    Both of these fault codes point to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after diong this, you will likely need to replace the pressure switch.
    Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    24 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
