Question about Sewing Machines
Lena serger 704dex cover hem threading - Sewing Machines
  • 136 Answers
SOURCE: Janome Mylock 534D serger thread 4 (green guides) breaking
what issue?
Posted on Jul 07, 2009
  • 11 Answers
SOURCE: White Electronic 834DW Serger
Hey if you need a new manual go to this link www.ifixmachines.com and dont forget to put this code (150t) so you can get $1.50 discount. Hope this help.. By the way the manual cost only $10. BYE
Posted on Jul 22, 2009
  • 1116 Answers
SOURCE: I can't find my Bernina Serger 800 dl manual - how
From what I have read this manual is less than desirable. Neither is the one for the brand that I have.
You may have better guidance if you purchase and use Nancy Zieman's "Serge with Confidence". I have found it very helpful.
For the two thread rolled hem, the looper cover is used to "trick" the looper into "thinking" it is threaded.
On my serger (not a Bernina), this is referred to as a "subsidiary looper". It is a spring type mechanism that fits in a small hole at the top of the upper looper.
You use a rolled edge presser foot; right or left needle; stitch length @ normal or wider; stitch length @ 1mm for the left needle/0.5 for the right needle; differential feed @ normal; needle tension - tighten; lower looper tension - normal or looser; two thread looper cover - engaged.
Test and adjust the tension as needed before making the rolled hem on your garment.
I hope this helps.
Posted on Apr 18, 2010
  • 4 Answers
SOURCE: I need a diagram for threading a 4 thread serger
The inside diagram is for the loopers. For the needle threads, just follow the color coded dots.
Posted on Dec 03, 2010
  • 18 Answers
SOURCE: I have a viking serger
http://www.sewingresourcesonline.com/product/PD1234
I have the same serger.  The produt link posted above is an awesome intrustional dvd on learning the cover stitch.
Posted on Feb 26, 2011
Can I make rolled hem with a Juki MO 2366 N?
Most likely. Most overlockers can make a rolled hem. You will probably want to do a lot of practicing on scrap chiffon before trying it on the real thing. It involves using only one needle, both loopers, and making appropriate adjustments to the machine.
Serger 101 Threading the Juki MO 654de Machine for Roll Hemming by CKC...
How to Serge Rolled Hem
Serger Stitches 101 Cheat Sheet Never Ever Without It Your New Must Have...
Bernina has some very nice Serger Workbooks that could be helpful:
Bernina Mastery Workbooks
Nov 13, 2017 | Juki Sewing Machines
Setting a elna 792d for rolled hem
I don't know your model in particular but generally this is how you set up a serger/overlocker to create a rolled hem. Remove the left hand needle and thread if 4 threads are threaded). Now there is usually a lever around the stitching area that you slide back towards you to remove the stitching finger back (disengaged). Then you adjust the top looper tension looser (about 2-3) and lower looper tension tighter (7 or 8). Leave needle tension at normal tension (5). You may need to move the cutting blade to the right too. The technique is to cut the fabric wider but with a narrow stitch so the cut edge rolls under within the stitching. You want the top looper thread really loose so it rolls right around underneath up against the needle thread, the lower looper thread needs to be tight and almost invisible, pulling the upper looper thread down. I usually do a few test runs and check the stitching. Once happy, I turn the stitch length right down to 1 so it is very dense. This uses a lot of thread up.
Ideally use a wooly overlock thread on the upper looper as this "fluffs" out once stitched and "fills" in covering the fabric edge completely.
some good images here
Sewing Basics Narrow Rolled Hems with Serger Sew Mama Sew Outstanding...
Jul 18, 2017 | Elna Sewing Machines
I need help in good tension for rolled hem in empisal 606D overlocker
Your owner's manual should have instructions for rolled hem settings. My Bernina manual has a the following settings:
Medium weight fabric
80/12 Universal needle
3 cones serger thread
Upper looper 3-5
Lower looper 7-9
Left needle (no thread)
Right needle 3-5
Stitch length 1-1.5
Cutting width 2-3
Differential feed N
Can use woolly thread in the upper looper, but the tension may need to be loosened since the woolly nylon thread will stretch.
Make It Handmade Threading Your Serger or Overlocker
Dec 19, 2015 | Sewing Machines
Do you have a manual, project book or anytrhing that gives information on how to use the features of the 936 surger?
I would suggest that you contact Husqvarna Viking to purchase a manual for your 936 serger, their contact details are here.
http://www.husqvarnaviking.com/us/406.htm
You could also get lots of general sewing info from Debbie Cosgrove at http://sewing.about.com/od/sergersoverlock/ss/serger.htm sewing.about.com is a fantastic source of information on sewing techniques, sewing machines, sergers and projects too.
Sergers are quite differernt to a sewing machine and there are plenty purchased, used once or twice, then put away or sold because they are a bit difficult. But like any new skill learnt, taking a class and learning hands on is so much better than trying to figure out from a manual so if you can find a local Husky dealership, I'd enquire about an "intro to serger" type class, well worth the money and time.
Yours will probably do a three thread overlock, 4 thread overlock and rolled hem stitch, these three seams will cover a variety of sewing tasks and applications. You can seam knits and lycra with the 4 thread, and neaten the raw edges of just about all fabrics with a three thread. The rolled hem allows you to do a small covered edge which covers the fabric cut edge wrapping the thread around it closely. Beautiful on very light weight fabric edges like ruffles and frills where you have yards of fabric to neaten, much quicker than turning edge twice and straight stitching it.
There are other techniques with a serger such as sewing stretched elastic onto fabric, sewing over nylon fishing line to give a fluted edge or stitching over a string of beads. These are best done with a special foot for this purpose, elasticator or beading foot. You can also use decorative threads through the loopers to give an attractive finish.
There are several good sewing with a serger books on the market, Singer does one but there are other great ones too. You could always borrow one from the library before committing to buying it.
Jul 07, 2011 | Sewing Machines
I can't find my Bernina Serger 800 dl manual - how do I thread for a 2 thread rolled hem, and do I need a upper looper cover and that the heck is that anyway?? Thanks
I hope this helps.
Apr 18, 2010 | Bernina 1008
Brother Serger 634d
where can i buy a new thread tree for my 1034d brother overlocker from betty c
Oct 30, 2008 | Brother Lay-In Thread Serger Mechanical...
Coverstitching on White Speedylock serger
Your machine cannot do a cover stitch. Check the Brother website, they make a cover stitch only machine, it works much better than any of the serger/cover stitch combination machines, and it is a lot less money.
Nov 19, 2007 | White Sewing Speedylock 1600 Mechanical...
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
