Question about Epson Office Equipment & Supplies
How to fix fuzzy lines on epson wf-4630 printer?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Epson Expert
  • 97 Answers
Go to menu on the printer and select "Maintenance" and print "nozzle test pattern".
Clean the printheads by going into menu again and select maintenance and then "cleaning"
Print nozzle test and see if page looks better.
Picture for example of bad and good nozzle test:
how to fix fuzzy lines on epson wf-4630 printer? - maint5-2sqgqrk0riremdz0mv2jm3m4-1-0.jpg
Posted on Jun 07, 2017
3 Suggested Answers
  • 18 Answers
SOURCE: i have a lg fuzzy logic 7.5 kg WF-T755A washing machine that has stopped spinning and also stopped agitating in washing cycle
Call LG's support line, they have excellent customer service.
Posted on Apr 04, 2013
  • 12 Answers
SOURCE: My Epson wf-2540 printer won't print black I have done head cleanings and have new ink in it as well. What can I do to fix the problem?
In addition to the things listed by Pete Kop and the head cleaning you have already done, try aligning the print heads. I had the same problem with my HP 6500 all-in-one and it always needed both the head cleaning and head aligning before it would print again.
Posted on Jan 17, 2015
What is an Ox97 or 0x97 error code on an Epson WF-3640 printer?
Error Code 0x97 in Epson WF- 4630 means there is decrement in efficiency of printer. The printer may be not printing the pages as it used to print earlier. You don't need to worry anymore. You can follow either of the Solution to resolve the Error.
Solution 1:
Step 1: Download "0x97 Fix Patch:
Step 2: Click "Scan" button.
Step 3: Click :Fix" button to repair the Printer.
Solution 2:Step 1: Restart the computer. Login as an administrator user.
Step 2: Click "Start" button> "All Programs"> "Accessories"> "Tools"> "System restore".
Step 3 : Now click "Restore my machine to an earlier date"> "Next".
Step 4: Select most recent system restore date within the "tap a restoration date" Listing and click "Next".
Step 5: Click "Next" on the verification window.
Step 6: Restart your PC is required after the completion of restoration process.
Now, try to work with your printer again.
Call Epson Printer Support Team 1-800-213-8289 if the Error is not resolved or you are having any other kind of issues.
Visit: Epson Printer Support Phone Number 1 800 213 8289 Tech Support
Jul 06, 2017 | Epson Office Equipment & Supplies
Ho do you reset the ink levels on an Epson WF-4630 (T7861)?
Ink levels are set by chips on the ink carts. You may be able to reset the chips with a "chip resetter", but that's not really recommended. Get refillable carts with automatic resetting chips...
Dec 08, 2016 | Epson WorkForce WF-4630 Wireless Color...
Epson Wf-4630 keeps jamming when i use the ADF to scan documents
It may be due to the corner of the paper is bend or not exactly parallel.
Nov 04, 2016 | Epson WorkForce WF-4630 Wireless Color...
PRINTING ERROR MESSAGE?
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
Jun 20, 2016 | Epson WorkForce WF-4630 Wireless Color...
MY EPSON WF-4630 PRINTER IS STUCK ON oxf4 AND WE CAN'T CLEAR IT. WHAT DO WE DO??
If you are lucky, the 0xF4 error indicates a foreign object (a scrap of paper) in the gears. That would translate to PF driver mechanism overload. Another cause would be a contaminated encoder scale. Fixing either of these will require you to disassemble the printer. Here are some tips for taking apart the printer: https://www.ifixit.com/Guide/Repairing+EPSON+B-510DN+Error+0xF2+or+0xF3/11767 .
However, the 0xF4 error could mean that the encoder board or the motor have failed. These errors can only be fixed by a service technician. If your printer is under warranty, you should call for service. Otherwise decide if you want to risk taking it apart and finding that you can't fix this error. It may be cheaper to replace the unit.
I hope this helps.
Every 10th line of print is fuzzy. We have tried all the usual fixes, head clean, nozzle check. What next
What should I do if my printout is blurry or smeared? - Epson ...
https://www.epson.com/cgi.../supDetail.jsp?...
EpsonSep 18, 2012 - Epson WorkForce WF-2530 All-in-One Printer ... If your printouts areblurry or smeared, try these solutions: ... If you print on both sides of a sheet of paper, smudges may appear on the reverse side of heavily saturated or dark ...Missing: every ‎10th
What should I do if my printout has lines running ... - Epson
https://www.epson.com/cgi-bin/Store/.../supDetail.jsp?...
EpsonSep 18, 2012 - Epson WorkForce WF-2530 All-in-One Printer ... If you notice white or dark lines in your prints (also called banding), try these solutions before ...Missing: 10th ‎fuzzy
FAQs for this Product - Epson WorkForce WF-2530, Top ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid...
EpsonThis link provides access to Top FAQs for the Epson WorkForce WF-2530. ... [ Answer ]; I see the message Printer is Offline when I try to print with a ... [ Answer ]; What should I do if my printout has lines running through it? .... When printing in Windows, how can I prevent an extra page from being ejected after every print job?
Jan 19, 2016 | Epson WorkForce WF-2530
Why is my wf-4630 not recognizing initial cartridges?
if they are not epson original cartridges,they wont work,you cant refill or by refilled cartridges to use in this printer,if buying used cartridges,you have to be able to reset the printer,some cartridges reset the printer but most dont
Aug 07, 2014 | Epson Office Equipment & Supplies
144 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
