Question about Roper Washing Machines
I have a Roper washer I want to use fabric softener but I cannot get the top of the agitator open how do i do that?
jsrock516
  • 5911 Answers
SOURCE: Fabric softener doesn't dispense
Fabric softener dispensers are notorious for getting all gummed up and clogged. Remove the dispenser cup and soak in some hot water to dissolve all residue. While you have the dispenser removed check under the dispenser cap in the agitator for gummy residue as well. Clean with hot water. There should also be an agitator seal cap under the dispenser. Make sure the cap and rubber o-ring are seated properly. Last of all, if the dispenser has a cone shaped cup inside, make sure it is inserted cone-side UP. The cup is designed to allow fabric softener to roll down the sides of it, NOT hold it. I hope this helps.
Posted on Apr 29, 2007
the dr
  • 447 Answers
SOURCE: Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Posted on Nov 28, 2007
  • 5 Answers
SOURCE: I've had an Amana Washer model ALW880QAW for about
I couldn't wait for a rely on my posted question on March 6,2009. I was able to ask around to figure out how to clean this up. This Amana washer model has an agitator that is just clipped on. I just got my fingers underneath the agitator and pulled it off. After getting the agitator off, I was able to clean all of the old built up detergent and fabric softner with some old fashion scrubbing. Then I used some CLR to get what ever I missed. I pushed the agitator back until it clicked back into place and ran one washing cylce to clean things up.....Works great....No more old clumpy stuff showing up in the wash....
Posted on Mar 13, 2009
huuum
  • 750 Answers
SOURCE: One part of agitator moves the other part doesnt.
Two-Piece Agitator: Bottom Works, Top Does Not - Whirlpool brands
Some Whirlpool brands washing machines employ a two piece agitator. The bottom is call the agitator and the top is usually referred to a 'Mover'. A multi-piece cam and bearing assembly connects the two and allows the top portion to index.
If the bearing or cams become stripped or damaged, the mover will often not work. Fortunately, Whirlpool produces a cost effective agitator repair kit that replaces all of the critical components in this cam assembly. There are three different repair kits. They differ in the height of the cam.
Agitator Removal Instructions:
Remove Dispenser or Cap:
Some models of washing machines utilize a fabric softener dispenser that resides on top of the agitator. This dispenser simply snaps onto the top of the agitator. Other styles utilize a decorative cap. To remove the dispenser, simply grab it and firmly pull up. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (mover). Use a twisting or prying action to pop the cap off of the agitator.
Remove Internal Debris Cap:
Inside the agitator you will see a cap with a raised handle, much like that of your automobile. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring.
Remove Agitator Stud:
When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt (agitator stud).
Remove the Upper Agitator (Mover):
With the bolt removed you should be able to remove the upper half of the agitator (mover) by simply pulling up. Sometimes pulling up will actually remove the whole agitator assembly. If this happens, place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator.
Remove the Cam and Clutch Dogs:
When you remove the upper agitator (mover) it contains the cam and clutch dogs. Tun the assembly upside down. The cam and dogs should then come out.
-- Stop Here if Replacing Cam Kit --
Remove O-ring:
The lower agitator remains on the transmission shaft. On the top of the agitator, there is an o-ring. Remove this o-ring.
Pull the Lower Agitator:
All that remains is the lower agitator. This can be removed by simply pulling straight up on the agitator.
Agitator Installation Instructions:
Set Lower Agitator:
Slide the lower agitator onto the transmission shaft. Rotate the lower agitator until the splines in the shaft match those in the agitator. Once aligned press the agitator down. Install the o-ring into the top of the lower agitator.
-- Start Here if Replacing Cam Kit --
Assemble Cam and Dogs:
Turn the cam upside down. Place the small round ear of the dog into the corresponding slot on the cam. Repeat this for each of the four cams.
Install Cam and Dogs into Upper Agitator:
Invert the Upper Agitator (mover) and slide the cam/dog assembly inside. The cam should be pushed into the mover until it shoulders. Then rotate the whole assembly upright.
Install the Upper Agitator (Mover) on the Lower Agitator:
The lower agitator has two tabs that stick up that are 180 degrees apart. These tabs fit into two slots on the bottom of the cam. Align the matching tabs and slots and place the Upper Agitator (mover) and cam assembly onto the lower agitator. Push down until the cam snaps onto the Lower Agitator. If the dogs fall out during this step it is necessary to return to the 'Assemble Cam and Dogs' section above and start over.
Install the Agitator Stud:
Place the bolt (agitator stud) into the hole in the bottom center of the cam. Use a socket kit or nut driver to tighten the bolt .
Install Internal Debris Cap:
Install the o-ring into the groove on the OD of the debris cap. With the o-ring in place, push the cap into the Upper Agitator (mover). It is important that the cap is pushed past the ports in the Upper Agitator (mover) so that the wash water can enter and exit as designed.
Install the Dispenser or Cap:
The final step is to replace the top cap. Both the cap and the dispenser simply snap into place. Just make sure they are installed as far down a they will go and are firmly in place.
Posted on Apr 07, 2009
SOURCE: kenmore 3.5 super capacity front load washer won't dispense fabric softener
Kenmore 110 front load washer wil not dispense fabric softner. Code 21. Have already checked pump and filter obstructions
Posted on Apr 18, 2010
Fabric softener ends up around rim of washer.
When you say you've cleaned both parts - have you poured hot water in and seen it actually drain out of the top peice while it was removed from the agitator? Have you poured hot water into the agitator with the top peice removed and seen it drain out of the holes? If not, repeated flushing (of the agitator) and soaking (of the top peice) with hot water as needed until is drains may be required. Until you can get water to drain out of both peices alone, it will work automatically. Once you have the water draining try again with a regular load of laundry and fabric softener. If it still doesn't work...
Since you've cleaned both parts (the non-removable and removeable top portion) of the agitator - it would suggest that the fabric softener dispenser's actuator inside the agitator is not functioning properly. The fabric softener isn't being released in the rinse (or at all really) and as a result of the centrifugal forces during the high speed spin cycle - it is causes the fabric softener to move up the sides of the dispenser and spray out of the top of the agitator onto the rim. This may be caused a mechanical or electrical failure in the washer or washer control. It will continue to work like this until it is fixed - so I suggest that you do not use the dispenser.
You will likely need to have the washer professionally serviced to have it begin working again. You can save the repair costs and either add the fabric softener yourself during the rinse cycle - or use "dryer sheets" in the dryer instead.
Feb 05, 2013 | Washing Machines
Does the roper washing machine top loader model# RTW4340SQ0 have a place to put in the liquid softener?
I have the same question but have not find a manual or any other reference that tells me whether this model has a softener dispenser or not. However, I just found this info: http://www.repairclinic.com/PartDetail/Fabric-Softener-Dispenser/8575076A/1195942 which is linked to roper washing machine RTW4340SQ0 parts list. It looks as if the washer doesn't come with the softener dispenser as original equipment but that you can buy this dispenser at repair clinic and just assemble it to the agitator as shown in the video that you will find in the link
Jan 13, 2013 | Roper RTW4300SQ Top Load Washer
Roper heavy duty super capacity 8 cycle fabric softener mess
check to see when and where you are to add the softener read the manual for tips look in the trouble shooting guide
Jul 06, 2012 | Roper RAS8445KQ Top Load Washer
The top part (not the fabric softener cup) of my Roper top loading washing machine came out when I took a blanket out of the machine. I tried reassembling the agitator, but, it doesn't fit correctly. ...
If this is the split agitator (two piece), the top part should not come off without tools. The part of the agitator that receives the fabric softener dispenser has a clear plastic cap that comes off to reveal a bolt. If this is the piece that you have described, something broke.
The bolt in the picture must be removed to release the upper agitator from the machine.
Is this the part that came off? If so, the bolt came off or the upper agitator is broken.
Jul 11, 2011 | Roper RAS8445KQ Top Load Washer
HOW DO i REMOVE THE AGITATOR FROM maYTAG WASHER MODEL # MAV6457AWW
Gently remove the fabric softener cup off of the top of the agitator
Using a ratchet, an extension and socket; then remove the retaining bolt under the fabric softener cup.
The agitator will lift off after the bolt is removed.
Installation is:
Drop the agitator in place. Install bolt.... tighten bolt with ratchet, extension and socket. Install the fabric softener cup.
Fabric softener cup is item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170378&diagram_id=28464917#d28464917
The bolt you need to remove is item 4 of the above link.
Thanks for choosing FixYa,
Kelly
Feb 05, 2011 | Maytag MAV6457 Top Load Washer
RTW434OSQO Is there a place to add softner
Actually no. The only thing you can add in your machine is soap and bleach. There is not a fabric softener dispensor in either the agitator or the chassis.
I am not endorsing this product only using it as an example but you can use one of these to automatically add fabric softener post 1st spin cycle:
http://www.downy.com/en-US/product/the-downy-ball.jspx
There are 2 or 3 different variations from several manufacturers out there.
Thanks for using FixYa.
Kelly
Apr 04, 2010 | Roper RTW4300SQ Top Load Washer
Where to put the detergent and liquod softener in newHaier washer
Detergent goes in the drum with the clothing, fabric softener in the middle of the agitator, the drawer is for delayed start if using soap powder
Apr 04, 2017 | Haier XQJ50-31 Top Load Washer
Spots on clothes
Chris your agitator problem is repairable. remove the fab softener cup and the cap on the agitator down inside the opening you should see 4 pieces that look lik a tear drop is my best description for them your are wore out and do not engage when the agitator agitates replace them and you'll be good as new.
Mar 19, 2009 | Roper RAS8445KQ Top Load Washer
Gunk in middle of agitator
the fabric softener spins out of the cup after the wash cycle when spinning the water out of clothes, then the washer fills back up for the rinse w/ your softener having been dispensed. is there a nut at the bottom of your agitator where you see the gunk? If so you can take the agitator out by removing the nut but be careful of the little parts that make the agitator agitate. Do not disturb these little parts if you don't know about them. Does the gunk smell like grease or a mechanics garage? If so chances are it is a lubricant and should not be removed replace the cap and your softener cup and continue enjoying your machine.
Jan 05, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
23 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
