Question about Sanyo Televison & Video
Me sanyo tv screen displays,,no media,, on screen,, touched alll buttons on screen,and cable remote,, dont hav original remote ..only cable remote
    Top Expert:
  • Sanyo Master
  • 74,630 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on Jun 18, 2017
Pookeybrain
  • 51 Answers
SOURCE: 1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Posted on Nov 10, 2007
  • 71 Answers
SOURCE: sanyo 42" flat screen tv green light comes on but no picture
oops u r in trouble.
Posted on Mar 05, 2009
SOURCE: i have a sanyo 32 inch flat screen television
you can order a replacement off of the website
Posted on Apr 04, 2009
SOURCE: Sanyo DS31590 channel display
I found the solution to this problem . If someone accidentally hits the recall button the display channel will show on the TV screen, To correct this problem hit the Info Button and the display channel will disapear. This works only if you have the standard cable box. I have another TV that uses a dual mode cable box, tried this procedure with analog RCA TV but it didn't work. Don't know if this procedure will work for all display problems, but it worked for me.
Posted on Sep 30, 2009
  • 1632 Answers
SOURCE: Sanyo TV DP42647 No picture or sound, remote does nothing
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
Sanyo instruction manuals
Most universal remotes don't have all the functions of the original remote controls.You may be out of luck unless you can find an original remote. There are web sites that sell original remotes. Just Google TV parts stores.
Sep 07, 2014 | Televison & Video
My tv screen changed its resultion dont have the original remote
SANYO GXBG TV REMOTE CONTROL ELECTRONIC ADVENTURE
You can purchase a replacement remote. There are several web sites that have the remote for your Sanyo TV. Just do search " replacement remote for SanyoDP42849. That way you'll have all the fucntions for the TV.
Jun 06, 2014 | Sanyo DP42849 42 in. HDTV
No picture.the word video is only displayed on the screen.
You may need to find the original remote or a sanyo universal remote. And then you press the tv/video to return to standard cable watching. Unfortunately you will to have one of these remotes to fix this. Ask a friend who also has a Sanyo TV set and borrow the remote!
Jan 23, 2010 | Sanyo Televison & Video
CH3 display won't go off! HELP!
HELLO
I don't think you'll get rid of the on-screen ident until you get the original remote. The symbol you need to look for is a TV screen with a cross in it
[+] a bit like this. It is possible that another SANYO remote may do the job for you, but is best to have the remote which goes with the TV.
Hope this helps (:-)
Nov 09, 2009 | Sanyo DS31590 31" TV
Cannot remove channel display from tv screen
Using the tv remote (or selecting TV button on cable universal remote) hit the INFO button. It remove the channel # for me. I might have a different model.
Apr 06, 2009 | Sanyo DS27800 27" TV
Problem with sanyo tv
Check the menus in the TV. Look for a Display menu. There should be an option somewhere to turn this off. I don't know this TV personally, but it CAN be turned off.
Feb 05, 2008 | Sanyo DS32224 TV
Jan 12, 2008 | Sanyo DS31590 31" TV
Channel display
Get an original remote and follow the instructions in the booklet that came with the set. If you have lost this, you may be out of luck. Universal remotes frequently do not cut the mustard!Sanyo, being fairly user friendly, sells replacements, as do others. Look around for one. There is probably a "Display" button or something obvious you need to press to get rid of this. Losing the original remote can be a gigantic "Gotcha!"
Sep 30, 2007 | Sanyo DS27910 27" TV
SANYO TV
The DISPLAY button on the remote will remove the on-screen display, so you either have to order the original remote or look for a universal remote with a "display" button and hope it works.
Aug 02, 2007 | Sanyo AVM-3659S 36" TV
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
