Question about LG Microwave Ovens
LG Microwave white powder inside the oven 1. Cause 2. Fix
MicrowaveSvc
  • 9098 Answers
SOURCE: paint inside microwave oven, Can it be repainted ?
Yes. You need to clean it, sand it shiny, then clean it squeky again.
Then you can get high temperature appliance paint in spray on brush-on form from local appliance part store or places like Wal-Mart and Lowe's.
I would suggest you let it dry overnight with the door open before using the oven.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 17, 2008
rickzilla
  • 706 Answers
SOURCE: LG microwave oven
As long as the waveguide itself isn't damaged, you should be able to replace the shield without issue... That shield only prevents food from splashing onto the waveguide itself and is not part of the microwave RF protection... Check your local hardware store for touch up paint.. shouldn't matter what brand as long as it contains rust inhibitors.. Good luck...
Posted on Aug 23, 2008
SOURCE: lg LMV1630st stainless steel microwave oven
Make sure the door is aligned and closes safety switches.
Posted on Aug 26, 2008
reg501
  • 413 Answers
SOURCE: microwave ovens
The Magnetron has failed, causing the waveguide to become damaged. If the waveguide is damaged/burned the microwave can not be repaired and should be replaced.
Posted on Dec 25, 2008
EwingElect
  • 276 Answers
SOURCE: Paint damaged in side microwave oven
1) How is the cavity damaged? Is it just peeling paint, or is it rust? If it's rust then the microwave could be dangerous.
2) The antenna cap usually has a small hole in the centre, but if there are any other holes in it the magnetron itself could be damaged, and holes caused by the magnetrin arcing.
Posted on Mar 25, 2009
Microwave sparks
If it sparks inside the oven then look inside for any powder paint missing... if so discard. If you has metal shelves or tin foil then don't put metal in when on microwave setting. Some of these metal shelves are for a microwave that is also a convection oven but only in the convection oven setting.
Nov 26, 2013 | Thermador Microwave Ovens
The inside fan comes on when the door is open.
follow this steps and use the VOM for fix it. God bless you
If your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  • Main control boardIf your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
    Jun 18, 2013 | LG LMV1630ST Microwave Oven
    I hv got a haier microwave model HIL 2810EGCB can i use aluminium dish for baking cake
    No! it will cause arcing inside of the microwave oven and destroy the magnetron.
    Mar 15, 2012 | Haier 1.1cf Microwave- White Microwave...
    I have an LG Microwave. A Week back i mistakenly microwaved sausages for 20 min. They got burnt and the microwave also started stinking. i aired it out and microwaved a cup of water twice on separate...
    Hi hafsahparkak,
    Plz follow the steps below once again ...hope it works if not plz revert:
  • 1
    Unplug the oven and unfasten the cabinet body, using a screwdriver. The body should be attached along the back as well as along the sides or bottom.
  • 2
    Slide the cabinet body back slightly to clear any internal brackets, then lift it off.
  • 3
    Clean the oven, using a vacuum with plastic crevice attachment. Vacuum the fan and other internal parts, then vacuum the vents underneath the oven, on the back and inside the chamber.
  • 4
    Reassemble the oven and plug it in.
  • 5
    Fill a small bowl with a 50-50 mixture of water and white vinegar, then set it in the oven and turn the oven on high for 5 minutes. When the mixture boils, it will remove stubborn smells inside the vents and loosen food particles on the oven walls.
  • 6
    Wipe down the oven walls with a clean sponge.
  • Aug 22, 2011 | Viking DMOC205SS Microwave Oven
    What size fuse is a 250v 10a drawing fuse inside my microwave would a 6.3 32mm fuse be ok.its a lg ms-283 mc microwave
    Chances are it is a standard 1/4" x 1-1/4" (6.3mm x 32mm) but I would suggest measuring it to be sure.
    Here's an exploded view of that oven to help in disassembly.
    May 28, 2010 | LG LMV1650SW Microwave Oven
    Burnt hole in metal plate inside microwave oven
    Ok stop useing oven and unplug! THIS CAN BE FIXED!!! Go to a home improvment store and buy a small bottle of white liquid enamal....Clean up the area that is missing and flakeing and then apply the enamel over the hole and let dry overnight! now that the exposed metal is covered back up it is safe to use and will not spark or cause any more soot!
    PLEASE rate my response to your question!
    THANK YOU!
    Jan 08, 2009 | Microwave Ovens
    LG microwave oven
    Aug 22, 2008 | LG Microwave Ovens
    Takes much longer now to heat things
    I think you have two separate problems.
    Taking a long time to heat is almost always a failing magnetron.
    The cover on the side is the waveguide cover. If your waveguide cover is burned or broken, it will need to be replaced.
    It protects the waveguide and magnetron from grewase and food particles, which can cause arcing and damage.
    Hopefully your oven is just under the one-year mark and GE will fix it free under warranty.
    Otherwise, they will replace the magnetron at no part cost, but labor will be your responsibility.
    GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
    May 10, 2008 | GE Advantium 120 Convection/Microwave Oven
    Lg LMV1630st stainless steel microwave oven
    May 02, 2008 | LG LMV1630ST Microwave Oven
    Emerson Mwg9111sl microwave blows 20 amp internal fuse instantly everytime.
    check your thermal fuse its about 2 inches long white on the outside black on the inside it has 2 wires going to it check for
    cotinuity becareful of the capacitor you need to disapate that first by touching the two teminals together with a screw driver
    Apr 01, 2008 | LG LTM9000 Microwave Oven
    Microwave Ovens Logo
    35 people viewed this question
    Top LG Microwave Ovens Experts
    William Miller
    William Miller
    Ross Metcalfe
    Ross Metcalfe
    Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
