My tv goes off the picture turns to a black screen then the menu screen comes up the volume was turning itself all the way off
SOURCE: tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Posted on Apr 16, 2008
mistersony
  • 320 Answers
SOURCE: Sony KDL-32ML130 lcd tv
Not really that tough. Sounds as though the backlight is shutting down, either from a power supply failure, or a failure of the backlight circuit itself. You can verify this by holding a flashlight to the screen in the area where the menu usually appears to see if it displayed on the LCD panel with no backlight. If you can faintly see the menu displayed, your backlight has shut down and the most likely cause is the backlight inverter board, followed by the power supply and the backlights themselves which are part of the LCD panel. If you found this information answered your questions, please be sure to rate it. Thanks!
Posted on Oct 25, 2008
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
SOURCE: samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Posted on Feb 08, 2009
SOURCE: Menu appears by itself. Sometimes stays on, sometimes comes on and then off. Also, some of the light touch buttons stay on and you cannot turn the TV on with a remote.
It's captioning. For me I press my CCD button on my remote until it says OFF.
Posted on Sep 27, 2009
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Dec 23, 2007 | RCA F38310 38" TV
TOSHIBA LED 46L5200U TV where picture stoped working and the volume is working
Check and replace its back-light inverter board. Contact any service technician. Gopakumar Gopalan Google
Feb 24, 2014 | Toshiba Televison & Video
I have a 1999 model...when you turn it on the screen is a black square all but like a picture frame on the outer edge...when i hit the volume the screen comes back for a few seconds and then goes black....
Goe to the setup menu and turn off closed caption.Does it do this on all inputs. Closed caption is only on rf input as far as the tv is concered. If this is happening on input which is connected to cable box or sat reciever call your serv provider.
Mar 07, 2011 | Mitsubishi WS-65907 65" Rear Projection...
Picture has a black image (box that black out part of the screen) that comes on seconds after TV is turned on, leaves when volume is adjusted, then returns after a few seconds. Does not appear when Wii is...
You need to go into your menu and go to close caption and turn off the text screen that some how got turn on, that big black box is call a text screen, and you are not the first person that this has happen too, Take care.
Jan 09, 2011 | Panasonic PT-51HX41 51" Rear Projection...
Television hAs a black box blocking picture in the middle o he screen. when you hit volume the black goes away until the volume icon goes off
Go to ur tv menu.Go in captioning turn off all 1,2,3 and all txt will stop the black box in the middle of the screen.
Mar 26, 2010 | Toshiba 32A33 32" TV
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
Powers on by itself
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Thanks,
Tina
Jun 01, 2008 | RCA 32V420T 32" TV
Hitachi 51F510
Same problem but mine goes black for long periods. Menu prompts still available and volume "meter" on screen is still visible. Have rerouted cable, changed outlets, all to no avail.
Mar 28, 2008 | Hitachi 51F510 51" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
