Question about Belling Ovens
What makes the over trip after it has started to heat?
I have a belling synergie 50/50 oven and the bottom oven kept tripping. I thought it was the element so replaced it. The new one heated up then tripped. I then replaced the thermostat thinking this was the fault. Again it heats up the trips. It would appear to be the selector switch but any thoughts would be appreciated before I spend more cash.
  • 1462 Answers
SOURCE: Main oven problem
I suspect not the oven element at fault. you only way forward is to actually test the resistance of the element to earth with a megga if you can beg the use of one. be cautious about the result as on occasion, elements are only faulty to earth when hot. another way to test if you are cdarefull, is to connect the element to mains independently of the oven and see if the rcd trips
Posted on Sep 22, 2008
  • 4 Answers
SOURCE: lights grill and fan work but oven isnt heating up
On our oven, we have to reset the clock before the oven will work. I think it's because of the automatic timer features.
Yours is a slightly different model, but on ours we have to press the two buttons with arrows on, at the same time as turning the clock dial. Once this is done, the oven should work again.
Good luck.
Posted on Jan 07, 2009
barkencoa
  • 3463 Answers
SOURCE: oven element tripped main fuse box switch
Try running it with the element disconnected, if it does not trip, then element is causing prob.
If it still trips, then look elsewere for prob,.
Please rate my solution.
Thanks.
Posted on Jul 14, 2009
SOURCE: Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Posted on Nov 02, 2009
barkencoa
  • 3463 Answers
SOURCE: belling oven xou592 bottom fan oven not heating up
You need to fit a new oven element.
This is located at the rear of the oven behind a removeable cover, where the fan is
It is a fairly straightforward job to replace.
Hope trhis helps with your problem.
Posted on Dec 16, 2009
Testimonial: "Thanks very much , wasn,t sure whether thermostat could be at fault so this has helped. Will buy an element and fit and let you know outcome. Thanks "
My belling oven won't heat up no light on the dial no fan and no heat what could this be please
Have you checked your consumer unit to make sure circuit breaker has not tripped. I know it sounds a bit obvious but sometimes it is the simplest things that confuse us.
Hope this helps
Jul 07, 2015 | Belling Ovens
Belling Synergie single oven keeps tripping the electric box
Tripping is common when a cable is exposed / burn / damage causing the tripping.
Sep 06, 2014 | Ovens
My Belling Synergie 482BL grill blew out yesterday
It's hard to say without actually seeing it, was it shorting out on the bracket that was supporting it? If so, this would be a weak point on the element and as it broke down it could have shorted out to earth through the bracket causing the bang/flash and tripping the breaker. If an element is just touching another metal part it won't short out because the filament is insulated from the casing. You should be able to find the element code on the casing near the terminals. Hope this helps.
Nov 11, 2013 | Ovens
Replaced element on belling synergie on 2 occasions in the past 6 months. What could be the reason for them blowing?
fan on in oven but not heating up just after the power tripped think because of oven this is not the first time this has happened can you help please
yours shane
Mar 10, 2011 | Belling XOU174 Electric Single Oven
My Belling E641 keeps tripping out. Now the trip
You evidently have an earth fault on the cooker i.e one of the heating elements has failed and the trip switch is operating to prevent you getting a shock.
Most likely it is one of the radiant rings that is at fault but it could also be an oven element.
There is no easy way to tell without checking with a multi-meter for earth continuity between each element and the cooker frame, you can do this with the power off and the meter set to resistance or continuity test.
There should be no reading between healthy elements and earth but a faulty element will normally show a reading when the probe touches the cooker frame.
Dec 30, 2009 | Belling Ovens
Belling oven xou592 bottom fan oven not heating up fully. Fan works and orange thermostat light on but does not heat up. Before this happened it tripped mcb in consumer unit.
Dec 15, 2009 | Belling XOU592 / XOU593 Electric Double...
My Kenmore Continuous Cleaning oven is older - it is running, or not running on a 50 amp circuit breaker. I can cook on the stove top, but the oven will only stay going for about 5 minutes before it trips...
If you are tripping a 50 A breaker, you have major problems. First check the breaker, to make sure it is in reality, tripping at 50 amps. As they get older they can suffer heat damage, and will trip at lower currents. How old is it? Does it visibly look like bad (burnt, etc) Is it loose on the mounting buss? Burnt smell? If everything checks out then go to the oven and look for loose connections. There will be heat where there is a 50 amp current draw. If the oven is suspect, I would seriously consider dumping it as soon as possible. This is serious fire safety hazard. Again, loose connections. Check all of them, both AC+ legs, Neutral, and ground.
KF Groves
Jul 12, 2009 | Kenmore Ovens
Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
May 02, 2009 | Siemens Ovens
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Ovens Logo
26 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
