Question about Building Materials
I have a problem with my Waupaca elevator. The elevator has 4 stops. At one stop and only going down, the elevator exterior door will not open. It can be manually. What gives?
SOURCE: Beetle Convertible window problem
My wife's car is a 2004 convertible. We had the same problem. There is a switch built into the door latch assembly. Whenever you pull either the interior or exterior door handle, the switch lowers the door glass a certain amount.
We replaced the door latch assembly and that corrected the problem.
Posted on Oct 20, 2008
  • 118 Answers
SOURCE: garage door won't open
You probably have a broken spring on your door
Posted on Jan 18, 2009
  • 137 Answers
SOURCE: Remote slide door will not close or open all the way.
there is a cable of wires that lay in the track under the slider they break from normal use.. the harness it fairly easy to change.. when you open the door lok in the opening you will see the harness there in black plastic
Posted on Jan 23, 2009
Doorguy27
  • 30 Answers
SOURCE: 1.3HP CRAFTSMAN CHAMPION GARAGE DOOR OPENER-NEW IN 2004
Well sounds like its a pressure setting. you said you open the door by hand? Was it easy to do? Ask your self this can a 15 year old kid open it and close it? If so then it sounds like its a presure setting There should be two blue slots on your opener with numbers 1-9 says up and down force. Turn the up force towards the bigger number. Just a little bit. But before you do that as the other guy stated make sure that your cables and springs are working. Spring depending on your doors can be in three places but we going to assume you has the most common set up so look over the top of your door (with it closed) you should eb able to see a tube running across there. and somewhere in the in middle a set of spring look at the spring to make sure that you dont see any of the tube showing in the springs. Becare not to touch the spring as they are under a lot of stress.
Posted on Feb 10, 2009
  • 226 Answers
SOURCE: Driver's door is not opening using exterior door handle
Normally it will be the small retainer that holds the inside of the door handle to the part that hooks to the latch assembly. Or it is possible that the door handle part is broken, but not likely. You will have to have the window raised, and remove the door panel and look inside the door panel where the handle attaches to see what the problem is. May help to have a flashlight. These are sometimes difficult to fix as there is not much room to work & the parts have to be attached for the exterior handle to work. Rick
Posted on Apr 15, 2009
Waupaca 3 stop elevator. Power went out. Stuck between floors. How reset elevator to get to proper floors?
There should be an escape hatch above your head on the ceiling panel. Try that but be careful. If not, pick up that phone next to the floor numbers and call the fire department.
Dec 28, 2016 | Miscellaneous
Door latch stuck
Bend down on one knee and use one hand to hold the exterior door handle in the open position while using a screw driver to disengage the door latch by inserting the screw driver's tip into the anchor hole and push the screw driver outward towards the car.
Dec 22, 2013 | Cars & Trucks
We just replaced the "trolley" component of the opener, now when we open the garage door it opens about a foot, then stops like its hung on something... it will go back down. If i help it pass the hun
Check your manual and re-program the up/stop and down/stop position. Also make sure the new trolly is in it's proper position.(in the closed position) Hope this helps
Oct 02, 2012 | Chamberlain 3/4-HP Power Drive Chain Drive...
My ge micro will not stop turning
HELLO.
If by not turning mean turntable fault,the solution is given below in detail.
1 Press "Stop" to halt microwave operation.
2 Press the "Turntable" button once to turn off rotation.
3 Push the door-release button to open the microwave oven if you do not have a "Turntable" button on your control keypad.
4 Lift and remove the glass platter from the oven, then pick up the plastic track with three wheels below the platter. Set aside these parts.
5 Insert the elevated microwave cooking tray into the oven. The tray has three to four short legs that hold it above the bottom of the microwave, keeping it from interfering with the rotating bolt in the bottom center of the oven the drives the turntable. You can now place food on the elevated tray and cook normally without disrupting the drive bolt.
Thanks.
Sep 20, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The power funtion drive on my Invacare Storm TDX 5 wheelchair, which operates the tilt, recline, elevating leg rest and seat elevator has stopped working. The drive switch as it appears on the LED screen...
1) Yes your power seat functions can be programed into your drive 4,You'll need a programmer or have to take it into a shop.
2) yes the chair can be manually elevated down,You'll want to take it to a shop for that ,because it requires jumping the power to the seat elevator and swapping the wires around and I would never recommend my customers to do such a thing because of electric shock or burning up the chair.
If your chair has a four wat toggle switch("what controls your power seat functions elev,recl,telt,ext) If thats what your using right now there may be a red light that comes on in drive lock out ,If that light is not on follow that wire all the way down it may have been pinched or cut.If so it will need to be replaced.
Problems like this one is hard to trouble shoot over text or phone ,if your four way switch cord is cut or smashed .Your gunna have to take it into a shop just to make sure ,It didnt cause any electrical problems in your chair .
Good luck hope i had the chair in front of me so i could help you more.
Jan 15, 2011 | Invacare Health & Beauty
Why won't my vision fitness simple T9500 run? I tried holding down the stop button for 3 seconds. It did clear the screen. Then when I hit start it puts 6000 in the screen and will not run. It beeps as if...
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Jun 14, 2010 | Dmm Vision Fitness T9500 Treadmill
Eletric won't roll up or down. makes clicking noise.
The clicking tells me that the elevator motor is getting power. In my experience, these motors brushes wear out over time, this makes them weaker n slower to the point where they just stop working. You can get a replacement for about 40 bucks.
Before you go and get a replacement elevator motor, using utility gloves, remove old motor. Do this by holding the glass up using clear or duck tape if the window is rolled up, if the window is rolled down, insert a towel or a rag in one of the openings the bottom of the door then carefully remove the elevator motor and seat the glass on the towel, test it's funcionality while still plugged in. Also inspect the elevator hardware to make sure nothing is bent or broken, specially the fastener that holds the window glass to the elevator rail.
I hope this will help you fix your problem.
Good luck
Feb 27, 2010 | 1992 Mercury Grand Marquis
The garage door will go down to the floor and then stop and come back up on its own. also at times will only go down to remain open 3-4 inches
Sounds like you need to recalibrate the stop point. If its coming back up the sensors may be off alingment (make sure the lights green/amber are solid and not flickering) or the door may sense an object that isn there and reverse. You can google Chamberlain powerdrive door opener manual and dwnload it for programing instructions.
Dec 18, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Remote control for garage door suddenly stopped working.
Press and hold for 3 seconds the button on the wall control with the lock icon. There you go.
Nov 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Oct 08, 2008 | 2004 Volkswagen New Beetle Convertible
Building Materials Logo
89 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
