Question about RCA Televison & Video
Dusted inside my RCA tv and now it will not come back on. Can you please give me some ideas as to what might be wrong?
I have a big projection screen (flat) HDTV made by RCA (5 or 6 years old), and when I try and turn it on it makes a weird sqeaky sound, stays on for a few seconds & then powers off (the screen never...
Hi, thanks for visiting FixYa. To give you a better idea about your problem TV. Please place the TV model, is located in the back of TV. is very important to know that information. Could have faulty capacitors in the power supply. I hope you let me know the model TV
thanks
Aug 14, 2011 | RCA Televison & Video
How can i hook my pc up to get sound threw tv and dvd w/surround sound
You would need the following hardware from radio shack.
Male 3mm jack to RCA into the back of the tv.
Depending on how far the TV if from the computer would depend on size of cable.
Now you tv has surround sound?
Or
You want the computer to produce surround to your tv?
I would go with the RCA idea to give you some starting place to produce sound from the PC to the back of the TV. Now this same idea goes for hooking up mixers, amps, ECT
I hope this helps you in your projects
Thanks for using Fixya.com
Jun 30, 2011 | RCA Electronics - Others
Hi there i knocked my computer over the other day and now it wont link to the screen, plus keyboard and mouse dont work, i've looked inside dusted and stuff but cant see much wrong a few loose wires e.g p7...
Please don't misunderstand but maybe you accidentally touch someting inside the system while cleaning it that caused for the computer not to work properly. Be careful in cleaning our computer specially inside. Replug all the links needed because the computer may reconfigurate it again before it will work. If it won't work however, please contact you Hardware IT Technician.
Mar 22, 2011 | Computers & Internet
My RCA tv has been working fine for years. A few days ago it began to have intermittent popping sounds. Picture is clear and sound is good. I recently dusted the back of my set and I'm sure some dust must...
hi there,
if u know how to work with your set u can:
1. open the back cover case of your tv and try to find a foreign objects inside and clean it up with your vacuum cleaner.
2. popping sounds sometimes due to lossen parts, bad socket contacts, too much dust and dirts ,corrosions .and when cleaning you unplug first your TV set to avoid electric shock. i hope this will help a little. Thank You.
Feb 08, 2011 | RCA TruFlat 27F520T 27" TV
Turned on my RCA P46924 today and played fine for 5 min. then picture curved and turned to 3 different colors seperated on same screen. Turned TV off and now will not turn back on. Please help?
Ur tv have convergence problems,before ur convengence ICS totally went dead.U must have tools like soldering iron,solders,solder witch,and know how to solders to fix this problems ur self.Must replaced 2 convergence ICS,and some or all it resistors.Tries websites like Tv repair world.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 28, 2010 | RCA P46924 46" Rear Projection Television
RCA TV that doesnt power on
most likley the capasitors on the power supply board are bad
if u take apart and inspect them u may see the tops have a slight dome shape giving indication they are out of range
Nov 26, 2009 | Motorcycles
When i turn on rca tv it shuts off after about 30 seconds
Hey; applelrton_man;
With out the type and age of TV you own it is hard to determine what is wrong with your TV. Example, if it's a projection, it may be the fly back. Or dlp it may the lamp. You see what I mean.
Please give Fixya the model we will be able to give you a more proper Fixya solution.
Thanks, Big Irish.
Nov 13, 2009 | RCA Televison & Video
My RCA DLP HDTV shows ''Cobwebs''
It is in the top half of the set. You will have to remove the top back cover to clean it.
Jul 09, 2009 | Televison & Video
Partial tv picutre
By distortion do you mean that the top part is stretched? If so, you have bad caps in the vertical circuit. If you are comfortable working inside hte set and can solder, you can fix this yourself. Please post the model number and I can give you the details.
Dan
May 28, 2008 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
