Question about Exercise & Fitness
I have a sole R92 recumbent bike that is showing e-2 motor error. what can be done to fix this?
SOURCE: error message on recumbent bike
The problem might be the gearbox. I know because I have the same problem.  Keys fitness is out of business, but "The Treadmill Doctor" has purchased the inventory of parts for the bikes. They will help you troubleshoot, and have parts available if you need them. The number is 1-888-340-0482. Or, you can go to treadmilldoctor.com.
Posted on Apr 03, 2009
wfservices
  • 262 Answers
SOURCE: schwinn 201 recumbent bike makes clicking noise
Check the tightness of the crank bearings, also the crank fastening nuts (on axle) If its the gears you may have to turn the screws on the rear derailleur to adjust the tracking. The same as the front. Your question is kind of vague so its hard to pinpoint the clicking noise. Could even be a stone in the tire??lol
Posted on Feb 21, 2010
maxtreadmill
  • 832 Answers
SOURCE: Our life fitness 9500hr recumbent bike stopped working
If this unit has not been used for that period of time then the 6v batt has died ans needs replacing call National Gym Parts @ 1-800-496-7278 to order part# LC001.5
HERE IS THE PROCEDURE TO REPLACE THE BATT:
Tilt the bike on its side, remove mounting screws securing the battery to the bracket. Remove the battery just enough to access and disconnect the black (neg) wire from the (-) terminal and the red (pos) wire form the (+) terminal. Replace battery and reverse procedure when installing battery
Posted on Apr 17, 2010
maxtreadmill
  • 832 Answers
SOURCE: Error 3 (E3) on Schwinn 240 recumbent bike. How
No speed/RPM reading, Console displays "E3" error code
Check data cable integrity All wires in cable should be intact. If any are cut or crimped, replace cable.
Check data cable connections/orientation, insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place.
Check magnet position (requires shroud removal) Magnet should be in place on flywheel. If no magnet is present, replace the flywheel or the entire base unit (if unable to replace flywheel).
Check RPM Sensor (requires shroud removal) RPM sensor should be aligned with magnet and connected to data cable. Realign sensor if necessary ( 1/8" clearance between sensor and flywheel) if still error 3 then check the sensor with a multi meter unplug sensor leads attach meter to sensor connectors. Have someone by hand rotate the pedal while you observe the multi meter opening and closing the internal sensor circuit if no change in meter readings then replace the sensor.
Posted on Jun 01, 2010
SOURCE: My "Edge 491r" recumbant bike
Same as above, have an Edge 491 with E1 and need to fix it
Posted on Feb 20, 2011
How to assemble a weslo pursuit ct 4.2 bike video
Weslo Pursuit CT 4.2 Recumbent Cycle: Relaxing Exercise ...
www.kmart.com > ... > Recumbent Cycles
KmartSep 30, 2012 - Arts & Crafts · Video Games · Learning & Development · Stuffed Animals & Plush · Musical ... Weslo Pursuit CT 4.2 Recumbent Cycle 1 ... With a Weslo recumbent bike you can approach exercise with ease. .... Like all in box items it takes awhile to assemble, but works great, and great value for the money.
Weslo Exercise Bike - YouTube
? 2:55
https://www.youtube.com/watch?v=2ZLzpsk4BdE
Dec 22, 2014 - Uploaded by ReviewTube
Weslo Pursuit CT 2.0 R Exercise Bike http://amzn.to/1vgiQjF ...bike assembly,weslo exercise bike amazon ...
Weslo Pursuit CT 42 Recumbent Exercise Bike ... - YouTube
? 1:41
https://www.youtube.com/watch?v=tYdlVsnDNQo
Aug 20, 2015 - Uploaded by Geraldine T. Lane
SEE MORE Best Sellers in Exercise Bikes http://amzn.to/1frY7Yr The 3 Week Diet is an ... Weslo Pursuit CT 42 ...
Weslo Exercise Bike Product Support ' ManualsOnline.
Jan 17, 2016 | Weslo PURSUIT CT 4.2 Recumbent Cycle
Sole R92 pedal resistance doesn't work at all levels
You need service. Someone needs to take a look inside call 877-805-1030
Dec 18, 2013 | Sole Fitness Sole R92 Recumbent Bike
R92 Fitness Bike has no ability to increase its pedaling resistance
You need someone to physically look at this. Call 877-805-1030
What are the benefits of recumbent exercise bike?
Recumbent exercise bikes offer a few benefits. First of all, they have lower back support, which is important for people with low back problems. Another benefit is that put less pressure on the knees compared to other exercise bikes. Moreover, if you have limited space available, these chairs are a great choice since they are very compact.
Feb 07, 2013 | Exercise & Fitness
I have a Rowe ami R92 jukebox, when I turn it on I get error 37
Did you ever get an answer to you question on the error 37 for the Rowe R92 Jukebox
Peter
Rowe R-92 Jukebox
Dec 09, 2012 | Audio Players & Recorders
Have a stairmaster recumbant bike which has generally worked well. Recently however had problems. Start pedalling to activate control panel, input data such as weight, level and time, however as soon as...
If the bike is working with Battery, Replace with alkaline batteries, and clean very well the spring with special electronic cleaner contacts, you can buy in any electronic stores.
2) Tight the connector well, and clean with cleaner contacts.
3) See if the small motor inside is working good, or the wires is faulty , and repair or replace.
LUBE very well the bike, follow the instruction manual steps.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
How to Lubricate an Elliptical Fitness Exercise Equipment
Nov 12, 2017 | Stairmaster 3800RC Recumbent Exercise Bike
Jan 04, 2011 | Fitness Quest Eclipse 1100 Hr/A Elliptical
Error message on recumbent bike
Jan 07, 2009 | Ironman 430r Recumbent Bike
Vital Fitness RB-251 Recumbent Bike Manual
Can I purchase a computer for my RB330P recumbent bike? If so where and how much?
Aug 23, 2008 | Sport & Outdoor - Others
Exercise & Fitness Logo
88 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
