Question about Home
I am unable to get cool water from my shower until it is almost turned back to the off position. The shower may not have been used for a few years, the handle does feel slightly tight
  • 4 Answers
SOURCE: posi temp valve has hot and cold water reversed
Shut off the water, pull the handle and turn the cartridge 180 degrees. then put it back together
Posted on Mar 03, 2009
  • 374 Answers
SOURCE: only hot water, no cold water.
The cartridges in the single handle units are prone to display this issue in hard water areas as mineral deposits such as calcium build up on the stem. The stems also have small rubber band like rings - for lack of a better term- that break apart and can clog the ports on the side where the are on. New stem should resolve the issue totally unless you have had a pipe break or other construction to the plumbing system recently. Thanks for using Fix Ya.
Posted on Mar 11, 2009
jj505
  • 195 Answers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
jj505
  • 195 Answers
SOURCE: moen shower handle keeps turning it wont come to a stop
  • 49 Answers
SOURCE: Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Posted on Sep 03, 2009
Shower valve making banging noise pressure balanced even after changing cartrige
turn hose water off. open facet at lowest level to drain out lines. open a few faucets around the house to let air in. then close everything up. turn water back on. repressurize system by turning some faucets back on. see if it still happens. this is letting air back into any anti-water hammer devices that might be in system. sometimes they loose the air in them that makes them work. this should add air back in. good luck.
Mar 10, 2015 | Grohe Danfoss Tempress ll Tll Shower Valve...
Water on/off is in the wrong position after changing the moen cartridge in my shower
Put your cartridge back the way it was originally. By rotating 180 you reverse the hot and cold. Leave the handle and plastic adapter off. Turn on your water supply and turn valve with the plastic adapter until the water is shut off. Remove the adapter and install it with the set screw for handle facing down. Put your handle back on and that should take care of problem. (I did the exact same thing as you today....small world)
Feb 16, 2013 | Moen Posi-Temp Single HandleTub And Shower...
Low water pressure from my shower.
You probably have a water flow reducer in the shower head. It is a rubber disk with a few holes in it. Just remove it and put the shower head back on. They are installed at the factory to save our environment. (Mine are all removed)
Dec 05, 2012 | Kohler Home
I have a Moen single handle tub/shower faucet. I cannot yet get much pressure to the shower head, there is good pressure from the faucet. I have placed the shower head in vinegar with no improvement. ...
Your problem is in the water restrictor located inside the shower head. All plumbing manufacturers install these small plastic internal blockers to reduce water down to 2.5 gals per minute. In your case, this restrictor is most likely filled with sediment which is restricting it even further. Remove the shower head from the curved shower pipe. Look inside where the water goes through it. You should be able to see the restrictor. Maybe you can flush out the sediment. Otherwise, remove it and I'm sure you'll get more pressure then originally installed. Because most restrictors are sort of plastic screens or cones, I usually put a wood screw through the center of this product and then once a few threads bite in, I use a plyers on the head or the screw and pull outward while holding the shower head in a stable position. If you are able to get it out, technically your "out of code" because now your going to get all the water it can really supply.Most people are delighted to have it gone.
Nimsgame
Feb 14, 2011 | Moen & One Handle Tub & Shower Faucet
Upon installation of a one handle Moen shower valve, water flows immediately in the off position (6 o'clock position) then reduces as valve turns counter clockwise until fully off at 12 o'clock, then comes...
you need to adjust the little gear like..plastic part under handle..plus hot water must be on so that the pressure is balance..the cartridge also needs to be adjusted so water is off on off position
Nov 25, 2010 | Moen & One Handle Tub & Shower Faucet
Water temperature cools when using the shower
the hot water heater may have sludge built up in it. drain a few gallons from hot water tank and see if this makes a difference. you should drain a few gallons fom tank at least 2 times a year, to keep the sludge from building up. ( is the tank big enough for the job)
May 13, 2010 | Home
Have no Cold water coming out of shower/tub. Replaced the Moen cartridge and still, no cold water. When knob is turned right I get hot water when turned left I get a trickle of hot water.?????
Hello
Take the plastic knob off.Turn the brass stem with a pair of pliers until you get it in the proper position.
Off faces down
Cold faces left
Hot faces right
Once in the position screw pastic knob back on.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
We installed a Grohe Relaxa Plus 10 years ago.
Likely a blockage in the line. Corrosion or other damaged parts. Try cleaning the filter screen first. Check for normal water flow without the shower unit attached to the spout. If OK, then the unit is the issue.
Aug 24, 2017 | Grohe 24'' Relexa Shower Bar with Swivel...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
