Question about GPS
How do I go to settings on my tomtom? - GPS
Tomtom xl 325
The GPS usually is set by the sat. You can go to page 37 of the manual for more information
http://download.tomtom.com/open/manuals/xl30/refman/TomTom-XL-en-US.pdf
Mar 15, 2010 | Tomtom One XL GPS Receiver
Need to find application for TomTom Eclipes AVN2210p and download
try these steps:
make sure you are logged in to home program
go to www.tomtom.com/10059...make sure you set the HOME program to the default settings
close HOME rename the TomTom file in 'My Doucuments; to TomTom2, then reopen HOME again, log in, and click on update my device again
Jul 30, 2009 | Tomtom XL 330 Car GPS Receiver
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
TomTom ONE XLNeed to change
google that how to format a your device that would restore all factory settings ...
Jun 01, 2009 | Tomtom Go Plus GPS Receiver
Can't connect my mobile phone to TomTom
Since the phone worked before the visibility issue is unlikely to be the cause. Try plugging your TomTom into your computer. In the my tomtom software, select manage my TomTom. Now find and select the item about mobile phone settings and delete it. That should fix the problem when you next ask the TomTom to set up a connection with your phone.
May 27, 2009 | Tomtom Go 730 GPS
Pairing tomtom go720 with blackberry 8703
On your Blackberry (BB), make sure you have set your blue-tooth properties to show Yes for "Discoverable", then go through the TomTom (TT) to find a phone. Trying to find the TT with the BB will not work.
Once the TT finds the BB, the BB will ask for a code - enter 0000. Once the TT is successfully added to your BB device list, highlight the TT and check device properties - set to trusted.
This should get you there.
Dec 06, 2008 | Tomtom GO 720 GPS Receiver
How do I set my TOMtom to English?
Turn on your TomTom and on the map screen tap anywhere, next tap the wrench at the bottom next to the forward arrow, tap the forward arrow until you see a icon of flags, tap the flag icon and set your language
Nov 26, 2008 | Tomtom ONE 3rd Edition GPS
Tom tom go 300 ''unable to store settings'' ''file access error'
You might have the switch on SD card set to "read only" , This would stop your tomtom being able to write to the SD card ... hence , " unable to store settings " message . .... OR ... the folder where your tomtom wants to store the settings is corrupted ( on your SD card ) so it can't store them.... or similarly , the file is corrupted on the SD card ( maybe the card is damaged ) so the existing file cannot be overwritten . Check out all these possibilities before suspecting any hardware fault on your tomtom ..... GOOD LUCK
Nov 24, 2008 | Tomtom GO 300 GPS Receiver
GPS Logo
24 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
