Question about The Audio Players & Recorders
Hi I have just got a Neostar (used) and when playing a record there is a rubbing sound and the record keeps going slow. Help
I have a recorder that whenever i put in video cassettes stops playing after a few seconds and turns the unit off. Can anyone help. Thanks
sounds like belts and rollers and any sensors you see need to be cleaned - it sounds like the unit thinks tape is at end and is shutting down
use qtip and rubbing alcohol to clean
try using different tape just to make sure it is not just a bad tape
Mar 21, 2011 | Toshiba RD-XV49DT DVD/DivX/VHS...
Samsung VP D31 stopped recording video - just black screen
my samsung vpd230 has stoped recording, just a black screen,
would you also explain what a ccp is,also the words memory stick keeps keeps appearing.thankyou
Apr 06, 2010 | Samsung VP-D31 Mini DV Digital Camcorder
Screeching turntable
Try to pin-point where the sreech comes from. You can do this by keeping your ear close to the turntable. Or you can use one of those 'bent' drinking straws to narrow it down, put one end of the straw in your ear and listen. If you find it's metal rubbing together you can use silcone grease on it.
Mar 25, 2010 | Sony PS-LX250H Turntable
EPG on recorder very very slow
You need to upgrade the firmware on the recorder as this was the problem with my recorder. You may have to use the firmware for SH875M.
Nov 22, 2009 | Samsung Televison & Video
Slow Playback
Sounds to me that the computer is way out of date. Chances are the computer doesn't have enough processing power to support what you're trying to throw at it.
It might help stop/uninstall all other programs running at the same time to give Cakewalk the best chance of working.
Nov 15, 2017 | Cakewalk Guitar Tracks Pro 2 Classic
Blocks of noise
Don't know about the slow motion, but the noise is usually from dirty heads. Just like a cassette player it needs them cleaned periodically. Dip a Q-tip in rubbing alcohol and rub over the entire path the tape takes. You'll see a little block that actually reads the tape. Thats what you need to clean.
Make sure you eject the tape and remove the battery while the tape drive is open to clean it. Rubbing alcohol dries fast but give it an extra ten minutes and check it again.
Video recorder while the heads were dirty will not change however new video should be clean.
You may also have a bent tape carrier that is putting your video off track. It needs to be pushed or pulled to realign it.
It it's not the cause though, this can make playing back the earlier tapes more difficult since they will read and record in a slightly different part of the tape.
Jul 10, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
My VCR tapes skip or only play in fast forward
If you are recording the tapes in a slow speed, then I would suspect that the tracking pulse is not being recorded properly. Since this is a new VCR, return it for an exchange. One of the recording heads is bad.
Dan
May 30, 2008 | Televison & Video
VHS Recording Tape
not much of a help but sounds like your record head is bad on the vhs heads,
use cleaning tape try that, if that fixes great, if it helps but not fully there, you might have to clean them by hand with very soft paper town and rubbing alcohol rub side to side very easy , if none of the above work you have a bad record head or record board, not worth repair vs cost
good luck
Aug 25, 2007 | Philips Magnavox 20MC4304 20 in....
CyberHome DVD Recorder - DVR1600 says No disc when there is a disc
Hi! Pick a jhonson's bud -- dip it into the lens cleaner solution -- rub gently on the lens both clockwise and anticlockwsie -- leave it to dry -- cover up -- run the machine.. but be careful -- don't touch the lens with ur finger and dont try to rub roughly -- lens may go forever. still if the problem remains , replace the lens. chhoton
Aug 21, 2007 | Cyberhome DVD Recorder - DVR1600
21 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
