Question about The Office Equipment & Supplies
I have a Delonghi Perfecta machine which shows a "Close Door" error message despite the door being closed.
Trying to do a thorough clean as per one suggestion but can't get the infuser out and I can't power the m/c down properly because of the error message.
  • 141 Answers
SOURCE: door close message
Witch section are you talking about ????
Posted on Apr 02, 2008
  • 3463 Answers
SOURCE: washing machine wont start - close door message
Most likely faulty door lock or door catch.
To access it, remove the clamp from drum front seal, and remove the seal from the front of the cabinet, undo the 2 screws that secure the door lock, and remove.
To test wether the lock is faulty or not, put a link wire across the (L) and (C)
connections on the lock, the m/c should now work, if it does not, then you have
a more serious problem.
Posted on Nov 22, 2008
SOURCE: door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Posted on Feb 24, 2009
SOURCE: DeLonghi Rialto Expresso Machine EAM-4500
You need to reset it. Unplug machine, remove waste container and tray. Put the waste container back in without the tray and slide a knife under the waste container, close door. Plug in. It should reset. Turn off, replace tray and waste container and turn unit back on.
Easier, call their 800 number and they'll walk you thru it.
Posted on Mar 27, 2009
  • 1833 Answers
SOURCE: my delonghi perfecta plus says
According to your problem, the 'Close Door' message indicates the service door is open. So first make sure that the service door is closed perfectly. If the service door is closed but you get the same error again then check the infuser is inserted correctly.
Open the service door
Remove the drip tray and the grounds container and clean it. Unlock the infuser and pull it out.
Wash the infuser under running water, without using detergents.
Clean the inside of the appliance thoroughly. To remove coffee encrustations from the inside of the appliance, scrape with a plastic or wooden fork, then vacuum up the residues with a vacuum cleaner.
Replace the infuser by sliding it onto the supports and pin at the bottom, then push the PUSH symbol fully in until it clicks into place.
Then close the service door perfectly. If it doesn't solve your problem then reset the settings of the machine. It will solve your problem.
Posted on Aug 13, 2011
Delonghi Perfecta won't froth milk or allow hot water to come out from waterspout
Aug 20, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
C4480 74xl
>Remove print cartridges, >Switch off the machine..>Remove power socket>Wait 10 to 15 mts, >Clean the cartridge & printer contacts. >Switch on the machine wait till message appears for the cartridges>Insert mono cartridge close the access door, check for the message>Insert color cartridge close the access door, check for the message> no error message.. diagnoses end> any error during the cartridge loading replace particular cartridge
Dec 27, 2011 | HP Photosmart C4480 All-In-One InkJet...
The door to my DeLonghi espresso maker (Perfecta) keeps opening
I hope you have solved this problem by now... The door not closing properly happens when coffee grounds build up in the middle of the machine. It tends not to get everything into the waist box. You need a chopstick to fish out the grounds from behind/under the central column of the machine. You'll find a lot of coffee packed in! Then the door will close.
Sep 16, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Hi the door keeps popping open on my perfecta coffee machine?
I have a DeLonghi Magnifica machine and had a similar problem where the door would pop open itself during the brew cycle. I figured out that there is a movable funnel on the inside of the door (part Z in my manual called a mobile drawer) that was sticking and needed to be cleaned. I had to remove two screws on the top of the door to remove this assembly, then soak it in water to loosen up the coffee deposits. After a thorough cleaning the mobile drawer no longer sticks and the door no longer opens by itself.
Be careful to make sure that you do not lose the little spring mechanism that keeps the mobile drawer in the correct place. I took pictures to make sure I knew how to put the unit back together again. Best of luck.
Apr 28, 2011 | DeLonghi ESAM6600 Espresso Machine
I'm getting the "generic alarm message even though I've cleaned my DeLonghi Magnifica. What do I need to do next?
Not good; from page 21 of the owner's manual: If the message is still displayed after cleaning, contact the service center.
The good news is that when I had to send in my ESAM3500 for warranty repair, I called DeLonghi (1-866-528-8323) and got through to their repair center without difficulty. They sent a new shipping box and wrapping material, and a prepaid shipping label to a repair center about 100 miles away. I got my repair ESAM back in just a week. I hope that your experience goes as well. If it's out of warranty, though, it could be expensive.
May 17, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Milk not frothing, internal door not positioned
Make sure that the milk container lid is thoroughly clean and that running hot water flows through the openings freely. Make sure you're using 2% milk. Make sure it's cold 2% milk.
The front door problem may be two loose screws in the back plane that holds the infuser unit. Turn off machine; remove the infuser unit and thoroughly clean. Behind the now removed infuser unit you will see two hex head socket screws; use a hex screwdriver to make sure these haven't come loose. If so, tightened them, but don't overdo it. Now reinsert the infuser and see if the door latching problem has disappeared.
Apr 28, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Adjustment to door hinge, as door does not close completely
In most cases door hinges needs to be replace but some time with old stile ovens and ranges help this trik:
1. Put small towels on right and left hinge between the door and range/oven body
2. Close door and gently push like you try to close completely.
3. Try several times.
4. Open door, remove towels and see if it helps
5. If not replace hinges
Nov 29, 2008 | DeLonghi Kitchen Ranges
43 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
