Question about Ricoh Office Equipment & Supplies
Ricoh mp c2050 show sc452 error - Ricoh Office Equipment & Supplies
M2Tech1
  • 313 Answers
SOURCE: Ricoh copier MP 6000 error code
THIS IS USUALLY FOR THE FUSER SECTION IT MAY BE THAT SOME TONER HAS BUILT UP ON THE THERMISTOR AND IT AINT READUNG THE TEMP PROPERLY AT WARM UP OR ON A RUN IT HAS TO OVERHEAT TO GET RIGHT READING TAKE THE FUSER OUT CHECK THE THERMISTORS.. YOU COULD ALSO GO INTO THE SERVICE MODE VIA CLEAR ALL THEN 107 AND HOLD DOWN THE RED STOP BUTTON TILL THE SCREEN CHANGES IF YOU LOOK FOR COPIER SP IN THE FEED SECTION THE FUSER SETTINGS ARE THERE YOU CAN OPEN FUSING TEMP AND CHECK THE TEMPS AT THE TIME TO SEE IF THEY ARE RIGHT.. IF IT SEEMS RIGHT IT MIGHT HAVE BEEN A READ ERROR AND BY GOING INTO MODE AND LOOKING FOR 5- 810 YOU CAN RESET THE SC TURN OFF AND THEN BACK ON IT SHOULD CLEAR... GOOOD LUCK A
Posted on Jun 26, 2009
  • 5 Answers
SOURCE: Sir, My copier model RICOH MP
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Posted on Sep 06, 2010
Testimonial: "Sir, Thank you so much for your help, let me try in my copier and revert back once the problem is solved. Thanks Gopalkrishna T N"
  • 398 Answers
SOURCE: Problem with the Ricoh mp c2800 Ricoh error code
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Posted on Nov 15, 2010
santosj27
  • 263 Answers
SOURCE: I have emptied the waste
There is no need to do that. Make sure the sensor is not out of the place.
If you take the wast bottle you will see a little sensor. Make sure is placed correctly.
By the way, what waste bottle is mentioned in the screen????
You have another waste bottle on the left of the machine.
Take the screws and you will see a white plastic bottle. Just empty it and your problem is solved.
Be careful, it is a little messy
Posted on Feb 27, 2011
Testimonial: "Thank you so much - another lesson learned - always happens on a Sunday! Several days better than Ricoh service! "
  • 13 Answers
SOURCE: MY RICOH AFICIO MP C6000
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Posted on Mar 05, 2011
What is error code sc565?
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Jun 25, 2016 | Ricoh Compatible 4 Color Set Aficio MP...
How to fix colour position in ricoh c2050
tthe machine can do autocalibrattion,
see the video
Oct 05, 2015 | Ricoh Compatible 4 Color Set Aficio MP...
How to reset login name and password for ricoh 2075
The default is admin and no password.
If this has been changed you can reset the admin pass by logging in as supervisor and no password.
This form might help if you are still having trouble from there.
How do reset the administrator password on the Ricoh Aficio MP C2050
Jun 04, 2014 | Office Equipment & Supplies
I have an error on my gestetner mp c2030 with code sc222, please help me.
Problem with the yellow laser unit. Probably need a tech for that one.
May 20, 2014 | Ricoh Compatible 4 Color Set Aficio MP...
2030 sc573 code
IT TELLS YOU THE TERMISTOR HAD TO BE REPLACED & LATER YOU TO HAD TO RESET THE MACHINE
Sep 14, 2013 | Ricoh Compatible 4 Color Set Aficio MP...
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
Mar 05, 2011 | Ricoh Aficio 1035 Copier
How to solve error SC452 for colour copier
sc 542 is the fuser error code. please check with a ricoh tech to fix it.
Jan 03, 2011 | Ricoh Office Equipment & Supplies
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
163 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
