Question about Sewing Machines
Hi just bought a husvarna Topaz 50 I was doing a embroidery design no 1 when it was 10 min of finishing it is come up with the machine need to rest it is stuck on that for 4 hours can I do to fix it
  • 192 Answers
SOURCE: Misalignment when embroidering with husqvarna designer 1
Sorry that I did not see this sooner.
It sounds like you should have your embroidery unit serviced. Sometimes they will accumulate lint on the slide rods and it inhibits the movement of the mechanism as if you were to bump into it while it is trying to move.
Quite often, this will happen repeatedly in the same point in the design and make people think that there may be something wrong with the design. But, usually it is just that the embroidery unit can't move freely.
Posted on Sep 30, 2008
  • 152 Answers
SOURCE: husqvarna viking designer 2 embroidery machine. Wont work on my
Buy a PC, or get the program that mac has that supports pc programs. I've seen it work so I'm sure it's an optioin. Mac people don't like the program, but it will create an environment that supports PC programs.
Posted on Oct 24, 2009
  • 371 Answers
SOURCE: I the floppy discs that control my Designer 1 embroidery machine
You can have replacement discs ordered from Husqvarna Viking. Visit an authorized Husqvarna Viking dealer for them to order the replacement discs. However, you might luck out and they have some already on hand from a scrapped machine or a trade-in. You can find your nearest dealer by visiting the Husqvarna Viking website - http://www.husqvarnaviking.com and clicking on dealer link down the left side of the page.
Good luck.
Posted on Feb 13, 2010
RichSew
  • 191 Answers
SOURCE: I need to download a machine embroidery hasp for
A hasp is also called a dongle, it comes with the software that you purchased. There is no other way to get a hasp/dongle.
Posted on Aug 23, 2010
RickE1
  • 202 Answers
SOURCE: Embroidery foot rest on hoop
Have you calibrated your machine to the hoop? Read that part of your user manual, it sounds as if it needs the hoop calibration.
Rick
Posted on Apr 15, 2012
How do i remove the embroidery unit from the topaz 40
Do you mean the Husqvarna Designer Topaz 40? If so, first make sure that the unit is in Park. You need the sewing machine on to do this. Select the Park Position on the Embroidery Stitch-Out menu. This screen is accessed after you choose a design and press Go (at the bottom of the touch screen on the left). Then press the release button on the bottom of the left hand side of the embroidery unit.
The directions to remove the embroidery unit are in the manual on page 6:3 (page 69 of the PDF). The manual is available from the product page: http://www.husqvarnaviking.com/en-US/Machines/DESIGNER-TOPAZ-40 . Scroll down and look on the left side of the page. The direct link to the manual is http://www.husqvarnaviking.com/SiteMedia/Products/Machines/DESIGNER-TOPAZ-40/Manual/Topaz40-manual-EN.pdf .
I hope this helps.
Dec 31, 2016 | Sewing Machines
Do you know where I can get a service manual or parts list for a Designer Topaz 50 model?
Search the internet for:
Manufacturer + Model + the word "manual" or "parts"
Dec 31, 2015 | Husqvarna Sewing Machines
Hi. I have a commercial one head tajima embroidery machine. I was sewing and realized I had no thread on one bobbin so I stopped the machine. Instead of continuing on, I decided to start all over with a...
Your new embroidery program has to be loaded first. The 2b7 is referring to needing instructions or in other words the embroidery program has to be loaded. Shut the machine down and turn the machine back on and load just as before.
Jul 06, 2017 | Sewing Machines
Where to buy another creative blank pfaff 7570 card
try contacting pfaff customer & ask them if a pfaff dealer would carry them
also try
sewingpartsonline.com
May 02, 2012 | PfaFF Creative 7570
Good luck.
Dec 29, 2009 | Husqvarna Designer I
Once I set up my design card and select design, the needle moves
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
  1. How long have you had your machine?
  2. How long have you been doing machine embroidery?
  3. Do you have a manual for your machine?
  4. Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
  5. Have you taken lessons for your machine or for embroidery?
  6. When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
  • Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
  • Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
  • Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
Feb 03, 2009 | PfaFF Creative 7570
Aug 22, 2008 | Husqvarna Designer I
Will a Husqvarna #1 Plus embroidery unit work on a Husqvarna Rose machine?
I am sorry to inform you that Husqvarna # 1 embroidery unit does not fit onto the Rose machine. The terminals on the Rose is upright, while on the H # 1 it is flat. If you want to do embroidery on the Rose, you will have to purchase the embroidery unit.
Sad but true
Jan 20, 2008 | Husqvarna Rose
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
