Question about Haier Washing Machines
I have a haier portable washer model xqbm22-C. Once the tub is filled, I have to turn off the faucet and stay by the washer to turn it back on. It drains and spins just fine, the hose isn't clogged.
SOURCE: washer won't spin
Where is the outlet filter?
Posted on Dec 18, 2007
  • 3 Answers
SOURCE: frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Posted on Jul 28, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore washer...the water just runs it never fills up.
I have seen this problem numerous times on service calls. It sounds like you have a siphoning problem. The key symptom is the wash tub that continously attempts to fill, but cannot achieve the proper water level. This is often caused by not having an air gap on your drain line, improper placement of the drain hose, or a standpipe that is too small in diameter. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If you place the drain hose in the standpipe too far, or seal the top of the standpipe, this can cause a vacuum which will cause the symptoms you describe. A tell-tale sign will be a sucking noise as you pull the drain hose from the standpipe. Read through the link I provided. If this does not correct your problem please post back and let me know before you rate this solution. This way I can try to assist you further. I hope this corrects your problem.
Posted on Feb 25, 2009
  • 4088 Answers
SOURCE: When tub filling, it drains out at the same time.
The outlet of the drain hose must be higher than the water level inside the tub--normally the pump inside removes the water when needed. Get a plumber to install a proper height drain pipe for you.
Posted on Jul 16, 2009
SOURCE: Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
Posted on Jan 12, 2010
Haier washer model xqbm22-c, fills with water and won't wash or spin, just hums through cycle and will drain. What are possible problems?
bad water pressure switch, bad door switch? bad motor coupler and or belt. the water pressure switch does not control the spin though? so I suspect door switch or coupler
Mar 07, 2015 | Haier Washing Machines
When the washer fills it overflows, what causes that?
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Mar 02, 2011 | Haier XQBM22-C Top Load Washer
Doesn't fill water
Assuming that the water is working from the faucet, the water valve is your issue. Fairly easy to replace if you're mechanically inclined.
Jul 07, 2010 | Haier XQBM22-C Top Load Washer
Jul 16, 2009 | Haier XQBM22-C Top Load Washer
Caster kit
try this site www.repairclinic.com and call 800-269-2609
Apr 04, 2009 | Haier XQBM22-C Top Load Washer
Need a manual or the basics on how much detergent and what to do to use my Haier XQBM22 C washer
I have a problem with my Washer dryer Combo on the front it seems like the machine froze and just says CE if you can help me with this problem It will much appreciated.
Jul 29, 2008 | Haier Washing Machines
Haier XQBM22-C washer stopped spinning
It still doesn't work! I don't know how to fix it.
Mar 07, 2008 | Washing Machines
Washing Machines Logo
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
