Please explain how to replace a thermostat to chiller
2 Suggested Answers
  • 51 Answers
SOURCE: i've an alram in my carrier chiller model 30XA1202
TURN OFF THE BREAKER TO THE UNIT AND UNPLUG IF
POSSIBLE...WAIT 10 OR 15 MIN. AND TURN THE BREAKER
ON THEN PLUG THE UNIT IN....IF THIS DOESN'T WORK YOU MAY HAVE TO REPLACE THE BREAKER OR TRY A DIFFERENT
OUTLET AND WHILE POWER IS OFF CHECK ALL WIRE CASINGS
AND CONNECTIONS FOR GROUNDS OR SHORTS.
Posted on Apr 13, 2010
My Samsung 4 door refrigerator quit working. The chiller and freezer are working. What could be wrong?
as the freezer section is working , It could be a thermostat for the fridge section
If you have some mechanical and electrical knowledge you could possibly do a DIY repair with a new unit from the service dealer agent spares
The only other option is to load the unit onto a truck and take it to a service agent for repairs
Feb 23, 2016 | Samsung RF32FMQDBSR 32 cu. ft. 4-Door...
Havomg trouble with food in top chiller freezing
check damper vents and cold control thermostat
Feb 17, 2015 | Refrigerators
Has anyone replaced a compressor relay on this chiller? Looks like it is not designed for replacement, but if it can be done with a generic relay I would like to know. Thanks.
The cost of one of those compressors is over $100. When you factor in tax and labor you're better off junking it. Its also possible you have a compressorless cooler called Peltier.
Jul 30, 2014 | Avanti WC1500DSS 30 Bottle Wine Chiller...
The freezer is running but will not switch off we have replaced the thermostat
loose clamp on,thermostat sensing bulb (c and s)
check position and tighten.
Chiller tray out of position(s) check and reposition
God bless you
Oct 30, 2013 | Frigidaire 20 cu. ft. / 566 liter Upright...
What are the recommended aquarium chiller brands available in the market?
I highly recommend you to get a USA Prime Aquarium Chiller you wouldn't be disappointed. You can also get chillers from Aqua Logic Aquarium Chillers, Deltec Eco Cooler Aquarium Chiller, Coolworks - IceProbe Aquarium Chiller, Oceanic Aquarium Chiller, TECO SeaChill Chillers and Tunze Aquarium Chiller the all solid chillers companies.
Aug 13, 2012 | Fish
Honywell whine chiller model 88058 not working
Hello friend, i had the same problem and it was solved replacing largest capacitors on board, they are 2 x 120uF(120V). You must to check that both original capacitors be damaged, you can to see it if they are inflated on the top
Jul 23, 2010 | Honeywell Consumer Products Model...
I have a watercooler that freezes. Water will not come out of the spout because it is frozen inside the system. it is not the temperature gage on that back of the machine. I have experimented with that.
no its the thermostat in it thats running out of true,,it telling the chiller the water is still to hot so the chiller freezes it some more,,change the thermostat its packed up,,
Jun 11, 2010 | Microwave Ovens
I've an alram in my carrier chiller model 30XA1202 which reads (electrical thermostat interlock or electrical box failure) and as aresult the chiller does not start. please advise
Apr 01, 2010 | Heating & Cooling
Part no. expansion valve of Air cooled chiller
On a chiller with semi hermetic compressors can have different types of thermostatic expansion valves for metering. As far as a number, you will have to go to the evaporator to look at the tx valve and get the numbers. It may be a single ported, double ported, be externally equalized or not. You have to get the copper line sizes in and out also if you are planning to change the valve out. The valve will also have the type of freon the system uses if for some reason the data plate is worn off. That's the place to always find out is the expansion valve. If you need information other then what I have given you, contact me and I will help you.
Sincerely,
Shastalaker7
Mar 15, 2010 | Heating & Cooling
Chiller wiring diagram
Contact the manufacturer through the tech support line located in your owner's manual.
Jan 29, 2010 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
