Question about Refrigerators
How to fit a beverage thermostat to chill not freeze or fridge
ngfam1
  • 639 Answers
SOURCE: Hotpoint FFA90N fridge freezing everything
Peace Friend,
ngfam1 At your service!
Ready?
it sounds like the thermostat and it is not easy to do if you have never done this before, it's better left to a professional!
What type fridge,model and age?
If not only a trained tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Posted on Sep 04, 2008
SOURCE: Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
behind or inside the digital display casing-mike
Posted on Sep 30, 2008
  • 478 Answers
SOURCE: hotpoint larder fridge RL150G keeps freezing at the back fitted n
flap controling tempature not closing to controle tempature 9inside ref
Posted on Dec 10, 2009
  • 117 Answers
SOURCE: Hi my Samsung fridge freezer
some good stuff on youtube re
samsung fridge freezer help
also samsung diy video help
Posted on Oct 19, 2010
  • 112 Answers
SOURCE: My True beverage fridge is
Sounds like a bad thermostat. Normal setting is 3 to 5, with 5 being colder, and in my experience, more common. Prices vary but a thermostat is $50 - $75 labor should take no more than two hours - (less if you have the unit completely empty and warm when the tech arrives). The sensor goes into a sheath on the coil so if its cold there can be ice jamming the sensor from coming out or the new one from going in. The thermostat can be calibrated sometimes but it will generally cost the same with less reliable results.
Posted on Dec 12, 2010
Won't Chill or freeze. The thermostate was replaced.
Did you change the thermostat or the thermistor? Thermistor is probably your problem.
Jul 24, 2015 | GE Profile PSW26P Stainless Steel Side by...
Chill parts weber
I have call 973-492-3253 nyyankee690@aol.com
Sep 16, 2013 | Weber Chill 05-161 Beverage Cooler
Daewoo american fridge freezer not freezing and not making ice
I think it is your thermostat this controls the motor theirs a top 1 & a bottom 1 they both control the motor 1 4 freezing the other chilling because u say they are both not working it is also posable that ur f/frezer may need re charging
Sep 03, 2012 | Daewoo Refrigerators
The lower part of my samsung cooltech fridge is freezing all food.
Hi nalin, sounds like you may have a problem with with your defrost timer. Defrost timers can fail due to wear and tear. If this happens during the cooling mode, it will allow excessive frost to accumulate on the cooling coils causing the refridgeration compartment to over shoot its chilling operation in turn causing everything to freeze. Best bet would be to call up a local Appliance Service Technician while the fridge is still manageable so you save on time and money. Also it wouldnt be a bad idea checking the thermostat rotational knob on the rear inner wall of the fridge (if there is one) just to make sure that the machine isnt fully dialed to max chill, hope this helps.
May 01, 2011 | Samsung Refrigerators
I have a true GDM46 and I cannot get the thermostat to adjust to a temperture of 36-40 degrees. What number should it be set at and why does it goes below or above the set you are trying to get. I put...
Did you fit a manufacturers original or an after market model?
When the thermostat was replaced was it fitted to exactly where the original thermostat was fitted?
These things are tempremental and must be fitted just so.
Mar 30, 2011 | True GDM-7 Beverage Cooler
There is a long wire that comes from the inside that is covered by plasting tubing sitting in the refrigerator that I believ is the thermostat and I am not sure where it is supposed to go, any answers. ...
You are correct. Your thermostat is probably bad if things are freezing in your fridge. I don't know where it goes either except in the fridge side. I don't know what kind of fridge you have, over under or side by side?
Aug 26, 2010 | Refrigerators
My True beverage fridge is freezing the beverages on a temperature setting of 3. The dial goes up to 10. What could be the issue and how much approximately to fix?
Aug 25, 2010 | True TD-50-18 Beverage Cooler
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Beverage-Air DD50 Commercial Keg Fridge Not Cooling
The starting components on the compressor could be going bad. You need to turn off the thermostat and then after about five minutes turn it on while listening to the compressor to hear if it kicks in, if it doesn't then you might have faulty starting component, more likely the overload.
Jun 26, 2008 | Beverage-Air DW49 Stainless Steel Beverage...
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
