Question about Honda Boating
How do you change lower end oil in a 20 hp 4 stroke Honda outboard
    Top Expert:
  • Honda Master
  • 24,322 Answers
If you mean engine oil in the sump, remove the sump plug at the base of the sump.
Posted on May 20, 2017
I have a 20 hp mercury outboard serial#06082001.I want to know what year it is and if it's 2 or 4 stroke
If you drop the first zero it would put it at 1981.
http://www.themarinedoctor.com/msn.pdf
this site gives a different answer, as 1980- 81, so close. It SUGGESTS it is a 4 stroke engine.
http://www.boats.net/parts/search/Merc2/Mercury/25%20%282%20CYL.%29%282-STROKE%29%28International%29/parts.html
It is likely a 4 stroke, but I won't give you a definitive answer, due to the damage it can cause with a guess!
A four stroke running with two stroke oil will just smoke, but a two stroke with no oil will seize and leave you stranded on the water with a seized engine!
A four stroke engine has valves operated by push rods or a pulley and a chain, a two stroke just has a head. Take a look at the engine and it should be obvious.
For your first service, I would suggest you go to a marine engineer. Ask all the questions, and get the right answers. When I had my 1986 Evinrude serviced, i typed a list of questions and left the list with him. i asked him when I picked up the boat and wrote the answers down. The first one was 'petrol to oil ratio and which is the best oil'. A basic service will cost you a hundred bucks and you will have some comfort that you are unlikely to break down, 6 miles offshore with only a paddle :)
https://www.google.ca/search?q=20+hp+mercury+outboard+serial%2306082001&ie=utf-8&oe=utf-8&gws_rd=cr&ei=uwm-WKjHK6SUjwSApJLQBw#q=mercury+outboard+serial+number+lookup&*
Mar 07, 2017 | Mercury Boating
Tip
Outboard motors
Keep the gas in your outboard new/clean with new oil every 6 months..Keep your motor covered when not in use, Dirt dabbers (dobbers) will build nest under the hood and break loose and ruin your motor, ,,Change your water pump and thermostate every year when motor is used a lot.....Dont run stainless steel props on small hp motors ,when you hit a log it will bend your prop shaft costing big $$$ to replace..Ck your lower gear oil if water is noted ,replace lower seals...Dont buy used motors unless you run a compression ck....ck for water in gear case , Dont buy 4 strokes to heavy to slow to many parts AND are being replaced by fuel injection 2 strokes .... Dont buy FORCE motors not made by mercury no parts being made and or extink and pure junk . Etex best motors , .
on Mar 16, 2011 | Boating
Where is the oil filter located on a 2004 Yamaha outboard two stroke motor
Some links including a video of how to change the filter. In such questions horsepower is useful along with year :>) Oil filters would only be on a 4 stroke though to protect the engine oil. Your two stoke doesn't have filters in the lower unit. There may be a strainer in the two stroke oil tank.
check page 31 here
http://www.yamaha-motor.com/assets/service/manuals/1/LIT-18626-07-03_1415.pdf
Google
year make HP manual
http://www.bing.com/search?q=oil+filter+located+on+a+2004+Yamaha+outboard+two+stroke+motor&form=PRHPR1&src=IE11TR&pc=EUPP_HRTS
Jul 04, 2016 | Yamaha Yamalube Outboard Oil Change Kit...
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
http://www.cottagetips.com/tips/boat-motor-gas-to-oil-ratios
Apr 15, 2016 | Boating
Mercury 1989 60 HP Outboard Motor manual to find gas to oil ratio
50:1 But if your doing mostly low rpm cruising (trolling) then you could reduce that a bit to 75:1 to help reduce smoke. If you do mostly mid to higher rpm cruising, then 50:1 (1 pint to 6 gallons. )
Or 200mls in 20 liters if your Canadian.
Feb 26, 2016 | Seloc Mercury Outboard Repair Manual, 1965...
Water got into the engine oil of my 8 hp 4 stroke when on the boat only as troller
Water gets in your engine through the exhaust with the boat speed! Lift that engine when not in use!
Oct 16, 2014 | Mercury Marine 8hp & 9.9hp 4 Stroke...
How do I set the timing on my Honda 7.5 hp 4 stroke outboard
if you havent moved the ignition plate etc then remove cam belt and put top piston to tdc and the cam pully to tdc ( mark on head ) refit belt and rotate engine by hand to check nothing catching then try !
Mar 07, 2014 | Boating
90hp 4 stroke suzuki outboard how do i reset the oil alarm?
TO RESET:
1. TURN IGNITION KEY ON
2. PULL OUT THE EMERGENCY STOP BUTTON 3 TIMES IN TEN SECONDS, A SHORT BEEP WILL BE HEARD IF CANCELATION WAS SUCCESSFUL. TURN KEY OFF AND PUT EMERGENCY STOP LANYARD BACK ON ITS BUTTON
Apr 11, 2009 | Sport & Outdoor - Others
Boating Logo
27 people viewed this question
Top Honda Boating Experts
Fabrice Wolters
ROBERT GARCIA
ROBERT GARCIA
Are you a Honda Boating Expert? Answer questions, earn points and help others
