Setting it up,I have tried twice - Televison & Video
My kindle fire hd will not load, even when I try to slide to put in my password to unlock it, a yellow box comes up around it I tried restarting it , no fix help!
Try this:
Swipe from the top with two fingers separated
Tap on More twice
Tap on Accessibility twice
Explore by Touch - turn Off
Voice Guide - turn Off
On the Fire HD2 and Fire HDX (2013 models):
Tap on Settings twice
Explore by Touch - Off
Screen Reader - Off
Apr 19, 2015 | Amazon Kindle Fire HD
I am trying to unlock the region code for Sony BDP-S5100 with the URC7740. The hack program refers to "press and hold the &#147 key. Where or what is "&#"?
I would have to guess, that is probably not the correct remote. I feel I must inform you, trying to upgrade your firmware, from an unsavory hacker, can turn your unit into a brick(doorstop). IMO, proceed with caution.
Jan 14, 2015 | One For All URC 7740 Remote Control
Bdv e3100 region free
try this
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until the DVD button flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 1891 (this sets key 1 - the DVD button flashes twice)
8. Hold the magic button until the DVD button flashes twice.
9. Press 994
10. Press Magic Key (don't hold)
11. Press 2552 (this sets key 2 - the DVD button flashes twice)
12. Hold the magic button until the DVD button flashes twice.
13. Press 994
14. Press Magic Key (don't hold)
15. Press 0953 (this sets key 3 - the DVD button flashes twice)
16. Hold the magic button until the DVD button flashes twice.
17. Press 994
18. Press Magic Key (don't hold)
19. Press 2214 (this sets key 4 - the DVD button flashes twice)
20. Hold the magic button until the DVD button flashes twice. .
21. Press 994
22. Press Magic Key (don't hold)
23. Press 0795 (this sets key 5 - the DVD button flashes twice)
Done - the remote is now programmed and ready to use
Oct 16, 2013 | Sony BDV-E3100 5.1 Channel 3D Blu-ray Disc...
I bought a Sony BDV-E570 in US and it came locked for region 1. As I live in Brazil, I need to run region 4 dvds. Do you know how to unlock it? Thanks
NO LIABILITY IS OFFERED HERE!! THIS IS A HACK!!!
Full procedure for a oneforall remote is as follows:
1. Press DVD
3. Press 0533
4. Hold the magic button until it flashes twice.
5. Press 994
7. Press 00189 (if your oneforall remote uses 4 digit or 3 digit codes, use less leading zeros)
8. Press 1 ( this sets it to key 1 - it flashes twice )
9. Hold the magic button until it flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until it flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until it flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until it flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDV-E370 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The 24p light will start flashing. (Centre light)
3. Put the player back into standby with the Sony remote.
4. Hard reboot machine (remove power)to prevent the 24p light flashing indefinitely.
5. Next time you turn on the player it will be region free for DVD playback.
This worked for me, but obviously I accept no liability for anyone who tries it on their machine.
Mar 23, 2011 | Sony BDVE570 Theater System
How to unlock region free on U.S sony bdp-s350
Sony BDP S350 bluray - unlocking to region free Yes, it is possible, but you'll need a programmable remote - most use the "one for 3/4/6/all". You can hack it by using the same code as for the bdp-s350. Follow the instructions exactly and it should work - mine does.
Programming the 7040 OneforAll remote to enable region free playback of DVD's on the Sony BDP-S350 Quote: 1. Press DVD 2. Hold the magic button until the DVD button flashes twice. 3. Press 0533 4. Hold the magic button until the DVD button flashes twice. 5. Press 994 6. Press Magic Key (don't hold) 7. Press 1891 (this sets key 1 - the DVD button flashes twice) 8. Hold the magic button until the DVD button flashes twice. 9. Press 994 10. Press Magic Key (don't hold) 11. Press 2552 (this sets key 2 - the DVD button flashes twice) 12. Hold the magic button until the DVD button flashes twice. 13. Press 994 14. Press Magic Key (don't hold) 15. Press 0953 (this sets key 3 - the DVD button flashes twice) 16. Hold the magic button until the DVD button flashes twice. 17. Press 994 18. Press Magic Key (don't hold) 19. Press 2214 (this sets key 4 - the DVD button flashes twice) 20. Hold the magic button until the DVD button flashes twice. . 21. Press 994 22. Press Magic Key (don't hold) 23. Press 0795 (this sets key 5 - the DVD button flashes twice) Done - the remote is now programmed and ready to use Quote: 1. Now to make your player region free use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed 2. Make sure there isn't a disc in the machine. 3. Now on the OneforAll remote press 1, 2, 3, 4, 5 (The blue 24p light on the player will start flashing) 4. Put the player back into standby with the Sony remote 5. That's it, the next time you turn on the player it will be region free for DVD playback If the blue 24p light doesn't flash then it hasn't worked, try a new set of batteries and start a fresh Good luck
Dec 02, 2010 | Sony BDP-S350 Blu-Ray Player
How do i get this remote programed to work with my television?
I hope this would help you.
1, Turn on the tv.
2. On the remote control, press the tv key once.
3. Press and hold SET until the LED blinks twice, then release SET.
4. Use the code to locate the typ of device and brand name and then enter the first four digit code for the device. If performed correctly, The LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the tv and press power once. The TV should turn off. If it does not repeat steps 2 to 5. trying each code for your brand until find one that works. If it doesn't work, try searching for you code.
BTW, I don't know the brand of your tv so you might as well try these steps to search for you code but if you want to use the steps above just reply to this and send me the brand of your tv so i can search for the code.
1. On the renote control, press TV once.
2. Press and hold SET until the LED blinks twice, then release SET.
3. Enter 9 9 1. The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
5. To lock in the code, press and release SET. The LED will blink twice.
Jun 10, 2010 | One For All URC-6131 Remote Control
Fix my sony BDP-S550 to be region free
Full procedure for a basic one-for-all remote this is the only way that this DVD player can be set to region free. You can also buy one ready programmed but this is too easy with the remote.
1. Press DVD
2. Hold the magic/set button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic/set button until it flashes twice.
5. Press 994
6. Press Magic/Set Key (don't hold)
9. Hold the magic/set button until it flashes twice.
10. Press 994
11. Press Magic/Set Key (don't hold)
12. Press 00255
14. Hold the magic/set button until it flashes twice.
15. Press 994
16. Press Magic/Set Key (don't hold)
17. Press 00095
19. Hold the magic/set button until it flashes twice.
20. Press 994
21. Press Magic/Set Key (don't hold)
22. Press 00221
24. Hold the magic/set button until it flashes twice.
25. Press 994
26. Press Magic/Set Key (don't hold)
27. Press 00079
The remote is now programmed and ready to use, to make the BDP-S550 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it. It should read "HOME" on the front panel.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The blue 24p light will start flashing on the front panel
4. Next time you turn on the player it will be region free for DVD playback
Dec 11, 2009 | Sony BDP-S550 Blu-Ray Player
I need the codes to program it to my orion tv and the onefor all website is useless
The Orion TV codes for the URC-3021 are: 0236 and 0463.
To control an Orion TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0236 or 0463
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
If that doesn't work, use the auto-search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Nov 19, 2009 | One For All URC-3021 Remote Control
There is no region free code
1. Press DVD
3. Press 0533
5. Press 994
10. Press 994
12. Press 00255
15. Press 994
17. Press 00095
20. Press 994
22. Press 00221
25. Press 994
27. Press 00079
Nov 02, 2009 | Sony BDP-S550 Blu-Ray Player
Urc-3021Boo one for all set up and codes for a sanyo tv
To control a Sanyo TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
4) Enter the code 0154.
If it does not turn off, try the auto-search function.
Hope that helps.
Oct 17, 2009 | One For All URC-3021 Remote Control
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
