Question about BT Lands Phones
I have just received a new base for bt 8500 but can not get it to work, what I am doing wrong?
Where can I download manual for bt 8500
The only BT 8500 I know is for a telephone.
If you are asking about a HP 8500 printer, the manual can be found here:
http://h10032.www1.hp.com/ctg/Manual/c01643304.pdf
May 12, 2016 | Office Equipment & Supplies
Got new BT FREELANCE xd 8500 ABOUT TWO WEEKS AGO. WAS USING THE PHONE TODAY FOR ABOUT 10 MINUETS AND THE PHONE CUT OUT. FRIEND PHONED BACK AND ABOUT 10 MINS LATER IT CUT OFF AGAIN WHAT'S THE PROBLEM
You need new rechargeable battery in headset... They only last a year, but should last 3.. IDK, being on the charge degrades them faster than normal. Open back headset and get new ones at Grocery store if they are AA or order from the specialized batter online like from Amazon.
Mar 03, 2015 | BT Lands Phones
BT Freelance XD8500 - one handset has totally "died". Anything I can do to restore?
just change the battery for new one and you will have miracle...
if memory serve correctly there is two "aaa" batteries in the unit, look how polarity goes!
to test - just insert standard "aaa" batteries and see if unit is resurrected, if so buy re-chargeable batteries, insert and enjoy! check an dswap charger (base) unit, rotate handsets between bases as well, base maybe not charding correctly, check pins on the bottom of the base.
if these do not work - buy new unit, it is not really worth repairing...
hope this will help you solve the problem - do not forget to vote...
Feb 12, 2015 | BT Lands Phones
I have a new BT 8500 Advanced Call Blocker , I have put my contact numbers in and saved them , but when my saved numbers ring they are going straight to the call Guardian , how do I rectify this ?
Hi
I downloaded the full manual from here
http://www.ligo.co.uk/data/manuals/BT%208500%20-%20User%20Manual.pdf
and a quick look through it made me wonder if you had inadvertently saved your contacts to the Blocked list. What happens if you press the top right button on the set. If you don't see a list of your contacts for dialling out then check the Blocked list by going through the menus and selecting the specific entry. Also you can use your Calls List to change the settings for those calls you have received, by scrolling through to always locked, always accepted etc etc. Also check your Guardian settings under Call Control in case these have been inadvertently altered to include all calls.
Hope this helps.
Nov 14, 2014 | Cell Phones
BT SYNERGY 4500
I bought a twin pack, having previously owned a BT cordless phone without a problem; whilst the phones worked, the battery life was very poor.
Not sure what went wrong, but after a couple of months neither phone would link with the base station.
If you want my advice, don't buy this product.
Nov 26, 2012 | Lands Phones
Both phones are flashing base 1 with no ring tone on a bt studio 1500
Hi
Had the same problem with my BT Studio 1500 phones both flashing "BASE 1" . Again could not find solution on web! BUT phoned the free BT helpline on 08001456789.
They told me to switch off electricity supply to the base unit then switch it back on.
(The fault is due to the base unit losing the signal and just needs to be "rebooted")
Hey IT WORKS!!!!!
Don't buy a new set of phones!!!!!
Groucho
Jul 14, 2008 | Lands Phones
BT Synergy 2150 Cordless Phone
As far as I can understand your problem, there is nothing wrong, just view the new calls ( options/caller id/options/view/ up and down arrows to scroll through caller id's). New calls message will then disappear, although it doesn't really matter if you don't do any of this.
Apr 13, 2007 | British Telecom Synergy 2110 Cordless...
Lands Phones Logo
23 people viewed this question
Top BT Lands Phones Experts
Steve Sweetleaf
Steve Sweetleaf
ptpumpman
Are you a BT Lands Phone Expert? Answer questions, earn points and help others
