Please respond. As previously stated. My landline isn't working. 01424200384
Not responding to Firewire800
Hope this helps. I assume that your operating system is working, If you can manage to update the driver of the device try to do so however check also if the update of OSX is supported by the manufacturer. Try also removing the existing driver of the device and open your internet. Now plug the device and look for the update drivers... If still won't, you may try the recovery method back to its default state. Goodluck.
Mar 03, 2014 | Western Digital WD My Book Studio...
Oven gets to hot and then it trips out. how many solid state relays do I need to replace?
Usually they put only one SSR(solid state relay).however just make sure how many do your equipment have. Just look at their parts list (that it dosent say dual SSR) . If yes then only one relay to replace But also check that I/O board isn't bad Sometimes the board gets wrong and we replace other components. Just check that when oven is hot I/O board isn't sending any voltage to the SSR Also , replace the thermostat tripper since after getting trip 4-5 times it's get faulty after some time . Thanks Please rate my work
Sep 08, 2011 | Ovens
Son hooked up computer to his ps3. Now wi fi will not work. How can I remedy this. States that is hooked up but isnt to wi fi. Works on landline. thanks Ed
If it works on the landline/wired connection then it's just the wifi you have to fix.
If I understand correctly, and the wifi doesn't work at ALL, then it should be a quick fix!
Right click "My Computer"
Click "Properties"
Click "Device Manager"
Here you should be able to see your hardware, also including "Network Devices"
click the + to dropdown this menu. Here you can see the status of your wireless adapter here. If it's Yellow, then you'll have to reinstall the driver.
If it's red, then simply right click and re-enable it.
Hope this helps! Best of luck :)
Mar 17, 2011 | Acer Aspire One D255-2670
All my icons on the desktop do not respond to a mouse click (Seem Frozen). If I go to Windows start menu, I can launch any application. Upon reboot, icons will work for a short time and then revert back...
Try restoring the PC at previous date of update.
If still the same, please write here the details with your operating system / windows name.
Thanks for joining us.
Good Luck
Nov 24, 2010 | Computers & Internet
I have two LED horizontal bars on the main lighitng display and dryrer will not start...
It seems the previous expert failed to respond to your comment. Please indicate the exact model number of the dryer so that we can start the troubleshooting. I cannot view your exchange of comments with the previous expert. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Oct 22, 2010 | Dryers
I am wondering if I can call my landline phone number and get any messages left on my recorder when I am away from home.
depends on whether your answering machine will respond to the mobile command . Please check with the manual of the ,machine and see if this activation is possible.
May 08, 2010 | Motorola Mobility TracFone C139-4 Cellular...
Window explorer not responding and hangs when i try to rename a file from windows xp. my guess would be it could be some system files that are missing or i mistakenly deleted. pls i need ur help on this...
Well first of all you can try to restore your XP to a previous state, that will allow you to remove all the bugs and errors from the present state...... you can please follow the below link to know how to restore XP to a previous state -
Please post comments if further you have the same problem.........
Good Luck!!
Mar 02, 2010 | Microsoft Windows XP Professional
Model 21518 GE Bluetooth Telephone Adaptor
I see the same thing and it appears that this is the way it works. Without the landline you will get the beeps but can still make and recv calls. After the beeps, dial #1#phone-number#, and it will call that number. Guess that is what they mean when say works without landline.
Apr 12, 2009 | GE Lands Phones
L button isn' working
DO NOT try to take the PSP appart on your own.... You're right, you will end up doing more damage than good. Both the front and back of your PSP are 'welded' toghether. It's a cheap fix if you take it to Game Stop or possibly Best Buy.
Oct 30, 2008 | Sony PlayStation Portable (PSP) Console
Tv repair
I have no idea on what youre needing, unless you respond to the origional post I have no way of viewing previous posted info. Could you please state what it is that you need help locating?
Jul 27, 2008 | Philips 60P8341 60" Rear Projection...
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
