Question about Crock Pots & Slow Cookers
Used the pot program now will not change to any other program
Just been given crock pot with 3 settings can you explain them no manual came with pot
It sure would help us to help you if you could get the model number off of the bottom of the unit. I can probably locate a user's manual with that information. Try this site to locate the manual: (my best guess without a model number)
http://safemanuals.com/314159.php?k=84c8d7db0922eceeab89e8e236b92e45&ID=2854106&q=CROCK%20POT%20SMART%20POT
(209k)
Find the little blue print that says enter security code and then you can dounload the manual.
The settings should be OFF High 4 High 6, Low 8 Low 10 and warm.
1. Place food in stoneware according to recipe.
2. Plug in Smart-Pot™ slow cooker. The Power light will begin to flash
indicating that the unit is plugged in, but not turned on.
HOW TO PROGRAM YOUR SMART-POT™ (CONT.)
3. Push the Cook Time button to scroll through the timed cooking
options. Push once and the 4 hour light will illuminate, twice and the
6 hour light will come on, etc. Select the time based on the length of
time indicated in the recipe. Two time options are usually given. The 4
and 6 hour settings are the HIGH temperature setting and may be
used when you want your food done quicker. The 8 and 10 hour
settings correspond to the LOW temperature setting and is used for all
day cooking. In addition your Smart-Pot™ can be set to the Warm
Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use
the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot™ slow cooker will
automatically shift to the Warm setting and the Warm light will come
on. NOTE: We do not recommend using the Warm setting for more
than 4 hours.
5. To turn the Smart-Pot™ off push the OFF button. Unplug unit from the
wall outlet.
6. For other recipes that give a range of times, select the time closest
to the setting on your Smart-Pot™. For instance a recipe calling for
cooking time of 7 to 9 hours on LOW, set your Smart-Pot™ to 8 hours.
NOTE: If power goes off then power light will blink and settings must be
reset. If cook time is changed before the cycle is complete the time will
reset to the new setting.
Thanks for choosing FixYa,
Kelly
Mar 04, 2011 | Rival 38601 Smart Pot 6-Quart
I never used a crock pot before,do I add water between the heating unit and removable pot??
No, don't put water around the heating unit... All food, liquids will be added in the pot.
May 18, 2010 | Crock Pots & Slow Cookers
Broken pot to a crock pot
Here is Rival's parts page for your model. They show two different versions for your number, and the stoneware for both are out of stock. But there's a "contact us" link so maybe they can tell you when the parts will be available, or recommend another suitable replacement.
Mar 13, 2010 | Rival 38601 Smart Pot 6-Quart
Our cermaic pot of our crock pot cracked when using it today is this a common problem its only a year old and has been used two times...
No this is not a common problem.
The ceramic bowl should last for years if handled correctly.
It may have had an unseen stress crack causing the premature failure.
Avoid putting cold liquid or items into the hot ceramic bowl/pot. This will cause the bowl/pot to crack and can be very unsafe when it pops. The reverse is also true, avoid putting hot liquid or items into the cold ceramic bowl/pot.
It is the sudden changes in temperature that can cause cracks to form.
Hope this helps!
Nov 10, 2009 | West Bend 84754 4-Quart
I have a Rival 6qt. programmable smart pot crock pot. The handle broke off the glass lid. Are plastick handles available?
You might try the automotive adhesive that is used to glue rear-view mirrors to the windshield. I have never tried this, so you are on your own.
Sep 28, 2009 | Rival 38601 Smart Pot 6-Quart
Funny smell coming from Rival 38601 Smart Pot 6-Quart
I had a similar smell coming from my crock Pot when I used it the first couple of times. After about the second or third time, the smell went away. I always figured it was the metals and such heating up to such a high temperature for the first time.
It never seemed to effect the taste fo the food....and my family is still alive!! :)
Hope this helps!
Dec 31, 2008 | Rival 38601 Smart Pot 6-Quart
Ultrex pressure cooker model innova 14240
Pressure cookers are only slightly more complicated than crock pots. In fact, you can think of them as the opposite of Crock pots. Where a crock pot needs 2-3 times as long to cook something, the pressure cooker needs only 1/2 to 1/3 of the time.
These are not that complicated and haven't changed in the last 50 years. The only real hard part is being sure is doesn't explode; not that hard: don't cook things that would foam, like pasta or potatoes. Just read some recipes on the internet or get a recipe book at a bookstore, used book store (super-cheap)or the library. My best advice is to make sure you use the lowest possible heat that still allows steam to escape at a whisper. That will keep things from burning (or scorching) on the bottom, which can give a harsh taste and make clean-up more work. Just do it.
Jul 20, 2008 | Ultrex 2-in-1 (9qt) 8-Quart
Crock pot insert
I need the insert for my GE crock pot, i have I have used it maybe three times and the ceramic broke in half, I am afraid to use it, where can I purchase the part.
Apr 26, 2008 | Crock Pots & Slow Cookers
Water comes out
I would suggust that you take your crock pot to your nearest service center. To see if they can correct the problem with your crock pot.
Okay. Spurs21
Nov 19, 2007 | Rival 3060 6-Quart
Crock Pots & Slow Cookers Logo
52 people viewed this question
Top Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
