Question about Air Purifiers
My AP1512HH air purifier failed after 5 minutes. All lights went off except for Fan Speed 1 & 2 which were blinking. The fan was not turning.
There is no service centre in my country. Is it possible to fix this DIY?
SOURCE: EcoQuest Fresh Air Lamp replacement
Its probably the starter. Manual says to replace both lamp and starter at same time.
Posted on Aug 10, 2008
JSEhandyman
  • 368 Answers
SOURCE: how to put together living air alpine bora III air purifier?
Hi Tlwynn,
The grid part of the screen should face the fan. The O3 produced by the cold-plasma discharge is what attacks the odors, and you want the fan to blow it out of the machine.
Make sure the spring-steel contacts are touching metal on both sides of the plate.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Jon
Posted on Dec 28, 2008
SOURCE: blinking blue light on ionic breeze s1871
the blue light keeps blinking
Posted on Nov 30, 2009
SOURCE: I have 2 ionic breeze air purifiers sharper image.(germical )
I have the same problem as gerardperez7. One of my germicidal light quadras won't turn the light on and doesn't appear to be cleaning the air at all. I even put a new light bulb in it and it doesn't fix the problem.
Posted on Dec 22, 2009
  • 8 Answers
SOURCE: My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Posted on Dec 25, 2009
Fan wont turn
I have taken one apart. reassembled and the fan would not turn, although there was power to the motor and it wanted to turn.
Sorry this is long...only this is about taking the motor itself apart..and I have yet to find a replacement motor.
1. Tried a little WD 40...(only on iron motor Housing!) nothing.
2. Took apart inside of motor. some rust inside..
3. carefully rubbed clean with WD 40..
4. leaned off WD 40 with contact cleaner...
5. Then worked little bearing loose on back side.
-Kind of turned upon reassembly..
6. Found some silicone High temp lubricant and took motor inside part again.
7. a very thin coat of lubricant inside rotor.
-Re assembled yet again..began to turn at high speed, kept running..24 hrs..
- It .finally turned at silent mode. and continues to work
This may be ar beyond what you want to do, however if all else fails...what else can you do? buy another one?
Tips:
1. mark rotor holders with housing. (do not reverse.)
2. make sure you remove all lint, dust, etc inside.
3. the rotor bearing I had to work by hand again and again repeatedly syringing a little WD 40 at a time to until it turned easily.
Jun 04, 2012 | Oreck XL Professional Air Purifier
Flair living air purificaion system
here are parts for your air purifier, including the motor and other parts you may need in the future.
AirPurifierRepair.
- just click the link
hope that helps, good luck
Jul 31, 2008 | Ecoquest Flair Air Purifier
Everything works but the fan will not turn. I recently performed a thorough cleaning and installed a new ozone filter, but the fan will not turn. I tried turning the fan manually and the unit would run...
The fan needs oiling (except for the Fresh Air, which has sealed bearings and no removable front grid). I need to know which model you have to help you reach the fan shaft. However, if you're handy, you can figure it out. Remove the front grid (if there is one on your model) and pull off the fan blades. Use a light household oil (sewing machine, hair clipper, 3-in-1) to drip down the shaft as you turn it manually. This should take care of the problem.
If not, and if you need more extensive repairs or rebuilding, call Vollara (new name for EcoQuest) customer service at 1-800-989-2299 and use 16618 as your dealer referral number.
Jan 30, 2011 | Ecoquest Air Purifiers
My AT is "surging" and seems to be cycling between
Check all connections. Most likely, something is not firmly in place. Unplug the machine.
1) Make sure the plate is inserted into the grooves, top and bottom.
2) Make sure the contact "fingers" press firmly onto both sides of the plate.
3) Make sure the plug is inserted FIRMLY into the back (MOST COMMON PROBLEM).
4) Make sure the back screen is inserted firmly, and that the safety switch is depressed by it.
5) Make sure that the outlet is not on a line with heavy power users, like a furnace or refrigerator.
Jan 19, 2011 | Ecoquest Breeze AT Living Air Purifier
The fan on my living air purifier doesnt turn anymore. Occasionally when I first turn the fan on, it will "try" to turn but stops almost immediately. do i need to replace the fan motor? Is it something I...
I just bought a used one of these at a sale. Horribly dirty, grimy, rusty, etc. Anyway, similar problem with fan. Clean it off and WD-40 or silicon it. You should be able to see an almost immediate response unless it's another problem. My fan went from a low speed when turned on "High" and from a complete stop on "low" to actually turning on low. Anyway, I laid it on it's front, sprayed some 40 on the back fan bolt (pin, screw, whatever), then used a pen to click the safety so it would turn on with the back off and in less than a minute it was at full speed. Good luck!
Sep 22, 2010 | Ecoquest Living Air Classic Air Purifier
I cannot adjust the fan speed. There is 1 spot on
If there is only one spot on the fan control dial that turns on the fan, it seems that the fan control pot has failed and needs to be replaced. You can call the company and order one and it should fix your problem 800 989 2299.
Jan 03, 2010 | Alpine Air XL-15 Air Purifier
My Apline Living Air does not create any ozone. The fan runs but the green light only turned on once.
Are the plates cleaned? They should be cleaned once a month by soaking in 1 part amonia and 1 part water for 10 minutes. Scrub with a toothbrush and rinse throughly with water. Allow the plate to dry overnight or use a hair dryer to dry throughly. Hope this helps.
Oct 12, 2009 | Ecoquest Breeze AT Living Air Purifier
Home Depot Switch Doesn't Work. Does anyone know where to get a
Google search Hunter Fan Parts. Should find what you need, and have it in a few days.
Regards, --WoobieDog--
Jul 10, 2009 | Hunter 30216 3-SPEED FLOOR MODEL Air...
Fan won't turn, Fight just flicker
Contact healthytech@triad.rr.com. They will be glad to help you.
Apr 09, 2009 | Ecoquest Breeze AT Living Air Purifier
Jul 19, 2008 | Ecoquest Fresh Air Air Purifier
Air Purifiers Logo
147 people viewed this question
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
