Question about Indesit Washing Machines
Water not going into water container in Indesit IDC750UK
3 Suggested Answers
apart4u
  • 213 Answers
SOURCE: Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Posted on Jan 10, 2010
SOURCE: i have an indesit is70c condenser drier and it
To take the lid off, remove the two screws at the back and slide the lid backwards. If you try to lift the lid up, you will break the plastic catches. I learnt the hard way. If you do it correctly, it's easy.
At the back of the tray that holds the water container there is a small hole which allows access water to drain back down into the pump. Clean this hole(it will probably be full of fluff and hair). While you are there, there is two tubes at the back off the drier the thicker on of the two is the one that the access water drains into, make sure this is not split(mine was and I used self amalgamating tape on it to seal it again.) Replace lid, replace water collector, job done.
Posted on Jan 30, 2011
Why is my indesit washing machine displaying H20 and not opening
• The water container must be emptied? The "Empty water container" indicator light flashes and the message appears "H2O" (see Maintenance).
Dado
Jun 29, 2015 | Indesit Washing Machines
Indesit idc85 not collecting water in container.
well it could be one of two things its blocked up which means you need to clean all tubes out or the pump is faultyif you take the top of dryer and pore water into drum and turn you should be able to see if water comes up tube if not check your pump
Oct 14, 2014 | Dryers
Indesit IWC6105 Keeps filling with water and lights flashing
Almost certain to be a power pcb failure due to the fact it fills and drains at the same time this is a regular fault symptom on indesit laundry appliances. Word of caution tho inde pcb's are generic to a range and the software must be programmed via a lap top to your specific appliance so you can't just order a pcb and pop it in sorry
Dec 08, 2013 | Indesit Washing Machines
I have an Indesit Dryer IDC75(UK), the red light goes on but the Container is empty, therefore it takes longer to dry and all the condesation collects inside at the rear bottom of the machine, I have...
Most likely it is clogged vent and also check for outside vent
Best way is visual check and check for any faulty component and parts and check all thermostats and sensors and look for clogged vent or any damaged or rusty or cracked components and use step by step deduction method for trouble shooting
Dec 07, 2013 | Bosch Axxis WTA 3510 Electric Dryer
I have Indesit IS70C dryer and all of a sudden it's not getting hot when switched on and the water container is empty..water is not draining from the clothes to the container and machine is not getting...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.//.';';]\\
Jul 25, 2011 | Indesit IS70C Electric Dryer
I have an indesit is70c condenser drier and it doesnt seem to be collecting all the water in the water container. some seems to make it into the container but then the rest just sits in the container...
Jan 19, 2010 | Dryers
Indesit condenser tumble dryer water light always on even though container empty
Maybe trapped water in the dryer. Switch off and remove power from wall. Remove condenser unit from the dryer (clean the condenser while you have the chance with plenty of water and an old toothbrush - it will probably be filthy). With the condenser unit removed stick an old tea towel in the hole where the condenser was and then tip the dryer on its side. If there is water it will either run onto the tea towel or onto your kitchen floor OR into the water container!
It worked for me, honest...
Oct 06, 2008 | Dryers
My indesit is70c tumble dryer isnt working correctly. The light which tells you to empty the water is staying on the water draw isn't filling up with water and it does not get any heat. ( I Know I Am Blond...
problem is probably the pump that sends water up to the container. take small panel off back and pump and water container is exposed. power the pump independently and see if it works
Aug 05, 2008 | Dryers
Common faults -
Feb 24, 2008 | Dryers
Washing Machines Logo
15 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
