Question about Coffee Makers & Espresso Machines
Water not going into water container - Coffee Makers & Espresso Machines
Water not draining to container,leaking.
Undu the hose or pipe at highest level and make sure it is not clogged
Aug 08, 2017 | Miele Dryers
Sprayer is not working, but leaks water
I think you have two problems. The leaking is old seals on either the containers, or on the other end (the machine). Try replacing them. There are various part websites for these.
The problem with the spraying could be the belt that turns the pump. Check it. If it's there its probably not it. The next thing could be the little plastic tubes that go to all the componets inside the machine tend to accumulate buildup. Make sure they are all flowing free. Next try the heating element (its inside the handle area) take it apart and clean it. If all those things are checked and it still doesnt work, it might be what was wrong with mine. The all on one container that holds fresh water and dirty water has a leak. I found mine would spray correctly if i had the lid off the container, and as soon as i would put the lid back on it would stop spraying. I found out that The suction going through the container to **** the dirty water in was also putting a suction on the clean water bladder which caused the water to stop flowing out of the clean water bladder. I ended up getting an all new container with bladder because i could not get anything to seal right due to its age and warpage of the plastic. So to determine if yours is the same issue. Just take the lid off the container and then try to spray water. It may take 10 seconds to get all the tubes primed again because the suction will actually **** all the water back up to the container. If you dont want to replace the container, just spray a few passes with the lid off, then put the lid back on to **** the water back up. Hope this helps. I might not write clearly for everyone to understand, but i hope it helps someone.
Mar 01, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
I have an indesit is70c condenser drier and it doesnt seem to be collecting all the water in the water container. some seems to make it into the container but then the rest just sits in the container...
To take the lid off, remove the two screws at the back and slide the lid backwards. If you try to lift the lid up, you will break the plastic catches. I learnt the hard way. If you do it correctly, it's easy.
At the back of the tray that holds the water container there is a small hole which allows access water to drain back down into the pump. Clean this hole(it will probably be full of fluff and hair). While you are there, there is two tubes at the back off the drier the thicker on of the two is the one that the access water drains into, make sure this is not split(mine was and I used self amalgamating tape on it to seal it again.) Replace lid, replace water collector, job done.
Jan 19, 2010 | Dryers
An automatic overflow switch and Container “Full” indicator light are provided to turn the
dehumidifier off before the container overflows. When the indicator light on the control panel
glows, the water container must be emptied. If the light remains on and the dehumidifier does
not begin to operate make sure the float is attached to the water container.
When the condensate water container is full, the indicator lights up.
1. Turn the power off before removing container. Wait 3 minutes for
any remaining water to drain into the condensate container.
2. Tilt the container forward then lift carefully by the handle.
3. Empty and gently re-insert the container.
Important:This water is not suitable for drinking.
Please rate and god bless:)
Apr 24, 2009 | Fedders A7DH45B2A Dehumidifier
Add water
There is a floating magnet in the side of the water fill container. Make sure the magnet is floating. That is how the Keurig determines whether there is water in the container or not. If it isn't floating, the machine thinks the water container is empty. If it is not working properly your only option is replacing the water container (or rigging the magnet and being very careful to make sure the reservoir never runs dry).
Mar 28, 2009 | Keurig Special Edition B60 Coffee Maker
My new GT300 won't prime.
I fixed mine! The idea here is to help fill the tube inside back up with water. The unit may need a little help to get the suction going.
Preparation: Set the unit so you can easliy reach the back side of the unit. Fill the container with 7 - 14 oz of water and have it nearby. Place a cup underneath the coffee drip container in the front. Have another small cup of water handy.
Process: Plug in the unit to an outlet. Hold as much water in your mouth as you can. Press the CLEAN button on the unit then put your lips over the water inlet valve on the back of the unit. Force (blow) the water from your mouth into the inlet valve. You should begin to hear the unit pushing the water through. Place the water container over the water inlet valve after you have released the water from your mouth. The unit should continue to empty the water container. Now, you just have to fill the water container and make a cup of coffee.
This is the same procedure I performed to get mine going again; I am not trying to make you look like an idiot.
-Richard Barrett
Mar 16, 2008 | Black & Decker GT300 Coffee Maker
Add Water
Turns out I finally called Keurig and explained the problem (says to add water when water container is already full...) and they told me that it was most likely an issue with the water container. They sent me a new water container about a month ago and it looks as though the problem has been solved!! Solution: Call Keurig and get a new water container!!!!
Dec 26, 2007 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
