If the main fan motor is screaming in your lincoln impinger oven, actually that means the motor is faulty. more so the bearing in the motor are worn out and should be replaced, its easier to replace the motor itself but the motor is very expensive. To save money you can actually replace the bearings your self by opening the back cover in which the motor is mounted, then unmount the motor and disassemble it so you can take out the bearings. take the bearings as a sample to a bearing store so that you can get the size correct.
make sure you get bearings that can handle high temperatures and not those with plastic seals ment for wet or water places.
Sorry I sent you the 1600 series manual. Here is the 1400 manual http://lincolnfp.com/docs/uploaded/lin/products/Impinger_I/L371075%20-%201450%20Series%20Gas%20Service%20Manual%20-%20Domestic%20-%2010_21_09.pdf
