Question about Sport & Outdoor - Others
Overheat sensor keeps going off on our yamaha 85hp outboard. Water pump has been replaced, thermostat, and sensor. Motor does not seem hot and water is coming out. Help please.....
  • lashers3 Aug 11, 2009
    Thank you we will check into whether they did that or not. Will let you know.
  • Sport & Outd... Master
  • 3,051 Answers
Hello there:
when you changed out the sensor did you have the codes cleared from the computer brain this is common on outboards. contact your local dealer for further asistance .
best regards mike
Posted on Aug 09, 2009
  • Michael Thomas
    Michael Thomas Aug 10, 2009
    Hello there again
    please dont forget to rate this solution i have provided ok it helps me out greatly
    best regards mike
Help with my 1994 Yamaha 150Hp
Outboards have thermostats...the tattle tale can be pouring water and the engine still overheat if the thermostat is stuck or airlocked.
May 07, 2014 | Boating
Yamaha outboard water pump
sounds like you blew a gasket . find a dealer .
Jun 26, 2013 | Boating
8hp yamaha runs hot
In most outboards, it will flow through the prop itself (through the inner prop). There should be a stream of water coming from somewhere around the back end of the motor itself, called a telltale, which visually shows that the water pump inside the outboard is pumping water up around the motor. If you cannot see this, then there is obviously a problem with the water pump or pump impeller that needs to be corrected to prevent the outboard overheating.
Jul 04, 2009 | Light Outboard Motor Boat Bass Fishing...
Water circulation (coolant) thru outboard motor
Common problem is the thermostats staying closed. If i remember correctly they should be replaced every year. Water should be spitting out on the upper part of the shaft. Good luck on that fishin'
Apr 25, 2009 | Boating
Temp gauge all the way hot
check your radiator and make sure that the water in the radiator is flowing constantly if not you have to replace your water pump or thermostat it seems to early for that since its an 05 but it can happen
Mar 16, 2009 | 2005 Suzuki Forenza
Sport & Outdoor - Others Logo
419 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
