Question about Miele Washing Machines
How to remove the Top cover from my Miele novotronic W 829
IB4G2008
  • 3587 Answers
SOURCE: water not getting into washing machine miele novotronic w830
K5? which pipe is that..let's assume you have pressure to the back of the unit, yes? then you have a valve sticking or something obstructing the channels inside that unit..
does this work regardless of temperature setting.
Posted on May 10, 2008
  • 163 Answers
SOURCE: Miele Dryer heater bank
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
Gallois
SOURCE: Hi, i have a miele novotronic w 916 and it's not spinning
I mean this is not a filter error and i think the power main board inside on front bottom EL110 has an defekt and must change.
Or you can post the problem on my board www.avpc.de with photos for solving together and find another cheap used power board for it ...
Posted on Sep 09, 2009
reverendrave
  • 24 Answers
SOURCE: replace door seal miele novotonic w 502
Hello mc2739,
It's been awhile for me since I have done this so I searched on the internet and found the following. The instructions are pretty detailed. You may want to contact Miele if any problems
1. Open the machine door.
2. Turn the main power off and unplug the machine from the wall.
3. Completely remove the powder dispenser drawer (it will come out so far (and stop), then there is a small button at the rear of the dispenser which you need to depress to remove it fully, you'll see this button once you've withdrawn the drawer to its stop position.
5. Undo and remove the 3 x hexagonal head bolts surrounding the door seal (they are at approximately the 2, 6 and 10 o'clock positions). Note these bolts actually secure the front panel to the machine chassis, they do not retain the door seal. Don't worry the front will not drop off.
6. Now look at the aperture of the powder dispenser drawer (you have of course removed the actual drawer earlier). Locate the lower left hand corner of the aperture, and you'll see a recessed philips head screw in a hole. Undo and remove that screw.
7. Now, you'll need to get on your hands and knees. You DO NOT need to tilt, or lift up the washing machine to do the next bit. Locate the underside of the front panel right at the bottom. You'll notice that it sticks out about half an inch or so and is proud of what I would call the kick plate which extends right down to the floor. You need to look on the underside of the front panel, about an inch or so in from the left hand edge. There you will see a spring loaded clip which when closed is located within a slot on the underside of the front panel. Using a flat bladed screwdriver, you need to carefully lever the spring clip open whilst gently pulling the whole front panel (from the left side) ajar. It will just suddenly pop out once you've done it.
8. Open the pump access door lower left hand side of the front panel) and unclip the drain tube from its plastic retaining clip.
9. Now carefully swing open the whole front panel, it opens like a door (hinged on the right hand side). It might be a little stiff as there are a whost of leads attached to it, but it is designed to open fully (with the leads attached) to about 90 degrees.
10. Next, unseat the rubber door seal from around the door opening area (on the chassis, not the front panel, obvioulsy), so that the seal the flops away from the chassis and lies just inside the machine.
11. You will notice that there is a thin steel band holding the door seal in place around the drum. On the right hand side (at about the 3 o'clock position), you'ss see a tensioning screw for the band. With a flat bladed screwdriver undo this completely and remove the screw (it is accessible from above with a long screwdriver). Be aware that there is 1 x washer and 1 x 'nut' type fitting that will fall out when you remove the screw. Locate these and retain them for later.
12. Now extend the steel band to its maximum opening (by moving the 2 x lugs apart where the now removed screw was).
13. You can now remove the steel band. Then pull it out through the hole/door aperture in the chassis.
14. Locate the small rubber tag at about the 12 o'clock position where the seal is attached to the drum and tug it. The seal will then come away from the drum. Remove the old seal completely.
15. Using your new seal, place this correctly around the drum (there is a lip on the seal and this has to go over the lip on the drum. Remember, the seal goes on the OUTSIDE of the drum. Ensure the 'tag' is at the 12 o'clock position.
16. Reassembly is then the reverse of removal.
17. Make sure that you do up the retaining steel band sufficiently and that you correctly locate the sela on the chassis front panel (there is a groove in the seal which will locate the seal in the aperture).
18. Finally, once you're done, put the machine through a few rinse cycles (where the water level is high) and look for leaks. If you have a leak, it is likely that your door seal has a rip/tear, or that it has not been correctly located around the drum - in which case you'll need to investigate.
Posted on Sep 17, 2009
  • 177 Answers
SOURCE: How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Posted on Jan 18, 2010
Testimonial: "Thanx for the help. I managed to get my first wash very successfully. "
Miele novotronic w145 s spullen light flashes
Possible that this error can be due to the INLET or the DRAIN being clogged or is not functioning. Remove and clean the filter to both the inlet and drain.
Jan 19, 2013 | Miele Washing Machines
Miele Novotronic w963 motor does not turn after water filling
Hello, my question is, I have washing machine MIELE NOVOTRONIC W 963, is broken, Which Miele model HAVE SIMILAR MOTOR ,thank you . William
Jan 03, 2013 | Miele Novotronic W1918A Front Load Washer
How to remove front panel on miele w524 washing machine to replaer elementce heat
very simple ,first thing first always unplug washing machine from main socket, remove top cover reomove soap drawvremove three screw from inside soap draw, remove kick pannel at bottom to reveal drain pump ,remove door seal held by spring ,remove two scrw where door strikre goes in ,then you should beable to lift of whole front which will reval heating element
Oct 18, 2011 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Jun 14, 2010 | Miele Novotronic Premier 500 Front Load...
How do you remove the top of the Miele T1515 vented dryer?
hi,
on each side of the lid at the front there is a plastic white cover. remove this with your fingers or a small knife. then using a T20 screw driver unscrew each screw a few turns and then push the screw heads in with your finger. do not unscrew the screws too far or remove them.
last push the lid back a few inches and it will lift off. once off you will see the locking clips that you just unscrewed which hold the lid down. when re-fitting the lid do the reverse and just tighten up the screws.
Apr 12, 2010 | Miele Novotronic T220 Electric Dryer
Miele Novotronic T562C: Do I put the washing powder into the small opening/hole top left in the removable part? It looks almost too small! And I can't see how it gets out of there into the machine during a...
Right side of compartment for powder when Pre wash is selected.
Middle compartment for powder when Pre wash not selected
Left side with flap for fabric conditioner.
Apr 03, 2010 | Miele Novotronic Premier 500 Front Load...
Jan 10, 2010 | Miele Novotronic W1918A Front Load Washer
Miele T220 Novotronic
Miele is a top notch machine. Try checking your vent hose. It may be blocked in some way.
Jan 28, 2009 | Miele Novotronic T220 Electric Dryer
Miele 829 Leaking
You will need to remove the top of your machine.
Screws are at the top on the back of machine.
You will then see where the leak is.
Shouldn`t be expensive and is quite easy to repair
Jan 26, 2009 | Miele Washing Machines
Water not getting into washing machine miele novotronic w830
Thank you for advice! My Miele Novotronic W830 is 17y old, been working well, until yesterday. When taking water, much started spilling on floor under the left lower corner of the machine.
I opened the cover, found a loose hose under the detergent tray, did set it back in place and tightened the band.
First you better loosen the band, it slips more easily on the funnel.
In my photos you can see the screw is pointing to wrong direction to be able to use a screwdriver, but I did manage it with bare hands.
Be sure there is no power connected when opening the cover!
And don't drop anything inside, when opened the cover, it is a nasty place to get it back...8_26_2012_3_23_27_pm.jpg8_26_2012_3_24_22_pm.jpg8_26_2012_3_24_47_pm.jpg
May 10, 2008 | Washing Machines
Washing Machines Logo
78 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
