Question about Nakamichi Televison & Video
I have a new nakamichi nk 11 system for a yr. I moved to a new development, now randomly it turns on by itself. I tried a new power strip, and directly to outlet, same thing.just started when moved.
jomaru
  • 337 Answers
SOURCE: TV shut off
The set is going into shutdown,there are a few reasons why the circuit is being activated,excessive high voltage,excessive volts supply(poor regulation)no screen voltage or a secondary supply is missing,if you are familiar with tv service you have a few places to check,you will need a volt meter and a soldering iron and the squematic diagram to locate the different circuits mentioned,if you are not too familiar seek the assistance of a servicer.Let Us know if you need more information.
Posted on Oct 27, 2006
SOURCE: Tone Direct Problems
Classic electronic controlproblem...
If you still have warranty, use it.....!
The board for your preamp/switch/vol are made as an electric matrix. This means that several signals are coded and sent from the "frontpanel" to the amp itself. A digital signal like this will be hard for someone to measure and understand without a oscilloscope.
My advice is to clean and check all connetions (inside the amp), but mind the hazardous currents inside.
Posted on Jan 23, 2008
SOURCE: Nakamichi SoundSpace 8 System
check your power cord, check your 9 prong relay cord from power amp to deck unit, check your fuse that is in a little slot in the plug itself, most importantly check the 9 prong plug to the control unit itself, if you are mounted on the wall it could easily come out enough to not make connection. these units will take alot of bad voltage errors, if the only thing not working is your cd player you should still be able to eject it, if not it is power related, if it will eject but not play then your drive band is broke and unless you are very very mech minded take it to a repair shop who is nach. refered just look online for service try my ideas 1st you might get lucky, I hope I am right!!
Posted on Mar 12, 2008
SOURCE: tv won't power on
I trashed the set and bought a new one.
Posted on Jul 08, 2008
SOURCE: My 5 yr old Palm Tx suddenly started trying to
I did a warm reset and it worked. Just hold the up key and reset!! good luck
Posted on Sep 02, 2009
I moved and lost the power cord. Where and how can I get a replacement cord?
NEW CABLE FROM NAKAMICHI IS £150 . INSTEAD JUST CUT THE METAL SHIELD OFF ANY CD MINI DIN CONTROL CABLE WITH A JUNIOR HACKSAW AND IT WILL FIT PERFECTLY (IT ONLY GOES IN ONE WAY BECAUSE OF THE WAY THE PINS ARE LAID OUT!). I USED AN OLD MAC DIN PLUG BECAUSE IT WAS 3M LONG! WORKS PERFECTLY!
DS
Feb 18, 2010 | Nakamichi SoundSpace 8 System
Nakamichi SS-5 humming noise at stand-by nmode
Nakamichi service center in New Delhi. call +91 9871371720
Jun 26, 2009 | Nakamichi SoundSpace 5 Shelf System
Nakamichi soundspace 11 dvd
The problem you have is that of the roller of the dvd player.The roller is one the moving back and port bringing the lense set,the roller is dirt already the grease thier is hardened already.Its needs to clean so that performance will come again.By using a lighter fluid to clean and lense is wipe by a cotton with no chemical use.When you do this your player will read again.
Jun 17, 2008 | Nakamichi SoundSpace 11 System
Nakamichi Sound Space 8 System
DS
Jun 01, 2008 | Nakamichi SoundSpace 8 System
Dec 23, 2007 | Nakamichi SoundSpace 8 System
SANSUI TVS3275 randomly turns off....
hi guys , sometimes the power switch can be faulty...
Nov 11, 2007 | Sansui DTV2760 27" TV
Televison & Video Logo
24 people viewed this question
Top Nakamichi Televison & Video Experts
Henry  Thomas
Henry Thomas
Josh Whitehead
Josh Whitehead
Jim Goldsmith
Jim Goldsmith
Are you a Nakamichi Televison and Video Expert? Answer questions, earn points and help others
