Why is the softener compartment still left filled with soapy water when the washing cycle has completed and the washed items have been removed
    Top Expert:
  • Washing Mach... Master
  • 34,743 Answers
The compartment is flushed to remove residue.
Posted on May 21, 2017
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
How do I get fabric softener to flow into washing machine
jrez's answer is for toploaders... you said you have a drawer, so it's a front loader.
The softener is usually taken up by a syphon. This can be removed from the drawer assembly for cleaning, when they clog they can't syphon.
While the machine is taking water for the last rinse, some of the incoming water is sent via the softener compartment. As softener is thick, without a syphon the softener would just sit in the bottom of the compartment and the fresh water would just skim off the top.
SO: Check the drawer after the final rinse.. if the softener compartment is full to the brim, the syphon is blocked. OR .. if there's just the same amount of softener as when you started the cycle, you have a filling problem instead.
Filling problem can be for two reasons: early machines had one water valve, and a flap which squirted water into the various compartments, operated by a linkage from the timer - this linkage can break, the spring can fall off, all mechanical. Later machines use a separate water valve, and this can fail shut.
Feb 15, 2015 | Washing Machines
Water in the Softerner compartment
The softener drawer cover is designed to siphon out most of the water that runs into the drawer so, when the wash is over, the drawer should always be nearly empty. Unclip and take out the detergent drawer, unclip the softener cover and fill the softener tray with water. Clip the softener cover back on and the water should run out immediately. If it doesn't then a small blockage in any of the 3 pipes in the cover can completely stop the siphon action. Cleaning them out is generally all that's needed.
Apr 06, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Softener wont add
Please ensure the machine is turned off at the power socket before you do anything.
Have you tried removing the draw? If you pull the draw out on most washers and slightly tilt the draw up and then try and pull further out the draw will come out. (DO NOT USE BRUT FORCE) if it doesn't come out easily then it probably isn't designed to.
If you get the draw out give it a really good wash in hot soapy water, the compartment where the softener goes normally as a piece of plastic that lifts up so you can clean the compartment throughly. Whilst the draw is out also give the inside of the draw compartment a clean out. (PLEASE ENSURE THE POWER IS OFF) Just for safety.
Once you have cleaned the draw replace it and try a full wash and see if that cleared the problem.1_15_2013_10_08_16_pm.jpg
Jan 15, 2013 | Belling SGE12X Front Load Washer / Dryer
Fabric softener premature release
In my case it was simply a matter of cleaning the nozzles that spray the water into the MAIN DETERGENT compartment. Turns our that when the washer was filling up, some nozzles were partially clogged and were directing water to the side where the softener compartment was, causing the fluid level to rise and therefore releasing the softener early. The washer was NOT spraying water in the softener side, what happens is that the dispenser tray is configured in a way that when the fluid reaches a certain max level in the softener/bleach trays, it completely drains. A way to test for this problem would be to completely dry the softener tray and start the wash cycle like you normally would (including detergent), only without adding any softener to the tray and see if after filling there is any water in the softener tray, this would prove that the water is coming from the other side.
Apr 13, 2012 | Whirlpool GHW9400 Front Load Washer
My fabric softener compartment won't drain properley and always has water left at the end of the cycle - any ideas to clean?
yes this cleaning should be carried out on a regular basics,remove the compartment/drawer give it a small pull and it will come out easly.clean with warm soapy water once replaced put a [dishwasher] tablet into drawer and run a normal wash,done once a month this will keep you free from problems.adrian,,,,,,,,
Aug 19, 2010 | Asko W6461 Front Load Washer
My bosch nexxt washer will not drain the fabric softener into the load during the rinse cycle. The same amount I put into the fabric softener hopper is still there after the load is complete
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Oct 22, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Fabric softener doesn't leave the dispenser
Oct 21, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Dec 12, 2007 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
