When moving, our Winner's Only double pedestal oak table got a crack in one of the pedestal legs. We need an estimate for the repair or replacement of the pedestal leg. Who can provide an estimate?
  • 3 Answers
SOURCE: Leveler Leg
this company has gone out of buss,? but the speaker company.com has either bought there exsisting stock or reproduced the same speakers i have the ST3 model that is now called TST3 or TST2 higher the # the more bass it can handle. awsome speakers and you cant beat the price. sorry if my typing stinks but i hope i helped someone out there if you bought sapphire when they where a hot item here's your answer lol pete n.j.
Posted on Aug 14, 2008
SOURCE: Leg lock broken
Assuming you still have the female part with the treads in tact, you can do what I did. I used a hose clamp, the kind used on radiators, but larger. First, take off the lock down knob, then put the hose clamp over the broken plastic housing and mark where the knob would screw through. Then remove the hose clamp, placing it on a sturdy surface and use a 5/16 drill bit to make a hole where the lock down know will pass through. Place the hose clamp over the plastic housing, insert the knob, tighten the hose clamp (but not so much that it restricts the tripod leg from moving) and you are done! I can send you pictures of the process and the final result. It saved me from buying a new tripod! I can be e-mailed at boingsplatplop@yahoo.com if you have questions.
-Spencer
Posted on Nov 17, 2008
SOURCE: How do I remove the legs from Leapfrog Musical Table
Turn the table on its side. On the top of the outside of the legs are two slits, where they connect to the table. Slip a butter knife in the area between the slits, and press in (not up or down) hard! The legs will pop off in a few tries if you do it hard enough :o)
Posted on Feb 09, 2009
  • 109 Answers
SOURCE: Kettler tennis table has rusty legs, one is very bad
To stop this much rust - go to any hardware store and buy (I forget the exact name) a "paint" called Rust Stop. It will stop the rusting and turn the existing rust into a hard black surface that you can then paint.
Posted on Apr 03, 2009
SOURCE: The lower leg clamp on my SLIK U212 deluxe is cracked.
Per another post on here i located a website which sells Slik parts -
http://kenkooutlet.com
- the part was cheap but the shipping was too high in my case. Good luck.
Posted on Jul 24, 2009
We have a very small dining room space, but would still like to put a dining room table and chair set there. Can anyone suggest the best way to furnish a small space like this?
The best dining room table shape for a room with limited space is a round table. You should look into finding one with an extension leaf if you have enough space to open it. Try looking for a table where you can fit more people around it by purchasing one with a pedestal base. This leaves more room for your guests legs without the legs of the table getting in the way.
Aug 09, 2012 | Furniture
Does the wood really matters when it comes to coffee tables?
Hardwoods like oak, walnut, cherry or maple dent less easily than soft woods like pine and cedar. A "solid wood" table means it's made of solid boards. "All wood" tables are produced from engineered plywood or particleboard. I personally prefer the oak tables but it can get a bit pricy so you should take it into consideration.
Jul 31, 2012 | Furniture
Kenmore Whasher shakes on spin cycle
unfortunetly this is common , these new frontloads spin fast even with no pedestal these things move...
make sure the locking nuts for the legs on the pedestal are screwed securely up to frame on pedestal, also could be a floor issue depending on where it is, slooping or not solid floor.
Jan 28, 2010 | Kenmore Elite 45986 Front Load Washer
How do we install the pedestal to the front load Kenmore washer
The pedestals bolt into the bottom of the washer where the legs where.
This is definatly a heavy job, so it's best to get 2 more people to help you out.
#1 Remove all 4 legs that came on the washer factory.
#2 Make sure you have enough room to manouver the machines. The washer is going to be the most difficult so start with it.
#3 Have your friends tilt the machine back and you slide the pedestal under the machine.
#4 Kneel down infront of the machine to prevent it from sliding forward.
#5 Have your friends lift up the back of the machine and walk it forward until the holes in the top of the pedestal are in line wiht the holes from where the legs where.
#6 Thread in the bolts and tighten.
**You will need to take out the drawer of the pedestal to get the back bolts in. There are plastic clips on the inside of the runners, just push those down at hte same time and pull the drawer**
Good luck! Please let me know if this was helpful!
Oct 03, 2009 | Kenmore 15.5 in. Pedestal
Washer unbalanced on final spin, cannot stop the unbalance
Hi Sparky,
The reason it's out of balance is because the skate plate shoes are worn out and need to be replaced. You'll have to access the washer in order to do this. There's a video available that shows how to do it.
After you have opened up the washer you'll see that the tub is sitting on a three legged pedestal. The shoes are in between the skate plate and the top of the pedestal. Here's a picture (and part number) to illustrate...
Do one shoe at a time by lifting the skate plate off of the pedestal about an inch or so and wedging it there (I use a hammer handle as a wedge). The shoes simply snap into place, so the old ones will have to be snapped out of place first. Use another hammer and tap the shoes out of their sockets from underneath.
NOTE! ---> When you place the new shoe into its' place DO NOT try to snap it in!!! (if you do, you'll break it) Just let it rest in it's place for now. Remove your wedge and allow the full weight of the tub to sit on it. Then move on to the next shoe and repeat.
After all 3 shoes have been replaced it's time to snap them in completely. Do this from the top of the tub. Using your body weight, press down on the tub from above on all three corners (where the shoes are located). This will apply even pressure to the top of the shoe and keep it from breaking. You should have all 3 snapped in now. Use a flashlight and look underneath to verify (you should see the tabs of the shoes poking all the way through the pedestal).
Now all that's left is to rebuild the washer cabinet and start some laundry!
SG
p.s. I know it sounds like a lot of work, but this job can be done easily within an hour and the parts only cost ~$12.00!
Apr 01, 2009 | Kenmore Washing Machines
I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Mar 20, 2009 | Evenflo Exersaucer Triple Fun Active...
Replacement table top stand for lg tv
Cracked table top stand for 42LC7D flat screen
Aug 19, 2008 | Televison & Video
Washer appears to be out of balance
Double check the screws holding the washer to the pedestal to make sure they are tight and make sure all the jam nuts on the leveling legs are tight. Loose jam nuts are the most common cause of this.
If they are tight, loosen the right front leg and screw it up until the weight is off the floor. Then run it back down until it contacts the floor. Put the washer in high spin and tighten it down to the floor until you get the spot where there is the least vibration. Tighten jam nut, and check it again in spin with a load of clothes.
Post back and let me know how this works.
Oct 18, 2007 | Whirlpool GHW9100L Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
