Why can I get no pictures on freest adjust say no signal
My ford freestly leak water under poump do i have to change the watar pump
if the hater is from the weep hole under the pump housing, it indicates that then pump shaft seal has failed
' a replacement pump is the fix
Sep 13, 2017 | Ford Freestyle Cars & Trucks
Hi iv got a Goldman's freest sd I can't get any channels it just says no signal what can I do presentable keith
hi turn the power off unplug it, see if there little reset button on the back of the box, check aerial lead, reconnect retune, thanks
shaun
May 20, 2017 | Televison & Video
Sony KP-51WS510 problem- 1. Picture is not stabilizing while can heard Audio clearly and continuous vertical moving picture. 2. How to connect TATA SKY INDIA DTH TO TV and convert PAL signal to NTSC or...
In your problem #1. try to do a fine tuning of the channel or adjust the horizontal adjustments. For the problem#2. Access the system setup of your television, from there you can choose either PAL signal or NTSC signal to operate in your system.
Oct 30, 2010 | Sony KP-51WS510 51" Rear Projection...
My Vizio LCD HDTV 32in. doesn't seem to "center" the picture on sports programs so when they have a score box in the upper left corner most of it is cut off and can't be seen. Doesn't matter how I adjust...
This is a common complaint. To be frank I don't have the exact term for your Vizio, but most recent LCD and plasma TVs have the ability to "zoom" or adjust "picture format" (those are two commonly used terms) depending on the signal source and format.
it has to do with the fact that currently there are both classic style format 4:3 signal sources as well as new HD 16:9 signal sources and on top of that it may happen that a 4:3 signal source is distributing adjusted image from a 16:9 or other signal source. Think cinema adjusted to run on classic TV - remember the vertical strip of image with two huge black areas below and above it?
Well the ZOOM or PICTURE FORMAT allows to adjust such an image so that you cut the "void" are by scalling (enlarging) the visible area to fit the whole screen.
A problem then appears when the signal source is normal and showing full screen. Then, because of the enlargement, you start missing some of the picture. Before there was nothing there because it was showing adjusted wide (cinema) format to the TV box format, but when the new TV box format gets enlarged it sure starts missing around the edges.
That's what you're seeing.
More and more TVs do not have the ability to adjust that through the TV itself. Don't ask me why, but they can only do it through the remote.
So if you have an original remote there MUST be a button there that's called ZOOM or FORMAT.
It does the trick.
Hope this helps. If it does do not forget to rate it.
Cheers,
www.coppelltvrepair.com
Oct 18, 2010 | Vizio L32 32 in. LCD HDTV
Hello i need to order replacement band for my freest yle can u help??
Hello.
The BEST way to get an autentic Freestyle band is thru Freestyle. You can contact them at the following link:
http://www.freestyleusa.com/contact.php
Best regards.
Aug 14, 2010 | Freestyle Shark Buzz Wrist Watch
I have a JVC G40 DVD home theater system and when I play DVD's the voice and picture don't match up. Specifically, Peoples lips move and then a second later what they say is heard...how do I fix this?
When viewing on Digital TV:-
Sometimes Audio and Video signal can not be transmitted simultaneously due to additional process time for the video signal compared to that of the audio signal.
Often video signal takes more time than the audio signal to convert from analogue signal to digital signal in the Digital TV.
It may result in mismatch of the picture and sound.
In the TH-G30/40's HD AV Sync menu, you can adjust the audio signal delay for simultaneous AV signal transmission
1. Delay time can be varied in 10msec steps.(0 to 300ms)
2. Delay time is different between TV Brands.
So you need to adjust the delay time for correct lip-sync.
The adjustment is listed in the instruction book page12
Jun 26, 2010 | JVC TH-G30 Theater System
Faulty tevion lcd 32
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degradation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem.
  4. Open OSD to adjust the picture: Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed. If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV. If the image quality problems still exists across all types of signal sources, the TV should be serviced.
May 25, 2008 | Televison & Video
Instructons for baby carrier
You can probably find new instructions on Tomy's website.
Apr 24, 2008 | Tomy Freestyle Baby Carrier
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
