Question about Canon Office Equipment & Supplies
How can i fix the the problem with canon ir 4570 which produce an image the half is good and the other is bad . i already change the drum .
    Master:
  • Canon Master
  • 641 Answers
Hi. You need to be more specific. Printed paged are OK or it's just when making copies . If both copies and prints are bad . The problem can be in the printer section but if only copies are bad the problem is in the scanning section .
Posted on May 20, 2017
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
Ir 4570 print half side print is good and half side print is light how to solve
This problem may be caused by several different issues. It may be a dirty laser unit, a bad developing unit or a dirty or bad CCD unit. All of these will require an experienced technician to troubleshoot and clean or replace. I recommend you call an authorized Canon dealership.
Jan 23, 2017 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Canon ir 4570
Fuser unit / fixing unit problem check whether fuser sleeve is damaged if yes change it or apply fuser oil and white grease on it for smooth rotation....
Jun 24, 2013 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
I change fixing film still problem e000000-0001 what can I do? canon Ir 4570
you may have forgotten to tight connector screw of heating element.check it if it is ok then check the continuity of heater element with multimeter, if it is not showing continuity replace it.
Mar 02, 2011 | Canon imageRUNNER 4570 Copier
From where can i get genuine canon ir 4570 fuser film
Hello
The genuine parts is available to authorized Cannon Service Center or you can buy online from here http://www.precisionroller.com/fixing-film-assemblies---units-for-canon-imagerunner-4570/details_35006.html
Hope this helps
Jan 26, 2011 | Office Equipment & Supplies
My ir 400 gives a white spot
something could be blocking the primary chargeing corona wires/roller. i see it a lot on the ir 5000 when the primary corona assmbly cleaning pads get stuck half way through the cleaning cycle.
Jun 16, 2010 | Canon imageRUNNER 400S Copier
My old Canon NP1215 Copier: -First copy is
most probably a change of the drum and cleaning blade is needed ,check also the fixing/fuser roller
Jul 11, 2009 | Canon Office Equipment & Supplies
HOW TO SCAN THE DOCUMENTS IR4570 TO P.C ????
On the device you want to chose the SCAN option and set it to ONLINE.
You then need an application that does TWAIN scanning and aquire image data. Set your scanner device yo "Canon Color Network Scangear".
A freeware product you can use to test is irfanview
You would otherwise need to do an aquire / TWAIN scan from MS Word or Adobe Acrobat (full/pro) or another software that does TWAIN scanning.
May 06, 2009 | Canon imageRunner C3100 Copier
Canon ImageRunner 4570 gives me an error code:E000001-0010
A E 000 code is a fuser ass'y problem. It will need to be rest in service mode...
Mar 04, 2008 | Canon imageRUNNER 4570 Copier
27 people viewed this question
old marine
old marine
